Question about Music
How to replace battery on Digitech rp2000 - Music
2 Suggested Answers
  • 5603 Answers
SOURCE: Can a keyboard synthesizer play thru the DigiTech
The short answer is NO. The MIDI connection does NOT carry audio, only commands. You must connect synth audio outputs to the inputs of the RP2000 and use the audio coming out of the RP2000 to have the effects.
Posted on Sep 24, 2009
Digitech 256 manual
This manual is Not available, The 256xl is ? I think if you contact the company they can help you, I have contacted them in the past threw this link.... http://digitech.com/en-US/support
Feb 22, 2015 | DIGITECH Music
My digitech looper phrase sampler will not turn on
A common problem is that somebody has paired the WRONG power adapter to this unit.
The REQUIRED adapter should be 9VAC (not DC) at 1300ma or 1.3 amps.
Note that UNIVERSAL replacement adapters will NOT work with the Vocalist.
Feb 06, 2011 | Digi-Tech Digitech Vocalist Live 4...
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
I NEED TAN ELECTRONIC SCHEMATIC
Here is a link to the manual:ftp://ftp.digitech.com/pub/PDFs/Manuals/RP1000/RP1000%20manual%2018-0597-A.pdf It is highly unlikely that you will find a schematic unless you know a service tech for a music store that deals Digitech. Also you will need some specialized tools. Here is their contact info:http://www.digitech.com/dealers/service_lookup.php If you are a tech you can always contact them.
Apr 07, 2010 | Music
Replacement encoder pot for a Digitech Vocalist VR rack unit?
Digikey.com and Mouser.com have encoders.
Their online catalog should help you find a replacement. Analyze how many detents it has AND the circuit board layout and number of pins.
DO NOT be surprised if you have to shorten the shaft to match the original one.
Jan 06, 2010 | Music
Can a keyboard synthesizer play thru the DigiTech RP2000 to receive the effects by connecting to the midi in?
Sep 24, 2009 | Digi-Tech Music
Rp2000, mdsper error
If you have ever tried to research this error message and found that there is no real answer to this, it is because "mdsper" is a general error message that can be the result of a few things. It seems to be a senseless thing to do until you realize that if you were Digitech, this would be a boon to your service department when these things go out of warranty.
Most commonly, it can show up if the internal battery needs to be replaced. As you know there is an internal battery in order to store patches in memory. Well, these things tend have (in my experience) a life of between 3-8 years, but can last longer if the pedal isn't used much.
It could also be that a power surge could have knocked out the memory in the main chip, rendering the pedal completely useless.
Another common situation is that many people use a non-factory power supply (wall wart) and often it may have the correct voltage, but not the correct MaH. This mismatch can blow out the unit if too high, or cause the unit to malfunction, if too low.
You should also know that some people continue to do the factory reset procedure until it "takes". So sometimes continuing to try the reset procedure could lead to success. You may wish to try and reset it quite a few more times (maybe 20?), then, if you have the correct power supply and are sure that is not the problem, you may wish to switch the internal battery yourself. Apparently it is an easy replacement. The one thing i do not know is the battery information and where to obtain it aside from going directly to Digitech. I am confident you could find it cheaper through another source. Good luck. Hope this helps.
Jul 12, 2009 | Digi-Tech Digitech Vocalist Live 4...
Music Logo
211 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
