Question about Crosley 4-in-1 Entertainer CD Shelf System
Stuck on hello
After i plug in the unit the LCD screen says Hello and never changes. I tried pushing every button including the function. Just stuck on Hello
  • dvtuttle Jan 11, 2009
    I have the same problem. Stuck on "hello". Nothing will work, Very aggravated with it.
  • marsilva Mar 18, 2009
    Same problem. Stuck on "Hello". None of the buttons work except stand by. I've unplugged it several times...and it comes back to Hello.
  • 53 Answers
SOURCE: Crosley CR247 never used, sat for almost year, display :"OPEN"
seems you need to go to the spesific mode, fono, or radio mode.
Posted on Sep 04, 2009
How do I fix problem with hp pavilion dv7 that the fan runs but screen remains black and the keyboard does not function
hello Anonymouse
It is possible that the problem in the slide card that beats screen located on the main board and the faults which also appear on-screen plasma appearance of a white image on the screen or the colors are without any data. Easy to verify the integrity of the slide card that beats the screen by pressing of Touch Pad or the left part of Keyboard to the East, including notes. When connecting to an external monitor with no emergence of data
Among these symptoms we see that it is clear that the device temperature was high because of heat produced following larger processor and thus the slide master ICH
Card and slide the screen. However, the slide of the type Intel does not notice the high levels of heat and when exposed to heat the welding related Qdanvsal on the main board of the parent on the board
Sep 15, 2014 | Computers & Internet
I have a electrolux dishwasher. Non of the buttons will function and the display is stuck on clean.
Hello louisewith4 - I understand none of the buttons functions on the dishwasher, however try unplugging the unit or flipping the household breaker off. Wait approximately ten minutes and I suggest touching each button individually on keypad, does the display change or will it start? If not, I would recommend contacting a professional because the unit may possibly have a defective keypad.
Nov 15, 2012 | Electrolux 24 in. EDW5505EPS Stainless...
Laptop screen has lines
Hello. If you gently push on the LCD display panel, and these lines clear up, the display, or cables going to it are either bad or loose. These units use ribbon cables that simply plug in and are locked down. If they become loose, you pushing on the display may cause the unit to work temporarily.
Dave
Sep 27, 2012 | Acer Aspire 3610 Notebook
Hi I have a pixma mp800 and it all works ok until i select the memory card function then the screen gets stuck and I cannot do anything else but turn it off from the plug. When I turn it back on all the...
Hello this due to a faulty card reader on the printer and will need repair, but considering the low cost of printes to day it may be best to just purchase a new printer.
Aug 24, 2011 | Canon Pixma MP800 All-In-One InkJet...
How do i change my pictue size using remote control
Hello
To select the picture size using the remote control
Press "Picture Size Button" on the remote control
While the Picture Size screen is open, you can do one of
the following to select the desired picture size
Repeatedly press "Picture Size Button"
Press the corresponding Number button (0-6) while the
Press UPor DOWN button, while the Picture Size screen is open
Using these functions to change the picture size (i.e.,
changing the height/ width ratio) for any purpose other than
your private viewing may be prohibited under the Copyright
Laws of the United States and other countries, and may
subject you to civil and criminal liability
OK
May 11, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
Hello , My TV is 42PFL7422 LCD , The problem is oprating function change itselfs and also chanel TV with AV port. How to stop it Thank you
he problem of your TV is the button of the channel will not getting back so channel can't stop
you have to do is replace the button if you will or use a remote control to access the channel and never use manual changing channel again
Mar 09, 2011 | Philips 42PFL7422D 42 in. LCD TV
My HP Officejet 7410 Unit is powered and the HP Invent logo is displayed on the screen with the progress bar moving at the bottom, but the power button is not lit and none of the other printer functions...
I will advice you reset the printer, follow the steps below to reset the printer,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold ?# and 6? keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
If that did not fix the problem, try this,
  1. Unplug the power cable from printer while the printer is powered on.
  2. Press and hold OK and HELP buttons while plugging in the power cord. Wait for the screen to go black or blank before releasing the keys.
  3. Just turn on the printer and configure your printer new.
The problem should be fix with this.
Take care.
Sep 14, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Lcd says hello and does nothing
sounds like the power supply could be going bad or else there is a disc stuck in the player. regardless, either require professional repair.
Jul 11, 2009 | Televison & Video
IR 2220i - change clock
Hello Debant2,
I believe on this model you go to additional functions (an asterisk looking button just to the left of the nine key pad) and this should give you a menu screen which will include a tab on the left that says timer settings. Press it and you should see where you can change the time. Take care. :-) .......SPINAL......
Apr 01, 2008 | Canon ImageRunner 2220I Copier
My panasonic SV-MP020 mp3 player does not turn on. and when i plug it into the USB, it's stuck on hello. help me pleaz!
Try reseting the unit.
1) Slide the hold switch to on
2) Turn power on.
3) While unit screen says hold, push: (mode)(-)(+)(-)(+)(mode)(+)(mode)
This should reset it.
Source: http://www.fixya.com/support/t129568-frozen_displays_wait
Aug 28, 2007 | Panasonic SV-MP020 MP3 Player
Crosley 4-in-1 Entertainer CD Shelf System Logo
49 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Robert Marmorstein
Level 1 Expert
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
