Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Erreur code E000051-0001
Need help for canon IR 6800c with error code E000051-0001
SOURCE: Canon IR 8500 Error code E000069-0000
You have a high-voltage leak to the transfer corona. This could be due to several different things, usually it's a dirty corona, maybe excessive dust or toner in the corona assembly. Toner conducts electricity and can leak voltage from the transfer corona to the frame. It may also be the "end-blocks," the thing in the back of the machine into which the transfer corona plugs when you close the drawer and lift up on the green handle. These crack and can cause intermittant failure.
I would start by taking a can of air and thoroughly blowing out the corona assembly and see what that does for you...
Posted on Aug 05, 2008
  • 199 Answers
SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Posted on Feb 26, 2009
SOURCE: Canon IR C3200 Error Code E000020-03C0?
plz tell me reason of e602 code in canon ir c3200
Posted on Nov 20, 2009
SOURCE: Canon IR3300 showing the error code E000602-0003
ERROR CODE E000602-0003 what i do
Posted on Feb 08, 2010
canontech
  • 1219 Answers
SOURCE: error code E000002-0000
Get in the service mode *28* and there under function, clear, err.
If not replace the fixing film unit
Posted on Mar 03, 2010
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
How to resolve erreur code E000051-0000 whith canon ir 2800
the Canon E500 printer is one of the most advanced printer which is build upon the latest printing technology. The printer comes in medium-size device and is reasonably light weight of around 5.3 kg. The black plastic body has no sharp edges, and the design is fairly pleasant to appear. The trays of the Canon printer Pixma E500 are quite flexible to use according to Canon Pixma E500 Printer Supportprofessionals. Its glossy finished touched feature makes the printer most eye-striking among users. But here in this blog, we will be introducing you guys with various Canon Pixma E500 error codes that you need to know.
List of top Canon Pixma error E500 codes
Error code 1: Canon E500 Error Code E02 (E,0,2)
  • This error symbolizes that printer is out of paper or is incapable of feeding any document.
Error code 2: Canon E500 Error Code E03 (E,0,3)
  • This error signifies the Paper Jam.
Error code 3: Canon E500 Error Code E04 (E,0,4)
  • The error signifies that the "fine cartridge" is not installed accurately.
Error code 4: Canon E500 Error Code E06 (E,0,6)
  • As stated by Canon Pixma E500 Printer Technical Support experts, the paper output cover is not in a closed state.
Error code 5: Canon E500 Error Code E07 (E,0,7)
  • The ink absorber is complete and users need to reset the counter.
Error code 6: Canon E500 Error Code E08 (E,0,8)
  • Here the error signifies that the ink absorber is almost in a full stage. Users are then required to press the "black or color" button to resume it in a proper.
Error code 7: Canon E500 Error Code E16 (E,1,6)
  • The ink in completely finished as of now. You are required to tap on the "Stop/Reset" button to resume the printing process.
Error code 8: Canon E500 Error Code E17 (E,1,7)
  • The front tray is totally closed.
Error code 9: Canon E500 Error Code E30 (E,3,0)
  • The error code defines that the size of the original cannot be accurately detected or even it is possible that the document is too small when the "Fit-to-Page copying" is selected.
Error code 10: Canon E500 Error Code E31 (E,3,1)
  • The machine is surely disconnected with the computer.
Error code11: Canon E500 Error Code E40 (E,4,0)
  • It shows that the protective material of the Canon Pixma E500 printer for the FINE cartridge or the tape is still attached.
Error code 12: Canon E500 Error Code E50 (E,5,0)
  • Scanning of the print-head alignment sheet has failed to function
Error code 13: Canon E500 Error Code P02 (P,0,2).
  • This is a critical error which shows that the printer is in malfunctioning stage.
Error code 14: Canon E500 Error Code P10 (P,1,0).
  • This error signifies that the mechanical printer is in total malfunction stage.
So, these are few topmost errors of Canon Pixma E500 printer that users need to be aware of. Our professional team of Canon Pixma E500 Printer Support experts is always available for you to help overcome with any kind of unexpected issues. Call us or even you may drop us an email to our professional email ID.
May 16, 2015 | Canon IR-2800 Copier Reconditioned
This is a side registration error.
Most likely the motor has failed, the small gear cracks.
This is the part you need.
FH6-1253-000
May 16, 2015 | Canon IR 2800 Digital Copier RECONDITIONED
CAnon xerox Machine IR 2318 L Error code : E 000007-0000
My canon ir 2318L shows error**E000007-0000 how can i solve this problem
Feb 28, 2011 | Office Equipment & Supplies
Code erreur system E246 E354 canon IR1600 problem:
CANON IR 1600 ERR CODE 354 IT CAME AFTER REPLACING
MAIN BOARD HOW CAN I CORRECT THIS PROBLEM
Dec 27, 2010 | Office Equipment & Supplies
Canon iR 3100CN Error code E000732-0001
E732 Reader communication error
0001 DDI-S communication error Check on connection between the reader controller PCB and the main controller PCB, Check on the
reader power supply
Hope that helped!
Jul 25, 2010 | Canon iRC3100 Printer
Computers & Internet Logo
154 people viewed this question
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
