Question about Hammering
No spark in my 7hp Briggs and Stratton engine
  • 83 Answers
SOURCE: removal of flywheel from briggs and stratton 4 cycle engine 3 hp
Without the $100 flywheel remover that briggs will happily sell you you can do the following.
First you will need another body to help, two if available
2 pry bars or large screwdrivers
A air hammer if you have it or a large hammer if not
Loosen the flywheel nut until it backed off til the nut is just barely one thread or even with the shaft. Now put your pry bars behind the flywheel on opposite sides. Have someone provide constant pressure (don't be too forceful the block is made of aluminum and can be damaged). Now hit the end of the shaft with a hammer or air hammer (the nut is protecting the shaft threads) with medium power. With a few careful hits the flywheel should pop right off.
If you run into trouble or are unsure of something in this proceedure please ask.
Posted on Mar 30, 2009
extroitive
  • 35 Answers
SOURCE: briggs & stratton 3 hp engine will not start
likely needs a carb kit
Posted on Apr 19, 2009
  • 15 Answers
SOURCE: cant get a spark on my briggs and stratton 4hp engine, trying to
gap from coil to flywheel is .010. if you've replaced coil, points and condenser with no spark i would try replacing the coil and points with an magnetron kit or a coil that allows for the elimination of points.
Posted on Apr 23, 2009
panilling9
  • 284 Answers
SOURCE: gap setting for champion RJ19LM spark plug 3.5
plug gap setting is .030
Posted on Jun 10, 2009
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
Briggs and Stratton 17 HP Riding Mower
Hi Lawrence.
There should be a few more numbers/ letters to your model number. I added a link to a website for you to check out. Click the link or copy and paste it. Hope this helps.
https://www.repairclinic.com/Shop-For-Parts/a22b303d782009/Model-42A7072653E1-Briggs-Stratton-Small-Engine-Parts
May 30, 2017 | Briggs & Stratton Garden
Spark plug gap
How to Gap a Spark Plug - YouTube
? 2:57
https://www.youtube.com/watch?v=IuW3svdqKZM
Oct 15, 2012 - Uploaded by ChrisFix
How to correctly gap a spark plug. This is a fast and easy video on how to gap a spark plug and spark plug gap ...
FAQ: Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonFollow this step-by-step image guide to locate spark plugs in different Briggs & Stratton engine types. ... Spark Plug Type & Gap Chart for Briggs & Stratton Engines. Now that you've found the part you'd like to replace, you can use the chart below to identify the genuine Briggs & ...
Spark Plug Gap - AutoZone
Dec 15, 2015 | Cars & Trucks
What is the characteristics of a blown engine on a Briggs & Stratton 7HP I/C Engine
any noise when cranking or running . easy to turn over little or no compression. blue smoke from exhaust.
Oct 02, 2014 | Garden
BRIGGS AND STRATTON 550 SERIES
Identifying the Correct Spark Plug and Gap
What is the correct spark plug and gap for my engine?
Due to the variety of engine and equipment configurations, your best source for spark plug information is your engine or equipment Operator's Manual. However, the following general guidelines will get you pointed in the right direction.
This guide provides the common spark plug part numbers used in our L-Head and Overhead Valve engines. For information regarding the service/replacement of spark plugs, please visit our Servicing the spark plug FAQ. Please be aware that the size/shape of the spark plug varies depending on engine design.
Briggs & Stratton L-Head Engines
(also referred to as Flat Head or Side Valve Engines)
Sep 29, 2014 | Briggs & Stratton Garden
18 hp briggs and stratton no spark
unplug oil senso still no spark un \plug shutoff wire to coil still no spark replace coil
Nov 15, 2012 | Briggs & Stratton Briggs Stratton Intek V...
We cannot locate the manual for our Mighty Mac Chipper/Shredder, 7hp Briggs & Stratton motor. Can you either send a copy in the mail or by Email at jc_marriott@yahoo.ca? MIGHTY MAC CHIPPER/SHREDDER,...
Don't know where you can get a manual, you never stated the model number, but you could contact the factory and talk with an engineer about whatever problems your having. (There are also parts still available for these older fellas).
http://mackissic.com/Tech%20Support.html
Jun 16, 2017 | Garden
I AM REPAIRING A SNAPPER COMET 30 B/S 7HP RIDING MOWER: (APX. 1966-1969) 1) TIRE PRESSURE? FRONT-410/350-4, REAR-16 X 6.50-8 2) WHICH FRONT BELT PULLEY DO I LOOSEN TO ADJUST OR REPLACE BELT? 3) REAR AXLE...
Chances are you wont get a manual, just lube it up.tires probably 12 to 15 lbs .the belt is mecanicly tensioned so there is no adjustment. Check the idler pully tensoner and ingage lever for proper travel and tention
Jun 03, 2010 | Briggs & Stratton Garden
I have the exact same problem on my 7hp briggs for a genny
Your carburetor is dirty. Need to be take apart and cleaned with carburetor cleaner.
Oct 06, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Hammering Logo
163 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
