Question about Vacuums
Nilfisk alto c120-2 leaking inside - Vacuums
Hi I have a nilfisk alto that has not been working properly. It has not been spraying the water
Alto nilfisk vaccuum is not spraying water , a highpressure washer do you mean not a vaccuum .
But If it's an alto nilfisk blue pressure washer on the vaccuums topic it must be the bypass / autostop on the pumphouse its internally a point where a microswitch is placed and depends on the type of washer by a problem with the parbak ( a parbak is a oring/ with auxiliary kevlar ring(s)) that can hang on lime, but on an other model there are 2 springs on the bypass and one of them the great spring is broken or only hanging on lime but thats rare if it is.
I don't know if there are vaccuums with water spraying only for remove dust.
Feb 15, 2017 | Nilfisk Vacuums
Change front wheel on x300
The front wheel on a Nilfisk Extreme 300 is changed by removing the 3 screws inside the bag chamber. From memory they are a torx screw driver size 15 or 20. Basically remove the bag and take out the 3 screws in the middle of the chamber - the wheel will fall off once you lift the machine up. If you need to buy a replacement wheel you can find one here.
Nov 10, 2013 | Nilfisk 11730410 Micro Filter Polyester,...
Fault Nilfisk Alto pressure washer
see the diagram and repair swtich:
May 14, 2012 | Vacuums
I need a small plastic part which controls air pressure in the Nilfisk Alto attix Vacuum cleaner
Fixya does not sell replacement air pressure controllers and cannot recommend sources.
Jul 24, 2017 | Nilfisk Vacuums
Hi my nilfisk alto e140.1 has just cut out i have changed the fuse its not that could someone please help because i have borrowed it off a friend :( helen....
Hi Helen,
I checked the owners manual. Here are some things you can check:
The thermal sensor has shut it down. The manual says to let it cool down for 5 plus minutes, then try it again. I imagine you've tried that already, so ....
The nozzle could be partially blocked. The nozzle MUST be detached in order to clean it. Use something as long as the nozzle, like a stiff wire or needle like object, to clear it. Then flush it backwards with water.
Since the fuse blew, try the machine without the extensions hose or use a little higher rated fuse or both.
The pump/spray gun is leaking.
If none of these works, please reply back.
I hope this does work. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 06, 2011 | Nilfisk 350-01 Wet Washer
Do alto clarke have a supplier in Australia for vacuum cleaner parts? D T V 7 Thankyou
HI there Vacuum Guru here from VacuumSpot.com.au. Most alto clarke share the same parts as a Nilfisk Alto. We are an agent for these machines. If you use the email link on our site and let us know which model you have we should be able to get you any parts you need.
Oct 14, 2010 | Alto 302000405 Attix 8 Canister Wet/Dry...
Not working,need assistance from anybody or cheap parts.thanks
sounds like the trigger switch is stuck.try to spray a little wd40 up into the switch and work it ,maybe it will free up.if not the switch is probably bad
Apr 29, 2009 | Vacuums
Got a WAP wet and dry and the bag inside has split
Check with www.industrialvacs.com. They sell bags and filters for all Wap vacuums, including old ones. They also sell new Wap/Alto/Attix vacuums. The company is now a division of Nilfisk, from Denmark. If they don't have it, check with www.ultimategarage.com. They are also a stocking dealer for Wap.Good luck.
Mar 16, 2009 | Wap 28538 Wet/Dry Vacuum
Need filter
Check with www.ultimategarage.com or www.industrialvacs.com. They are both stocking dealers for Wap/Alto/Attix vacuums, now a part of Nilfisk of Denmark. Good luck
Mar 03, 2009 | Wap 28538 Wet/Dry Vacuum
When vacuuming dust does not go into bag but goes all over the place.
Used an elastic band to tighten bag onto nozzel.
Sep 27, 2008 | Nilfisk Vacuums
Vacuums Logo
110 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
