Question about Kenmore 22422 Top Load Washer
Kenmore washer will not go to rinse cycle. 70 series
When the washer gets to the rinse cycle, it stops. I have to turn the dial all the way around back to the rinse cycle and slam the lid down hard to get it to start again and this works. Maybe you think its the lid switch that has to be replaced. Help. sincerely Ruben.
I had the same problem and it was a broken switch that prevents the washing machine from going into spin with the the top door open. The switch is located in the upper left corner, you can see 2 screws that hold it in. Reach under and check that the middle point when pressed pulls the ends where the actual switch is, you should hear a click.
I was able to temporarly repair by focing the swtich to always be depressed with 2 strips of duct tape. - Warning the washer will go into spin cycle with the top open.
Posted on Jan 08, 2009
Kenmore 70 series washer
If you can see a constant water pressure from the hot and cold, chances are the water solenoid valves are ok.
I would look towards resetting to factory and checking the main control unit.
May 11, 2014 | Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore washer Heavy Duty (70 Series) 1985-1989
behind the knob that you use to set the water level is the level control it should have a n adjustting screw to set the water level(you can set it where you want)
Aug 20, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Jul 10, 2009 | Kenmore 22422 Top Load Washer
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
How to work my washer?
the timer change by itself. You don't have to change anything.
But cold rinse only works if you have the cold water connect to the washer
May 08, 2008 | Kenmore 24032\24036 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
85 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
