Goodman gms80703an bc pressure switch stuck open
  • 3087 Answers
SOURCE: my goodman gms80703 has three blinking lights
you can blow through it or put a drill bit down it to clean the conections where the tubes push on
Posted on Feb 28, 2009
  • 189 Answers
SOURCE: pressure switch stuck open
It most likely is not stuck..... It is just doing its job. You "most likely" have over problems. To "properly" diagnos this problem you will need a manehelic gauge. You can have a wide variety of problems from as simple as a blocked or disconnected vacum hose to a lifetheatening problem.... a blocked flue pipe or a bad heatexchanger.
BE CAREFULL
GOOD LUCK!
Posted on Mar 08, 2009
  • 25 Answers
SOURCE: Code 3 - pressure switch stuck open. What do I do
where vent motor is there is usually a hose coming off which oressurizes when vent motor comes on, take hose loose **** or blow in it, take tooth pick and stick in all ports where hose connects (could be clogged) when sucking on hose you shoul hear pressure switch click each time you pull a vacumme, if fan has switch on back of fan as some Goodmans have the vent motor may need to be replaced.
Posted on Oct 28, 2009
  • 2976 Answers
SOURCE: Need to find the pressure switch on my goodman furnace
It's mounted onto the gas valve. It will be a button or lever that you have to push in or down, depending on the style.
Posted on Nov 20, 2009
  • 52 Answers
SOURCE: I have a Goodman GDS80904BNA. I'm getting 3
These furnaces have notoriously bad circuit boards. The light will give you a diagnostic code and after you have replaced every component there it still will not work right. Need to know more specifically the order of events happening. the blower should turn on (draft blower) then after a second a click and you will see the ignitor glow bright orange then click the gas valve opens and the burners light. most of the time this will all happen and then the flame in all burners will go out and it will attempt the whole process over. if this is the case turn power off and then remove the circuit board from the 4 retainer clips and look at the back 9 times out of 10 the board will be dark brown in one or two spots large spots at that. time to replace the circuit board. They have updated the board and it is being made by a different company now. Take a picture of the board before you remove any wires so you can replace the wires in the proper location.
Posted on Dec 13, 2009
I have installed a wood burning furnace and was hoping to run the blower on my goodman gms80703an and thermostat without having to ignight the gas furnace
If I am understanding you correctly, you are just wanting to circulate the air with your gas furnace and heat the air with your wood burning stove. You should be able to set the fan switch to the ON position and leave the heat/cool/off switch in the off position.
Nov 29, 2015 | Goodman Heating & Cooling
Heater does not come on gms80703an
There are too many reasons for this to happen so we would have to narrow it down. The sequence of operation on a Goodman furnace is usually:
1: Inducer draft motor comes on
2: Hot surface ignitor comes on and glows
3: Gas valve opens, lights burners
4: Flame sensor detects flames
5: Blower comes on
If the inducer motor never came on, then you start looking at power to the unit, thermostat issues, or inducer motor issues. Just a few places to start. Hope this helps!
Dec 05, 2013 | Goodman Heating & Cooling
Goodman Gas Heating A/GPG13 Not Heating - Pressure Switch Stuck Open
Clear the little hole where that hose go to the inducer case
Feb 10, 2013 | Goodman Manufacturing Goodman...
Goodman GDH80703AXAC pressure switch stuck open
Possible water inside switch & or tube..(Condensation)Rremove switch and gently tap the switch to see if water comes out.If not replace the switch.
Oct 29, 2011 | Goodman GMS90703BXA Heater
MY Goodman furnace mdl #GMS80703AN would not come on. Diagnostic lite flashed in threes. I called Installer who instructed me to stick a small wire or other object carefully into hose connection from...
This code is for a pressure switch failure. Do not stick anything into the pressure switch or blow into it. Either will damage it. You may however do as your technician suggested and clean the inducer motor port as well as the hose. If this does not fix it, begin inspecting the flu for blockage and make sure there is enough combustion air supplied to the room for combustion to be sustained. If all of this checks out ok, You can use a Ohms meter to check the continuity on the pressure switch. If this is ok you may have a gas pressure problem. Do not attempt to adjust the gas pressure if you are not certified to do so because the gas valve can be damage in the process not to mention the risk of explosion. Good Luck!
Nov 15, 2010 | Goodman GMS90703BXA Heater
Oct 27, 2009 | Goodman GDS80703ANA Open Flame Mid-Size...
I have a goodman gcs90703bxa flashes 3 times blowed in the pressure hoses went from 3-2 flashes what could be wrong?>
flash 3 is a blocked pressure hose. the switch is open. flash 2 is the pressure switch stucked closed. if you applied pressure to the swich you may have damaged it . It typically clogs on the Induced draft motor housing on the bard fitting that the hose from the pressure switch connects to. sometimes if you take a paper clip and **** it out. but never apply pressure or tools to the switch.
Jul 31, 2009 | Goodman Heating & Cooling
Furnace code light flashes 3 times /pressure switch stuck open
Check the intake and exhaust plumbing for any obstructions. I had same issue, turned out to be ice in the air intake plumbing on outside of house. This may be the problem. The pressure switch can be tested by pulling hose from purge motor that goes to switch and applying a small amount of suction. The switch should make a clicking sound.
Dec 19, 2008 | Kitchen Appliances - Others
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
