Question about Maytag MEW5530D Electric Single Oven
How to turn on cleaning option older Kenmore Self Cleaning oven
We have an older model Kenmore Self Cleaning oven and don't have the instructions on how to start the cleaning operation. We don't know the year but if it helps the door has a pull down locking mechanism on the outside.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 15, 2010
How do I clean Kenmore electric range model; 36393091300 .No manual for this self cleaning range.
Hi,Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 24, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Where can i get cleaning instructions for a Kenmore model 4652591 self cleaning oven?
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
Mar 23, 2011 | Kenmore Ovens
Need cleaning instructions for tappan self-cleaning oven model number TEF351EWE
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 24, 2011 | Tappan 30IN ELEC IGNa Oven
My kenmore electric oven was put on to self clean and then immediately turned off but the oven door has remained locked. How do I unlock it?
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Dec 14, 2010 | Kenmore 49222 Electric Single Oven
My kenmore self cleaning oven , F06 error
first try to turn the breaker off and then back on and see what happens.let me know if this helps and what is the model number?
May 10, 2010 | Ovens
The self cleaning instructions for my Frigidaire Gallery Pro Series Model FEB798WCCH do not inform how long to set timer. Any instructions would be helpful as I've never operated a self cleaning oven...
Hello- The function is automatic when clean button is pushed. Oven will lock, and turn on at full power for about 90 mins. This 'feature' can, and usually does eventually burn out circuits in the control board. Techs call this the 'self-destruct' option, cheerfully promoted by the salesman. Avoid using 'self clean'!  Scrape and clean with light soap/water. Turn on to 450deg. for about 30 min. This is about half the temp. of a 900deg. 'clean' cycle and a lot less expensive in the long run. Please acknowledge this post if info is helpful- have more if needed.- Thanks- Ed
Mar 19, 2010 | Frigidaire 30 in. Electric Gallery Series...
I have an older model double oven by Kenmore - probably 15-18 years old. I was baking bread in foil three days ago and the oven set on bake 325 degrees. (I had been cooking a roast in it for several hours...
Hi.
the oven may have locked in consequence of the self cleaning cycle.
After unplugging, allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
Parts must be tested to discover the fault.
Call Kenmore at the number listed on the owners manual.
Regards.
Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Dirty self cleaning oven
easy off has a new spray for self cleaning ovens start with that after getting loose grime then self clean
Oct 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven door won't open after self cleaning
it hapen to me i activated the self cleaning gently hit the top of door and turn the self cleaner off the latch came off was able to use the oven did not used cleaner again clean it manuelly did not whant to spend the money
Jan 16, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag MEW5530D Electric Single Oven Logo
106 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
