Question about Maytag CWG3100A Gas Single Oven
My oven takes about 20 minutes to preheat to 350.
I have a Maytag MER5755QAW smooth top oven/range that is about 4 years old. What would cause it to take so long to preheat. I have an a 25 year old home and had a new breaker box installed about 7 years ago.
    Sergeant:
    Champion:
  • 338 Answers
Most ovens take 15-25 min to preheat.
Posted on Jan 04, 2009
Oven won't hold temperature.
If oven is electric pleace check that the heating elements are ok, could be that only one or two elements could be the only heaters hence luck power to maintain temparature when open or gets too slow to preheat.
Aug 03, 2015 | Ovens
Westinghouse oven model WFE946SA, purchased only 4 mnths ago. No lights display
main control board,take it back,its expensive,1 year warranty
Jul 26, 2015 | Ovens
SLOW HEATING OVEN
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
anyway
14-20 mins is the industry standard for a 350 preheat...
Oct 25, 2009 | GE 30" Built-In Single Electric Wall Oven...
I have a Maytag Electric Range/Oven The Range MODEL#MER5755QAW
best guess is thermostat I believe the broiler does not need the thermo in oven.. it stays on steady hot .. thats why it still works
Mar 12, 2009 | Ovens
Preheat worksoven wont bake
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
Nov 06, 2008 | Tappan 30IN ELEC IGNa Oven
Gas oven temp problem
HI thanks for your question. there is a oven sensor , located in the oven, top left corner. replace this part. thanks the appliance doc. please rate my answer. thanks
Oct 11, 2008 | Frigidaire Ovens
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Fridgidaire stove/ove
I have a Frigidaire electric oven model # PLES389ECE. It is two years old. It has maybe 50hrs of use. I had the oven blower motor go out. Then I had a circuit board malfunction.  The repairman discovered that one of the main terminal connections was loose and caused the terminal block to short. Could this have been the problem all along? Also, we are having a problem with the oven coming up to temp. According to the operating manual, set oven temp. lets say for example  350 degrees. Once the oven is preheated to 350 a beep sounds. With my oven the oven is about 60 degrees to low. You have to wait about 10 more minutes. Is this normal with this model? Has anyone else had problems with this model? I also heard that Frigidaire made a bad batch of ranges. Could this be one of them?
Thanks, Vincent
Oct 27, 2007 | Frigidaire FGB24S5A Gas Single Oven
Maytag CWG3100A Gas Single Oven Logo
1,672 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
