Question about Toys
My rc helicopter br6008 v-max rotate right side
Rc helicopter rotate on side and cann't stop
SOURCE: will not stop spinnig to the left
The heli will do that if you hover less than 1meter from the floor ! or you may need to adjust the swash plate screws Look at them very carefully and draw a diagram if you remove a screw and replace screw into another hole , in case you want to put it back as it was?,Also remove two of those little [8]shaped hooks that tie the blades to the main shaft. Remove one from the top A set of blades and one from the Lower B set of blades You dont need to have all four connected at once.If you click on this link http://www.maplin.co.uk/Media/PDFs/N32FR%20manual.pdf it has the complete operating manual of your apache model in Pdf form (U Will need to download Adobe reader)
Posted on Jan 26, 2010
jyackle5
  • 8197 Answers
SOURCE: Building a RC helicopter for college
You might want to get on google and search how to build Remote Control Helicopter. you will find a lot of useful info. If you have never flown a RC heli thought I suggest you get a sim for the computer. I have been flying now for 10 years and they are not that easy to fly. I still have problems and always am learning some thing new. here is one link to look at.
http://www.angelfire.com/blues/heli_project/
Posted on Jan 30, 2010
micromend
  • 748 Answers
SOURCE: my rc helicopter can not fly it spin in floor
Hi
This type of helicopter uses a fixed pitch blade. Have you recently replaced one or all the blades? If the blades are correctly positioned then once the motor comes to speed, the pitch of the blade creates enough lift to overcome the force of gravity. The problem you're having can only be that the motor is not coming to speed or the blades have been replaced but the pitch is now at the wrong angle.
Posted on May 13, 2010
  • 906 Answers
SOURCE: find charger for world tech rc helicopter skyhawk
good day,
hope this link below will help tp solve your problem.
toys
Posted on Jul 29, 2010
Don3542
SOURCE: My helicopter won't take off,
This issue is the "Drive Gear Unit" It is the small gear just above the motors which is attached to the very large gear. You will have seen several posts indicating that sometimes this gear shifts and does not engage the larger gear. In my case I looked and say that it was indeed trying to engage the larger gear, however the gear is stripped (the teeth are nearly gone). The sound that you are hearing is the sound of the gear slipping against the Bigger gear. I have a UJ365 which is a newer model. To my disappointment I cannot find a "Drive Gear Unit" anywhere on line. The copter will not function without it. This issue is that it takes the lift of both rotors to lift the copter into the air. There are two motors (one for each rotor) and each motor has one of these drive gear units. Each of these attach to the larger gears which turn the rotors. The rotors each turn in the opposite direction. This is what keeps the copter from continually turning in one direction. When one of the "main Gear Units" becomes damaged it seems to have three noticeable effects. (1) There is a noise that is the gear grinding against the bigger gear. (2) Because many of the teeth are stripped the drive gear engages the bigger bear only some of the time, this causes the rotor to turn slower and in-turn causes there not to be enough lift from the rotors to lift the copter. And finally (3), someone noted that copter wants to spin in one direction. Understanding the above, you can now understand that if one of the rotors is not reaching its full potential to turn, it is also not reaching its full potential to counter act the other fully functioning rotor. Thus the fully functioning rotor is forcing the copter to spin in its direction and the malfunctioning rotor is not spinning fast enough to stop the spin.
So this is the answer to your questions, hopefully on the older models there will be parts available for you to replace it. The copter cannot work until the part is replaced.
Posted on Jul 11, 2011
I have a rc helicopter with gyro and can't get it off the ground. Any suggestions?
You need to adjust the trim controls........look through the instructions!
May 29, 2016 | RC Toys
Tail rotor blade is bent and helicopter wont fly forward or backwards
Fixing Your RC Helicopter - The Basics + Tips / Tricks ...
? 3:26
https://www.youtube.com/watch?v=Gxst73zE0VY
Jan 16, 2011 - Uploaded by Live2Fly94
i have a heli and the tail rotor will spin right but not left .... im having problems with my silverlit nano copter the tail ...
Frequently Asked Questions - RC Helicopter Wiki
www.rcheliwiki.com/Frequently_Asked_Questions
Probably the best way to learn to fly is to find a group of like minded people locally and ask their advice. ... The tail rotor should rotate so that the blades come 'up' towards the front of the heli. ... My helicopter won't stop spinning! ... still flying awesome but now tail vibrate and it issues backward forward. what should i do ?
Dec 28, 2015 | Toys
I have an eagle rc helicopter . It's motor cuts off just halfway as I push the throttle up and it's blades stop rotating.what to do.?
sounds like a bad controller. but do the blades start back up if you bring the control back below that point? if they do you defiantly have a bad control.
Dec 30, 2014 | RC Exceed Rc Eagle Helicopter Replacement...
Helicopter swerves right at speed
Hang it from a sting attached to the rotor shaft and see if it hangs level. It sounds to me like it is off balance.
Mar 07, 2014 | WL Toys WL V912 MAX 4CH FP RC Helicopter...
Gyropter RC helicopter replacement parts
Replacement parts can be found on amazon, take a look: Amazon com Gyropter RC parts. I hope this was helpful. cheers
Jan 26, 2013 | JCPenney Gyropter RC Helicopter
No power
Check the channels and make sure your on the right channel A / B usually..
give the blades a gentle turn with your fingers, they stick sometimes.
Dec 28, 2012 | FocalPrice BR6008 3.5-channel Infrared...
Cant find potentiometer screw to adjust for counter clockwise over rotation on my iwave dragonfly helicopter
The Potentiometer screw is there, right underneath the orange label for the On\Off switch. Your cockpit housing, (read the red bubble) is removable by gently pulling the housing off the posts on either side at the bottom rear.
Removing the housing is also a great aid to reach the connections easily when you need to recharge the battery pack.
Dec 25, 2010 | Jumbo RC JUMBO HELICOPTER
Heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Apr 10, 2009 | Max Heli- Axe CX Micro Electric Rc Mini...
Toys Logo
360 people viewed this question
Top Toys Experts
Tom Chichester
Are you a Toy Expert? Answer questions, earn points and help others
