Question about Acer 22" X223w LCD Monitor
Do you need to hook up both the vga and dvi cables from the monit
Do you need bothe vga and dvi hooked up to the comp.
  • mmink4248 Jan 05, 2009
    thank you very much
    Genius:
  • 2,120 Answers
No, either cable will work if you have the socket on your computer.
Posted on Jan 04, 2009
Hi i am looking for vga cable 9 Pin Female to 15 Pin Female thanks
The 9-pin port on your PC tower is NOT a video port, it is a serial data port. All VGA connectors are 15-pin. Hooking up to the 9-pin port will not get you a picture. There should be a VGA port on the PC, or else a DVI an/or HDMI port. You can get DVI-to-VGA adapters that work, but only if the DVI port is an analog DVI, not if it is a digital DVI (DVI-D or DVI-DD).
Feb 02, 2016 | LG Computers & Internet
How to hook a pc
hi just hooked up the VGA cable from your PC into the VGA port of the tv unit and then select pc in the source menu. if it is hdmi or dvi you must need a converter , like vga to dvi or dvi to hdmi etc.
Sep 18, 2012 | Hitachi 42HDF39 Television
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
How do I hook up the moniter to the CPU?
First figure out what output video the computer has. These days it can be VGA, DVI, or HDMI. Then determine what video inputs are on the monitor (same list). Then plug in the desired cable. Many monitors only come with the VGA cable. If you do not have a VGA port on the computer you would need a DVI to VGA adapter to use that cable. Otherwise buy the DVI or HDMI cable. (DVI to HDMI cables exist if you have HDMI but no DVI on the monitor and only DVI on the computer. However, you need to check your video specs closely. A Single link DVI is different than Dual-link DVI and the cables are not interchangeable.)
Once the data and power cords are plugged in, power up the monitor and then the computer. The computer should find the new hardware and install (or ask for a disc to install) the drivers.
I hope this helps.
Mar 20, 2010 | Gateway Computers & Internet
Need to hook computer up to my Hitachi projection color t.v.
You need a VGA to DVI cable. You can get one that is 6 feet long at TigerDirect here. If you need a longer cable you can get a VGA to DVI adapter instead and buy a really long VGA cable if you need more cable length. Click here to browse both.
Mar 21, 2009 | Hitachi 46F510 46" Projection HDTV
Problem hooking my macbook to the Powerlite 62c/82c the projector
For these types of projectors if you're planning to hook it up using you MacBook ;
You will need a converter ( from VGA to DVI )
Using the VGA cable that came with the unit when purchased ;
Connect the VGA cable on the back of the Projector and on the other of the cable you will connect the converter ( VGA TO DVI ) since for MAC systems it has DVI ports for monitors not VGA...
You can purchase the converter at any Mac store or any computer shop near you..
Mar 13, 2009 | Epson PowerLite 62c Multimedia Projector
Radeon R9600/XT GRAPHICS CARD
Yes, they both will act independently if you choose to use it that way or they will show the same picture, one is a DVI output and the other is VGA. Use the ATI’s CATALYST software suite provides the ultimate software required to enjoy the full acceleration of your ATI Graphics Accelerator card. You can use it to separate your Primary video from your Secondary video.
Jan 03, 2009 | Abit R9600XT-VIO RADEON 9600 XT, (256 Mb)...
What dvi cable do i need?
Any bog standard dvi cable should work. As should a dvi to vga converter. Dvi is by far the better interface, and I would highly recommend using it, without any converters. I don't believe you can up convert vga to dvi, but you can certainly downgrade a dvi signal to vga, but i can't see why you would want to...
Oct 17, 2008 | Computers & Internet
Acer 22" X223w LCD Monitor Logo
137 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
