Question about Sony CDX-CA750X CD Player
My car fuse recently blew (which controls live feed to my player). However when I changed the fuse the player now wont light up. I know I have power because I can eject a CD and the reset button causes the player to make a whirring noise Any suggestions? thanks! Brett
  • brett850 Jan 06, 2009
    Wow awesome ! Disconnecting the set from the power for ten minutes did the trick !
    Many thanks!
  • 1,990 Answers
Check your Ground wire on the Wiring Harness for the Stereo. If good Disconnect the Power and Ground for 5 Minutes then Reconnect. See what we have got then. Let me Know!
Posted on Jan 04, 2009
  • Travis Humphries
    Travis Humphries Jan 07, 2009
    No Problem! Happy to Help!
My buddy has a 03 trailblazer he blew a fuse tiring to wire in some lights with his dome light so we replaced the fuse everything works good but the dome wont turn on when u open the doors and when u lock...
sounds like you blew more than one fuse.
check the live feed to the dome light, then check the earth return through the door switch, make sure it switches. if no earth return you must check wiring and switch. if no live, go back to fuse boxes.
Apr 21, 2014 | Cars & Trucks
I have a 2009 volkswagon jetta diesel my battery was bad so my son put his truck battery in it and hooked it up backwards now the power steering light is on and no power steering also alternator light is...
Hi, first thing to do and if you know location of the fuse box take light tester and test each fuse may you find some fuses blew. change theme first. if you change the fuses and the the problem for each item you describe still on that mean damage went to the items you say.
Dec 14, 2013 | Cars & Trucks
I have a 87 jeep comanche. auto. transfered to 4x4. my dash light wont work, i believe its a dead short because i raised the fuse number and it still blew. my question is, were would be the most likel
When say "dash light" I'm assuming you mean the nighttime illumination for instruments like the speedometer for example. If your truck has a stand-alone digital clock (not part of the radio) that has a feed wire from the instrument panel lights for it to dim at night, otherwise it'd be too bright. That could be a source of a short. The radio also makes use of the dash illumination as well, making the digital display darken at night and lighting the radio's controls and face plate at night, another source of a short in this circuit. Do not ever increase fuse ratings when replacing a fuse, that defeats the safety purpose of the proper fuse being able to blow, opening the circuit which prevents wires overheating and potentially catching fire. You don't want to go there. If you have recently installed another radio the wiring may be wrong. This happened a LOT on Pontiac Firebird's and TransAm's. People often wrongly assumed all black wires are ground and ended up grounding the dash illumination input. This blew the dash light fuse and made the retracting headlight doors stay up.
Jan 01, 2012 | 1987 Jeep Comanche
My stereo is stuck on one station, dosn't light up wont turn off/on \r\nthe volum control not working, cant change station, I don;t know whats going on with it !!! It worked fine yesterday
check all of your fuses, the radio has 2 power feeds, one for the operation and one for the memory, if the memory feed is out the radio will work partially like you explained
Sep 23, 2011 | 2004 Dodge Durango
Where is the fuse for the trailer brake controller on a 2006 chevy silverado 2500hd, i think i blew it installing the controller and can't see any blown. I did have power and now I don't.
The same fuse that feeds the high mount brake light feeds the brake control. Should be in the side panel on the drivers side.
Apr 21, 2011 | Chevrolet Silverado 2500HD Cars & Trucks
Wont turn on
If it does not turn on at all, then there is something wrong in the wiring at the back of the unit. Double check wiring. Eventually use a volt-meter to check if there is 12V in the power leads. This units also have a fuse at the back. Replace the fuse. If the fuse blew, that means that there was a contact or an incorrect wiring.
May 29, 2010 | Farenheit DVD-61 Car DVD Player
My honda worked until i had my two fridges pluged in then i turned a light on it blew the light now it worked power anything it runs good but like i said it wont give power to anything would there be a...
yes there should be. there should be a circuit breaker, try to reset that. then find the circuit protectors and check those. without model# I dont know locations but probably around the control panel.
Jul 30, 2009 | Electrical Supplies
Dash lights wont work
Some Honda vehicles illumation wire (orange wire)is switched ground. Once connected, turning your lights on will blow your 'small lights' fuse which is a constant power fuse that should be located under the hood. you should just cap off (do not connect) the orange wire and replace the fuse.
May 20, 2009 | Pioneer AVH-P5700DVD Car DVD Player
No display
check wires make sure they are not grounded meter them
Jan 04, 2009 | Sony CDX-CA750X CD Player
Sony CDX-CA750X CD Player Logo
94 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
