Question about Sony Cyber-shot DSC-W50 Digital Camera
Shutter takes to long to take pic and subject has moved.
Are there any settings that speed up shutter release?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
This is a common problem with compact point&shoot cameras.
You can reduce the delay by anticipating the shot. Pressing the shutter release button halfway focuses and meters the exposure. Keep holding it there until the right moment, then press it the rest of the way.
Posted on Feb 27, 2012
3 Suggested Answers
  • 883 Answers
SOURCE: slow shutter speed
from the manual: Using Shutter-Priority Mode 1. Set the mode dial to S (shutter-priority) and a yellow arrowhead on the screen points to the current shutter speed. Press the jog dial and the current shutter speed turns yellow. 2. With the current shutter speed displayed in yellow, rotate the jog dial to select the speed you want to use. 3. Take the picture. If a workable aperture isn?t available for the shutter speed you?ve selected, the shutter speed indicator on the screen flashes when you press the shutter button halfway down. You can use the setting as is, or press the jog dial down to select the shutter speed again and rotate it to select a new shutter speed.
Posted on Jun 04, 2007
htechie
  • 146 Answers
SOURCE: Setting shutter speeds
Lumix DMC-fz18 Manual/Instruction book
http://service.us.panasonic.com/OPERMANPDF/DMCFZ18.PDF
Posted on Aug 23, 2009
How to take certain types of pics for my college class in photography. I am trying to take action photos and in them, I am supposed to use shutter priority.
Hi, Tina,
Hope I can help - it's quite simple really. Shutter priority means that you set the shutter speed (as in 1/30 sec, 1/60 sec etc) and the camera sets the lens aperture (as in f4, f5.6, f8 etc). It is up to you to choose the ISO rating, but for action I would use either ISO 200 or ISO 400.
If you use a slow shutter speed (such as 1/30 second) you will need to use a sturdy tripod to support the weight of the camera and lens (you've not specified which lens you are using, so I'll assume a zoom with a maximum focal length of 200mm). You will also need to use a remote release to fire the shutter, in order not to impart camera shake.
By using a slow shutter speed, you will automatically impart blur to the image - check on the monirot, and if the image is too blurred, choose a faster shutter speed (i.e. 1/60 second) - don't forget, the camera will take care of the aperture.
The angle from which you take the photos will also affect the result - if you are 'head-on' to the action, then there will be little sign of movement, whereas if you shoot from the side, then movement will be across the frame and will show to a far greater effect. A compromise is to stand at about 45 degrees to the action, so you get movement but the subject is still identifiable.
For frozen motion, just select the camera's fastest shutter speed, which on your camera appears to be 1/4000 sec. You will need to increase the ISO rating as well for this to be usable, especially on a less-than-sunny day - ISO 800, or even ISO 1600 may be necessary. I am assuming you do not have access to infra-red remote triggering equippment, so you'll need your remote release again. As there is a perceptible time-lag between deciding to fire the shutter and actually doing so, anticipate where you want the subject to be in the photo, then fire the shutter before it reaches that point.
Some people like to use burst shooting mode to ensure that get a selection of images, from which they can choose one or more, but since this is a college assignment, I would suggest practising until you can pre-visualise what Cartier-Bresson termed 'the decisive moment'.
Panning fills some people with dread, as it is the least predictable way to capture motion, yet can provide the most spectacular images. The camera will need to be hand-held for this - as I am sure you know, received wisdom states that when hand-holding a camera, the slowest usable shutter speed is the reciprocal of the focal length (i.e. for a 200mm lens, a shutter speed of 1/250 sec is considered the minimum) - this is to prevent camera movement during the exposure. With panning, we actually want camera movement to be plain, so choose a shutter speed of 1/60 sec or 1/125 sec. Again, a high ISO rating will be helpful - say ISO 400 or ISO 800. This is to ensure a reasonably small aperture, thus increasing depth of field.
Panning usually works best when the subject is parallel with the photographer, or maybe a little before this point, and the technique is very simple. You merely look through the viewfinder at your subject, making sure it is approximately in the middle of the frame, and, continuing to swing the camera at the same rate as the subject is moving, release the shutter just before the point you have selected as likely to give the best result. With a DSLR, of course, everything goes black as the mirror swings up, but it is vital to keep panning smoothly, because now is when the image is being recorded.
When the mirror returns to its usual position, if the subject is still in the viewfinder, there is a very good chance you have taken a successsful shot. Well Done !!
You haven't specified the subject matter for this assignment, but unless you are on safari in Africa shooting Klipspringers, chances are they will be people or pets. People are easiest - on a running track, they travel at a reasonable speed, and you have the chance to make adjustments in between each lap. Cyclists, unless on a velodrome or short city-centre circuit, pass less frequently, and at a greater velocity. Racing cars - possibly a little optimistic for your first attempt. Dog or horse shows may provide suitable subjects as well.
Main thing is - practice ! That is the great advantage of digital - instant replay, to check for areas to be improved, and almost unlimited storage. One final bit of advice - although RAW gives better results, JPEG writes to the SD card far faster, so you won't miss the one perfect shot of the day waiting for the data to be written to your card. Good Luck !!
Tony
Sep 25, 2016 | Nikon D3200 24.2 MP CMOS Digital SLR with...
Nixon S8100 fairly new camera, nice pics if the subject doesnt move but horrible pictures if object moves. Very blurry.
If everything in the picture is blurry, you are moving the camera when you press the shutter button. If only the subject is blurry and the background is clear the problem is too slow shutter speed. If this is cause by movement of the camera you must learn to SQUEESE the button while being sure you don't move the camera. It just takes a little practice. If this problem caused by a shutter speed that is too slow, it is remedied by increasing the ISO "film" speed. Even though you have no film, the camera has a "speed" setting that relates to that. The higher ISO value increases the camera's sensitivity to light and thus allows for faster shutter speed. Normally the ISO choices are 100, 200, 400, 800, 1600. Try using 400. The ISO setting is in one of your camera menus. 400 is fast enough to solve your problem in all but very fast movement of either the camera or subject. Using ISO above 400 will cause your pictures to look grainy and not as sharp. Use the highest speed only when absolutely necessary. Slower ISO numbers produce the finest grain and thus the sharpest pictures. It a trade off between ISO and shutter speed because the exposure is a combination of the ISO and shutter speed and lens opening. Each one effects the exposure by half or double.
Apr 16, 2011 | Nikon Cameras
How do you take a picture of a fast movement?
It depends on the effect you want.
  • To freeze motion, you need either a fast shutter speed, or a fast flash in a dark environment. In less than bright light you may not be able to get a fast enough shutter speed to stop the action. Increasing the camera's sensitivity to light by increasing the ISO will help some.
  • You can blur the motion by using a slower shutter speed and a stable camera. Set a slow shutter speed and put the camera on a tripod or other stable surface, and you can get things like streaking car taillights and star trails. How slow a shutter speed depends on the speed of the subject.
  • You can pan with the subject. Move the camera with the subject, and keep it moving even while the display blanks out while taking the picture. This will keep the subject sharper while blurring the background to lend a sense of motion to the picture.
  • It's either to freeze motion if the subject is moving straight toward or away from you than if it's moving across your field of vision.
Sep 10, 2010 | Canon PowerShot S2 IS Digital Camera
My canon powershot SX100 IS has image stabilizer, but apparently I'm not using it properly. All my pics, even stand still pics, turn out blurred. What am I doing wrong? My sons graduation pics were ruined,...
Image stabilizer (IS) will help you stabilize your shaky hand when photographing static object in dim light environment. When photographing moving things such as humans, camera IS will not and cannot not freeze them unless you use high shutter speed. If your camera allows high ISO and manual shutter speed setting, experiment indoors with it. Just remember, high shutter speed freezes motion and IS can only steady your shaky hand for so long. Tripod can only steady your camera not the subject if the subject is a human being.
Aug 18, 2009 | Canon PowerShot SX100 IS Digital Camera
D50, blury pics
Blur can occur if the shutter speed is too low relative to the degree of movement of your subject(s). While the 'sports' mode favors shutter speed and adjusts the focus for moving subjects, you may still need to increase the ISO (I'm not sure the camera does that automatically), or use flash, if feasible.
Alternatively, try panning the camera with your moving subject. This should blur the background, but keep the subject from blurring.
Finally, keep in mind that in sports photography, blur is sometimes a desired outcome that produces a sense of motion in an otherwise static photo.
Hope that helps.
Nov 14, 2007 | Nikon D50 Digital Camera
Canon sd 550 (and sd 200) shutter speed
If you check out a review site such as www.steves digi cams. com or even the Canon site to check out the spec of the camera to discover what shutter speeds are available. When shooting fast moving subjects try panning the camera on the object as you press the release this will[to a degree] keep the primary image sharp[ish] whilst blurring the background
Feb 26, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
What is the available shutter speed range?
The DiMAGE A1 controls shutter speed in the range of 30 sec. to 1/16000 sec. in 1/3 increments. (at bulb maximum 30 sec.).
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
The subject is very blury or out of the picture
You are expecting too much for any auto mode. When shooting under low light conditions, the camera may take longer to achieve focus lock. If the subject is moving too, it will take even longer to lock focus. Try using manual focus for the conditions you described.
Sep 06, 2005 | Olympus Camedia C-765 Digital Camera
Blury
Sony Cyber-shot DSC-W50 Digital Camera Logo
47 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
