Question about Dell Inspiron One 19 All-in-One Desktop PC with 18.5" LCD Display, Intel Pentium Dual Core E5400 Pro... (884116033820)
My inspiron 19 is not turning on
The computer is not turning on, no lights are on. The power outlet is fine.
  • Dell Master
  • 32,281 Answers
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Nov 04, 2012
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
My Dell All in One Inspiron One 19 will not power on!
Dell Inspiration One 19A Dead - Repair
Face down. Remove the plastic panel covering the sockets at the back. Remove the stand, 4 small black countersunk screws. Turn over and unclip the bottom panel. Unscrew the plastic piece across the computer under that panel. The escutcheon around the screen should now unclip. Unscrew ~8 screws around the edge holding the back to the metal-work. Carefully invert, face down, and lift off the back. The power supply is in the middle. Another bottom piece of metal may need to be unscrewed first. Remove the cover from the power supply. Four screws hold the PC board in the power supply box.
Two green 820 uf, 25 volt capacitors are likely to have bulged tops.
Replace them anyway. Reassemble after testing.
Nov 22, 2011 | Dell Inspiron One 19 All-in-One Desktop PC...
Yellow light blinking on my Dell Inspiron one 19 and won't start up
if you have replaced the MB and power supply, then the from IO panel could be the failed component
Nov 16, 2011 | Dell Inspiron One 19 All-in-One Desktop PC...
Inspiron 2305 power cord doesn't turn the desktop on
After connecting the AC adapter to a wall outlet and to the computer press the power button the right side of the inspiron. The button itself should then lite up white if the power adapter is good. If not, check the power outlet you are using. Plug in something else and see if it works on this wall outlet. Some outlets are connected to a wall switch. If its still a nogo you may need to replace the AC adapter.
Sep 18, 2011 | Dell Inspiron One 2305 Desktop Computer...
Dell Inspiron 1000 won't turn on. It is always
Well if it is always plugged to the wall then the laptop's power jack is the common problem there. You can have a Computer Technician check it and diagnose it for you. Be careful how much you pay, if that is the problem (i'm pretty sure it has to be) you can shop for the part online (ebay is a good place to find them for around ten bucks) and hand it to the computer guy. Otherwise you may be charged a fortune to get it fixed. Next time, use a power surge between the power adapter and the wall's power outlet.
Here's is a brief explanation of what happens with the power jack. Inside of it there are two or three pieces of metal that look like thick wires and what they do is transfer the current to the laptop. Eventually they wear out and break (common cause is having your laptop plugged to the wall continously exposing it to all sorts of power surges). Hope it helps, good luck.
Jan 03, 2010 | Dell Inspiron 1000 Notebook
Laptop has shut down with no power lights
laptop dose not turn on but lights are on
Feb 23, 2009 | Dell Inspiron B130 Notebook
Mag lt982s no green light no power at all
try testing it in another outlet a known good outlet if it powers on then your outlets bad if it doesnt means a bad cord or bad monitor
Feb 10, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Problem turnining computer power on
your power supply is going bad, its an easy thing to replace and less than sixty dollars to replace for about a 450 watt power supply
Dec 06, 2008 | Dell Inspiron 530s Desktop Computer...
Won't Turn On
Hi
If the green light doesnt turn on, check if the wall outlet is workign properly.
Also pls check with another moitor power cable.
If the above steps dont work, then the monitor needs to be serviced.
Jan 14, 2008 | Acer AL1912 19" LCD Monitor
Dell Inspiron One 19 All-in-One Desktop PC with 18.5" LCD Display, Intel Pentium Dual Core E5400 Pro... (884116033820) Logo
95 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
