Question about Campbell Hausfeld 26 - Gallon Air Compressor
My 26 gal. vt629102aj model air compressor want start
I try tro turn the switch to on and all it does is make a clicking sound
4 Suggested Answers
  • 19 Answers
SOURCE: Air leakage through pressure switch needle
1)Let your unit pump up.
2)Turn it off.
3)Find the supply line from the pump to the tank.
4)Remove the supply line from the pump head.
5a)If you hear air coming from the tank you have a bad check valve.
5b)If you do not hear air coming from the tank, you have a leaky
pressure switch.
Posted on Feb 02, 2009
brewerstool
  • 141 Answers
SOURCE: Model WL611200 30 gal oilless compressor will not start
It could be a couple of things. First and foremost check the plug and make sure the continuity is good for the wires. I have found sometimes that cords get smashed and the wires will be making contact inside the plastic sheathing. Sometimes you cant see where the problem is visually. Remove the cord from the switch and test the continuity with a meter. Check across the poles to see if there is a connection there that shouldn't be. If there is continuity across poles get a new cord.
If your cord is good then it could be your switch. There may have been arching that caused damage to your switch. Check for burnt marks and any wires that are touching that shouldn't be.
Check all wiring to make sure it is correct.
Lastly, your motor may be stuck. Check motor and wiring.
Posted on Sep 11, 2009
  • 1383 Answers
SOURCE: need air tank 26 gal tank rusted through
Contact local repair shops for used tank. May be different size or configeration but a little creativity will save lots of money. Usually motor or pump will fail so there are many good tanks around. Or order new from www.chpower.com or www.toolpartsdirect.com ,good luck
Posted on Sep 30, 2010
My husky 26 gal air compressor will not stop running
Sounds like you have a faulty shut-off switch...
Replace the shut-off switch with a new one...make sure it is of the same shut-off and turn on values
Mar 30, 2013 | Air Tools & Compressors
Compressor shuts off at 60 psi will not come back on until opsi
If the pressure switch has been changed you will need to reset it if not ,then is the compressor trying to come back on but will not start untill it reaches 0 psi?
Apr 25, 2010 | Campbell Hausfeld 26 Gallon Low Rider...
Problems with kobalt air compressor 26 gal. simply would not start
Check and reset motor thermal overload (red button) on motor, also check circuit breaker for your power supply. other than that the pressure switch is what stars and stops the motor, and depending on your level of knowledge you will need to check continuity through the pressure switch with a ohm meter.
Jan 20, 2010 | Air Tools & Compressors
Air compressor motor won't stay on?
The pressure switch controls the motor on and off. Adjust the pressure switch up to increased the 'off' setting for higher pressure.
Sep 17, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
My campbell and housfield 60 gal wont run.. help
10 AMP CIRCUIT SOUNDS WEAK. WIRE MAY BE TOO SMALL. ARE YOU SURE ITS NOT WIRED FOR 220 VOLTS AND YOUR RUNNING IT ON 110. START CAPACITOR COULD BE BAD BUT TYPICALLY WOULD LEAK OIL-LIKE FLUID IF IT WAS DAMAGED. CUTTING OFF AND ON CONTINOUSLY COULD BE THE PRESSURE SWITCH IS DAMAGED. SOUNDS MORE LIKE WRONG VOLTAGE. THERE ISNT A LOW OIL PROTECTION DEVICE.?
Feb 04, 2009 | Campbell Hausfeld 26 - Gallon Air...
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
240 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
