Question about HP Officejet 5610 All-In-One InkJet Printer
Some kind of strip of plastic has come off the printer.
My printer was working fine when a strip of plastic started coming of the printer. I think my little brother ripped it off, but is it possible to replace it? I dont know what it's called but I want to see if I can put in a new one.
  • mworia Jan 05, 2009
    Some kind of plastic strip or a broken belt around the cartridge carrier unit came out I think a rat ate it together with a plastic sheet attached the cartridges.
    Genius:
  • 2,120 Answers
Encoder strip is not available as a seperate part.
Posted on Jan 05, 2009
IP1500
Solution 1:
Look inside for a tiny object like a piece of paper, a staple...
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough . Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Solution 3:
Clean the timing strip: there is a thin plastic strip running across the width in front of and below the drive belt: there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence.Gently clean this strip with a damp lint-free tissue.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 20, 2012 | Canon PIXMA Office Equipment & Supplies
Plastic strip inside printer
The only plastic strip that is user serviced is the protective strip for the ink cartridge. It comes with all new cartridges, or new printers. You are supposed to pull this strip out for proper cartridge operation (printer will not work with the strip still attached). When you pull it out, be very careful that it doesnt whip and touch your clothing. The plastic strip will be wet with ink, and if it touches your clothing, it will positively NOT come out.
Apr 04, 2012 | Epson Stylus® RX640 All-In-One InkJet...
I have canon mp145 printer. when it starts to print it gives the service error 5100 message
Tried greasing (actually WD40) per linzi's reply, but it did not help. In the process, I think the solution presented itself. There is a thin (1/4"wide) plastic strip running across the width in front of and below the drive belt. This is part of the optical encoder that tells the print-head where it is. If you look closely, there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence. Gently clean this strip with a damp lint-free tissue. This also fixed a gap in the printing running lengthwise (not across the page like a clogged head).
Jan 27, 2011 | Canon MX700 Office All-In-One InkJet...
Canon MP600 Printer - How do I fix error code 5100
Hi Whitey621
Error code 5100 Try
Solution 1:
Solution 2:
There is a thin plastic strip running across the width in front of and below the drive belt: there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence.
Hope It Helps: Pineworks.
Jan 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Cannot use our magnetic stripe cards to login. They scan ok but do no work.
Wrap the magnetic strip in a plastic bag (the kind of plastic bag you get at a grocery store) and then swipe the card and it will work just fine. I learned this working in gas stations when the customers card did not work it would work when the strip was wrapped in plastic
Dec 30, 2009 | Pc America Restaurant Pro Express
Hi My problem is that this plastic strip has come off of something and now the ink cartridges go back and forth really hard but doesn't print anything. There are little slits on each end of the strip. One...
Hi Debbie,
If the plastic strip is about 10mm (or ~0.4 inches) and about the with of the printer, and if you look very closely the strip is striped (with tiny very think vertical lines).. .that strip is the locator strip… The ink cartridges read that strip to know where the carriage is (ie the carriage reads/counts the strips and then it knows where it is)
Hence if the stripe is now in your possession the printer doesn’t know where the cartridges are and just keeps moving them back and fro hoping to “find them”.. sadly without that stripe you printer will work no more L
Sorry.
Ed
Nov 08, 2009 | HP DeskJet F380 All-In-One Printer
Repair
First remove the flip up lid and the paper support tray then remove two small phillips screws one infront of the black ink cartridge the other on the far right. Then use two regular screwdrivers to pry off the cover start at the backside underneath you will see two tab slots walk the screwdrivers about 1" apart until the top is free (you will think that it is going to crack but the plastic is flexable and strong)
There are two metal tabs on both sides they are held in place by the tension from the plastic strip. Check strip ends make sure they are not broken and the strip is not frayed slide back in place adjust tension by bending tabs out slightly reassemble and print a test sheet. I had to run the test 2-3 times to reset the printer. If this does not work you need a new printer.
Feb 20, 2009 | Canon PIXMA iP1600 Printer
Lexmark z730
Try putting the plastic strip in. I think it should help. Anyways i had the same problem but mine didnt work even after replacing it. So Igot an HP all-in-one and I'm satisfied :).
Nov 09, 2008 | Lexmark X2350 All-In-One InkJet Printer
Printer will not work
there is some kind of plastic strip on the new cartridges did u remove that strip?
Sep 03, 2008 | Brother MFC-5440CN All-In-One InkJet...
Carriage jam message
I had this same problem and spend hours working on it. Took the side panels apart to get a better look. Nothing anyone said fixed the issue. Not even the link everyone keeps posting to HP's carriage jam fix. Was out of solutions and about to give up and order a new printer. There was one last thing I had to try that I didn't think was going to work, but I had a theory. Right after I tested this solution it started working again. This worked for me, but anyone who has tried every and have not got their printer to work can try it.
My Solution: Open the front covers and look inside. Just above the metal rail that the carriage travels on there is a thin plastic strip about 1/4 in. width and should have a glossy shine to it. I believe this is some kind of positioner. It runs through the carriage and gives it some kind of position. After years of use, it'll become dirty with ink. I used some tissue and alcohol and wiped the strip clean. It worked perfectly fine right after. Below is a picture of the strip I underlined with a yellow line.
Aug 27, 2008 | HP Photosmart C4180 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
122 people viewed this question
Seeker5211
Seeker5211
