Question about Saws
Changing the blade on a stayer table saw s c 391
Changing the blabe
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
efs_perpends
  • 1996 Answers
SOURCE: Table Saw Blade Won't Cut Straight
Inside the saw, on the end of the trunnion is a stop that is adjustable to zero the saw in to exactly 90 degrees. Either there is sawdust or something accumulated there or it needs to be adjusted. You say you cleaned it out, So you'll need to unplug it an have a look up in there. See how there's a geared piece of steel that moves when you crank the saw over to 45 degrees. Usually there's a bolt or stud with a locking nut on it, either on the trunnion itself or the lower surface of the table top. You need to break the nut loose and screw the bolt in or out to adjust, then crank the saw over to hit it, check for square with a known square, crank it all the way out of the way and readjust, etc. Until you get it right. Make sure to tighten that lock nut when you're done.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
  • 59 Answers
SOURCE: old craftsman table saw parts?
most sears stores have a dept. that refurbishes and sells these tools. if it can be had, they can help.
Posted on Apr 25, 2009
  • 384 Answers
SOURCE: key switch on Craftsman table saw
Switch is filled with sawdust. Disassemble and clean out.
Posted on Sep 14, 2009
SOURCE: How do I change the blade on my Ryobi 10" table saw?
The manual is posted on line. Changing the blade does not require turning the saw over, blocks of wood or vice grips. The advice listed above is potentially damaging to your equipment.
http://www.raygirling.com/ryobi/ryobi.htm#settadj
Posted on Sep 24, 2009
New to table saw use, have my husbands old 10 craftsman, was learning to rip with it doing fine, then it started to bog down during cut until the blades stops, moving. put on a new blade and noticed...
If I understood correctly, you started using your husband's table saw and while ripping boards, you managed to stall out the blade AND motor?! If that's the case, you probably have a very dull blade and are binding your board on the blade. Neither is safe and it sounds like trouble is brewing.
First and foremost, get someone to show you how to safely and properly use and adjust the saw if you are new to wood working and power tools. That saw is capable of turning your lumber into a high speed missal if you do things improperly.
It also sounds like you tried installing a new 10" saw blade. Changing the blade requires 2 wrenches. One to hold the arbor and one to tighten the nut. The blade itself should rest on the arbor between two large washers. Also make sure you install the blade so the front face of the cutter teeth face you and rotate toward you. Make sure the saw is unplugged when changing the blade and never turn on your saw with a loose blade.
Oct 20, 2013 | Craftsman 10" Table Saw
Mastercraft 2 in 1 flip over saw only works on one side
You have a safety lock as the table turns to table saw with an open blade.if you don't hear the click or one of the wires on the locking mechanism have come loose it will not function. Used to have one but I wore the motor out - best portable saw I have owned and I own a lot of high end saws.if anyone has a flip saw for sale let me know - pipeline@nucleus.com.
May 31, 2013 | Saws
I've borrowed a circular saw (v old B+D 1 HP model). Can't loosen spindle bolt to remove blade: the blade is locked with a pair of locking pliers against the guard, but when I turn the spindle bolt...
you just have to look for little button close to blade, smash it, hold it while you move the blabe till gets stuck then you're ready to loose the blade! hope this help
Jul 24, 2011 | Saws
Have a 10''band saw with 254mm blabe need to no the size of blade to replace / alum blade glide so i can replace montgomery ward 10''band saw belt drive
Your 10 inch saw takes a 59 inch blade, I think, it will say on the package if you buy from lowes or home depot, no matter what the thickness is, 1/8, 1/4, 3/8, You don't want to go any bigger than that. The belt for the drive is just a v-belt, measure the old one or get the number off it, or just measure the distance around the pulleys. Hope this helps.
Mar 01, 2010 | Saws
How to change the blade? We have one wrench, but you need two correct? Where can I buy the wrench if I need one?
Well I use a wrench on the bolt and a screw driver in the teeth against
the table to stop the blade from turning.
You could also use a vise-grip to hold the blade, just be careful if you have carbide teeth so you don't break one.
Some saws have a blade lock on the motor, I don't know about yours.
I find it best to lower the blade so its just above the table so it can be held, and the bolt is out of the way of the table.
Feb 11, 2010 | Black & Decker BDTS200 15-Amp Table Saw...
I would like to purchase a copy of the Owners Manual Stayer TF84
Customer service E-mail: info@grupostayer.com Telf: +34 91 691 86 30 Fax: +34 91 691 86 31
Jan 11, 2010 | Saws
Craftsman model 708100 table saw tilt lock won't stay locked
Try removing the lock knob and putting a toothed lockwasher on the shaft. reinstall the knob.
Dec 11, 2009 | Craftsman 10" Table Saw
Instructions on how to change out a 10'' blade on a Central Macinery Model 38533 table saw?
table saws usually don't have shaft locks... i either use a piece of wood to hold the blade or a c-clamp. crank the blade all the way up, remove the plate surrounding the blade and put a wrench on the nut,,, hint it is a left handed threading so... its counterclockwise tightens and clockwise loosens.... ps unplug it
Nov 17, 2009 | Saws
How to change blade;where is button to hold blade from moveing
There is no button to lock the arbor on a table saw. One method is to take a piece of wood, about 1" x 1 1/2" x 16" long, rest it against the back or front of the table throat and lever it against the blade, holding the blade from spinning while you use the wrench to loosen the nut on the arbor.
Make sure you first unplug the saw before changing the blade. Lever against other end of throat while tightening.
Apr 04, 2009 | Craftsman 10" Table Saw
Jan 20, 2009 | Craftsman 10" Table Saw
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
