Question about RCA F27442 27" TV
Tv F27442 my tv has no power does it have a reset button? i put a screwdriver in the little hole in the back and for 1 second i had a fuzzy picture...then NOTHING!
  • 398 Answers
The TV does not have a reset button. If you have no picture and no sound, there is something wrong with the chassis. In this case the set should be serviced by someone experienced in the RCA CTC203 chassis. If you have no picture but do have sound, then it is possible that the 2 controls in the 2 little holes in the back of the set are not adjusted correctly. This is quite possible since you said you put a screwdriver in there and got a fuzzy picture. The control on the bottom is called "screen" and is the overall brightness of the picture and the control on top is called "focus" and is the sharpness of the picture.
Posted on Aug 09, 2007
Can't put password in tablet
You will need: A clip. Open out the clip. find the tiny reset hole (see photo). Note that this is often not the tagged 'reset' button on the rear of the tablet. tablet must be be off (and a minimum of five hundredth charged) at this time. http://screencast.com/t/bm5WvA0cWIP The clip is used to activate the button in this little hole; you may hear and feel a click of the within button, in but 15mm of insertion. don`t force unduly! 1. Insert clip, till you hear the clicking of the button. Keep clip inserted, and press and hold the black power button.
2. In . ten seconds the blue PROSCAN screen will be displayed. still keep black power button on hold, and unleash clip.
3. some seconds later you may see an android 'guy' lying on his back with belly open, and a red triangle (with !) image hovering higher than his belly. unleash power button. this means we are on the point of having the ability to interrupt things. Note that once a second more or less, if no more action is taken, the tablet can shut off, then be restarted normally.
4. Press and hold power button. Insert and take away clip. you may see a screen titled android system recovery. (Note that recurrent insertion of the clip can alternate the show of the Recovery menu). unleash power button. http://screencast.com/t/TSnhaLpk2kE
5. Use clip to scroll down the list of choices. To reset the tablet, choose wipe data/factory reset. Press power button to confirm the choice. (If you go past the specified choice, carry on clicking, because the choice can scroll back to the highest once at the bottom).
6. Once reset has been designated, you`re currently at the final chance to back out or commit. All the menu things, aside from one are tagged No. To verify the reset, choose yes - delete all user data then press power button. http://screencast.com/t/0fuyMFYR
7. The wiping method starts, and after a couple of seconds will complete.
8. Menu choice bring up system currently should be highlighted. Press power button to choose.
Apr 11, 2014 | Proscan 8" Tablet with 4GB Memory
Reset password wireless34558645
On the back or side of your router, there should be a little hole that looks like it has a little button in it. You can either use the tip of a pen, a toothpick, a small screwdriver, or something like a paperclip to insert into the little hole and you should feel a button depress. Hold that button down for 30 seconds, or until the router reboots itself. This should reset the router to factory settings, and the password will either be on the back of the router on a sticker, or you'll be able to find it online by searching for your router brand and default username/password.
Dec 18, 2013 | Computers & Internet
HOW DO RESET THE DEFAULT USERNAME AND PASSWORD.
Hard to say since you didn't leave a router type, but typically:
1) get a pen (Bic pen) 2) Look for a small hole on the back of the router. This is typically the reset. 3) With the power on, put the pen in the hole and push for 30 seconds. 4) Unplug the router, wait 30 seconds, plug it back in. It should now be reset to factory.
Mar 13, 2011 | Computers & Internet
Someone help mii pleace i locked my phone its aslid and touch and just dont know what to do
You can reset your phone, but you would lose all of your music, pictures, videos, just any saved settings would be gone.
If you want to reset it.
1. Take the battery out of its compartment for 60 seconds. 2. Put the battery back in. 3. Find a little hole in your cell phone and use a small screwdriver and then press it for 10 seconds. Your phone should reset now.
Mar 01, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
The power button is gone so there is no way to turn it on. is there anyway i can turn it on with the button?
You could try using a small screwdriver pushing straight in thru the hole where the power button was. If that doesn't work, put screwdriver in hole then push down on it. The switch inside the TV could be just inside the hole or up to an inch or so inside. To prevent electric short, wrap tape around screwdriver.
If that doesn't work, unplug the TV and take the back off, slide the circuit board out far enough to see how the power switch works then go from there. The actual switch is soldered to the circuit board. The power button is only a piece of plastic that actuates the switch.
Dec 03, 2010 | RCA Televison & Video
Lost password for router and can't accsess wi-fi on my ipod touch
do a hard reset - press the little button inside the device, while unplugged and disconnected. hold with a paperclip for at least 30 seconds.
This will reestablish factory default settings
Dec 26, 2009 | Computers & Internet
I have a rca f27442 tv and the picture is half
yes!!!! very common problem. soldering the vertical section and the grounds around the tuner section will fix it. guaranteed fix. for a quick fix, take off back and while tv is on, take the plastic side of screwdriver and tap tap tap the tuner section. see i told you that would fix it.
Nov 10, 2009 | RCA F27442 27" TV
The tv powers up and displays a picture with a fuzzy square on the left hand side but the picture is fine behind it. It stay on for about 10 seconds then restarts and carrys on doing this all the time.
needs a simple reset
NO RESPOSIBILITY ACCEPTED
do this exactly
tv in stand by
press the following buttons in order
info
menu
mute
stand by
when tv comes back on
select reset
this puts tv back to factory mode
tune in etc as if a new tv
Jun 24, 2009 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Rca f27442 input button not working
REset your parental rating.
May 11, 2009 | RCA F27442 27" TV
LG 20LS7D TV
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key.
then the fly back unit is failed you need to resolder the contacts or get it serviced...............
Jun 08, 2008 | LG RE-20LA70 20 in. Analog TV LCD...
RCA F27442 27" TV Logo
91 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
