Question about Sears Parts Direct Washing Machines
Maytag lat2500aae timer 22003363 - Sears Parts Direct Washing Machines
2 Suggested Answers
SOURCE: are there fuses on the
I have the same model with the same problem. Did you ever get a solution?
Posted on Oct 01, 2011
My Maytag performa series LAT2500AAE fills to the medium level no matter which setting I use. It does NOT overflow.
If your infinite water level switch has a reset, perform this before changing the water level setting prior to your next load, this is usually done by rotating the knob to the reset zone, then back to your desired water level setting. If your problem still exists, you will most likely need the water level switch replaced Part# 22001776. Pleazer Appliance...
Apr 16, 2014 | Maytag Washing Machines
Lat2500aae We have a Maytag Performa, Model
it sounds like the shocks on the drum maybe failing. on this model the washing machine mother board is close to the outer drum. the out drum may have made contact with it. and not turning on the pump to let the water out.
Oct 06, 2013 | Washing Machines
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
I have a Maytag LAT2500AAE top load washer. The
check the balance ring on the tub just below the tub cover and tub cover gasket which can be done from the top of the machine by removing the top cover,while doing this pull and push tub from side to side and see if it moves easier in certain directions, if it does you may have a tub spring broken on the tub leading to an un balance condition cause the springs stabilize the tub like a shock absorber on an auto, if this is it then you need to access the lower unit area by removing the front cover of the unit there are screws at the toe kick panel to remove this panel
Dec 08, 2009 | Kenmore 24032\24036 Top Load Washer
Newbie Question
Look carefully under the front panel. there is a clip on either underside of the front panel. Insert a putty knife or screw driver in the clips to release. Pull the panel upward until the top clips are released. This is one of the best machines Maytag ever made.
Jun 23, 2008 | Washing Machines
The drain hose on a Maytag model #LAT2500AAE is leaking so I would like to replace it. From the back panel, it is way inside and difficult to reach. How do I remove the front panel?
there are 2 clips at the bottom left and right that pushes in or you may have the one with 2 screws on bottom left and right cornier..
Jun 03, 2008 | Maytag Washing Machines
I have Maytag LAT2500AAE. I took off the front cover and I see water leaking from the tub bearing during the rinse cycle. I think I need the Tub Bearing Repair Kit PS60151. Is this a difficult...
Tub bearing replacement on ANY Maytag can be difficult. Even for experienced technicians, it can take 1 to 2 hours as long as there are no surprises (corrosion, stubborn bolt etc). Also, all Maytag washers require specialized tools for removing certain components of the machine.
May 29, 2008 | Washing Machines
Maytag LAT2500AAE- unbalanced
see if it has 4 adjustable feet on each corner on the bottom
get a bubble level from a hardware store and turn the feet to raise or lower OR you could use something else to raise the sides until it is leveled by looking at the bubble level.
hope this helps
thanks for your rating
Jan 09, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
60 people viewed this question
Top Sears Parts Direct Washing Machines Experts
Are you a Sears Parts Direct Washing Machine Expert? Answer questions, earn points and help others
