I have a DP50842 Sanyo LCD tv. does it have a digital tuner built in? if so how do i use it?
  • Anonymous Mar 24, 2014
    connect to android tablet
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Here are the specs, it has a digital tuner:
http://us.sanyo.com/LCD-Televisions/50-Class-49-5-Diagonal-LCD-1080p-60Hz-HDTV
If you do not have the owner manual google the model number with "manual" to try to find it.
Posted on Nov 04, 2012
SOURCE: digital tuner
Try this!
The manual states the TV is designed to search for channels.
turn the power on
then hit menu
(if it doesn't start searching for channels)
then hit channel up -let it run a complete channel search
hit menu again
hit channel up- let it run a second channel search
hit menu again after it finishes it's 2nd search cycle
if it doesn't go to a channel, hit the input button.
it worked for me!
hope it helps
Posted on Sep 24, 2008
  • 73 Answers
SOURCE: Does my Sanyo CLT1554 15 in. EDTV-Ready LCD have a digital tuner?
Your specs are here, http://reviews.cnet.com/flat-panel-tvs/sanyo-clt1554-15-lcd/4507-6482_7-32013875.html?tag=mncol;psum
unfortunately you have a
  • Analog TV Tuner NTSC
and
  • Enhanced Definition Television (EDTV) Monitor - EDTV Monitor refers to a monitor or display with the following minimum performance attributes:- Display Scanning Format: Has active vertical scanning lines of 480 progressive (480p) or higher- Aspect Ratio: None specified
You need a tv that has this:
Enhanced Definition Television (EDTV) Tuner - EDTV Tuner refers to a RF receiver with the following minimum performance attributes: - Receiver: Receives ATSC terrestrial digital transmissions and decodes all ATSC Table 3 video formats.
So Sorry, the tuner is not Digital.
Posted on Jan 05, 2009
  • 8 Answers
SOURCE: Trutech 17 LCD TV/VCR Tuner
If the TV was purchased as recently as 2007, then chances are decent that it DOES have the ATSC (digital) tuner. HOWEVER, I cannot confirm this for you on my end with the amount of information supplied. (Remember to include as much information as possible when inquiring, such as model numbers!)
HOWEVER...
If your set was sold as a "monitor", or an "HDTV READY" or "High Definition READY" set then indeed it will NOT have an ATSC tuner. If it was sold as an "HDTV" or "DTV", then it SHOULD have a digital tuner. This is based on my experience as lead TV tech at a local repair shop.
Take a look in the menus, and see what channels appear when you attempt to scan for them (assuming you are using an over-the-air antenna). Almost everywhere in the US now stations are already transmitting concurrently in digital and analog, and if you can receive the digital channels, you have a digital tuner! You can sometimes tell by the aspect ratio (widescreen, particularly on new programming, during primetime; be aware that smaller screen sizes usually are not widescreen). You can also tell if any of the channels received use a decimal or hyphen such as "channel 6.1 or 6-2" If you see this type of naming convention, you most certainly DO have a digital tuner.
Otherwise, you might consider how much you paid for the set- If it only cost you $150 brand new, or was on clearance, you probably do NOT have a digital television. Expect to pay well in excess of this amount for a digital TV. Hope this helps!! please comment with any additional ??'s and I will respond further as necessary until we know for sure what you have going on. Thanks for asking!
Posted on Jan 08, 2009
  • 6 Answers
SOURCE: Viore Remote Control Codes for Direct TV
Contact service provider ( ie Directv.) to see if they have the code or a scanning method to get it to work.
Posted on Apr 20, 2009
  • 8457 Answers
SOURCE: analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Posted on Jan 16, 2010
Is there a way to test each board individually on my tv? What could be shorting them out?
pitch this thing into the dump or get a professional to troubleshoot it, it has several bad components that are burning other things our, get out while you can.
Nov 09, 2015 | Sanyo Televison & Video
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
Dec 21, 2012 | Sanyo DP32746 32 in. LCD Television
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
Mar 04, 2011 | Sanyo 42 in. LCD TV
What are the classification of simple machune
Specifications Display Image Aspect Ratio: 16:9 Widescreen Modes: Conventional 4:3 Comb Filter: 3D digital Additional Features: V-Chip, parental control Diagonal Size: 42" - widescreen Display Format: 1080p (FullHD) Resolution: 1920 x 1080 V-Chip Control: Yes Image Contrast Ratio: 2500:1 Brightness: 500 cd/m2 TV Tuner Stereo Reception System: MTS Secondary Audio Program (SAP): Yes Analog TV Tuner: NTSC Video Features HDTV Ready: Yes Analog Video Input Signals: NTSC Input Video Formats: 1080p Remote Control Type: Remote control Audio System Sound Output Mode: Stereo Sound Effects: Virtual Dolby Digital Speakers Included: 2 speakers Additional Features: Mute button Speaker(s): 2 x right/left channel speaker - built-in Connections Connector Type: 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 ) Power Power Device: Power supply - internal Power Consumption Operational: 240 Watt General Product Type: 42" LCD TV TV Tuner: 1x analog, 1x digital Width: 41.3 in Depth: 10.2 in Height: 29.7 in Weight: 55.1 lbs HDCP Compatible: Yes Digital Television Certification: HDTV Digital TV Tuner Digital TV Tuner: ATSC, QAM Additional Specifications HDMI: Y More Information Model No.: DP42848 Shipping Weight (in pounds): 67.0 Product in Inches (L x W x H): 41.3 x 10.2 x 29.7 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Walmart No.: 000503420
hope this will be helpfull to you.
GoodLuck
Feb 02, 2011 | Sanyo 42 in. LCD TV
and
Jan 05, 2009 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Digital or not digital
this tv has no digital tuner built in to it. In order to recieve a digital broadcast the tuner must be atsc compliant. The best solution is to get a converter box to decode digital to analog signal.
Apr 03, 2008 | Televison & Video
SANYO DS31590 TELEVISION
No digital tuner inside. Will have to have a converter box in Feb 2009 for digital: Search "the fcc on digital tv transmission" on the internet for useful information on the upcoming digital age..
Dec 22, 2007 | Sanyo DS31590 31" TV
Digital tuner
Try this!
turn the power on
then hit menu
hit menu again
it worked for me!
hope it helps
Dec 08, 2007 | Sanyo Vizon LCD-15A2 Television
Televison & Video Logo
300 people viewed this question
Top Televison & Video Experts
Electro Med Services...
