Question about Powerglide Power Glide Cordless Drill
Where do I get a charger for my 12v power glide drill. Mine s--- the bed?
The charger just quit charging, I think the power converter wentout, I have no light to indicate that it is working even with the battery in the charger.
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: Need to replace charger (NO.
Hi and welcome to FixYa, I am Kelly.
You can order it on line here: ($10.19)
http://www.acehardwareoutlet.com/productDetails.aspx?SKU=2105054
Thanks for choosing FixYa,
Kelly
Posted on May 05, 2011
Mine has broken where can I get a replacement
All About Battery Chargers - Battery University
batteryuniversity.com/learn/article/all_about_chargers
Battery UniversityOct 16, 2015 - Figure 1: Battery and charger must go together like horse and carriage.... charge time but there are limitations as to how fast a battery can be charged. .....There are universal lithium chargers available but these only charge at .... i want acharger to charge my lead acid batteries(12V-26Ah) within 6hours.
[PDF]Energizer Rechargeable Batteries and Chargers: Frequently ...
data.energizer.com/PDFs/Rechargeable_FAQ.pdf
Can I use another manufacturer's charger to charge my Energizer® NiMH Rechargeable batteries? 18. ... 22 Why are rechargeable batteries 1 2 Volts? 22. ...When not in use, nickel metal hydride batteries will lose 20% to 50% of their chargewithin six months due to ... Energizer offers several universal voltage chargers.
Dec 02, 2015 | Drills
Dewalt 30 Minute Fast Charger does it work in uk 230v
Some battery can not be charged by fast charger, because this can damage the battery. You can think to replace it to a new charger, a 7.2V 9.6V 12V 14.4V 18V NI-CD NI-MH BATTERY charger for Dewalt
Jun 22, 2014 | Drills
Black & Decker Cordless Drill will not charge battery
Either the charging adapter is faulty or the battery is worn out.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jun 03, 2012 | Black & Decker Black and Decker 18V...
What is the polarity of a 12v Black & Decker Drill?
centre pin on plug socket is usually positive...
think I would **** it and see ....if the replacement charger has a charge light it will probably not light if you have reversed polarity. Had the same problem with VHF portables ...I just cut the wire on new charger and tried both options ..reconnected and a bit of tape...voila.
There is little danger to your drill from getting it wrong as long as a the timing is relatively short.
May 29, 2012 | Black & Decker Drills
Blowing the fuse when trying to charge
I would think that a circuit is bad in the charger. Have you tried another battery?
Jan 29, 2012 | Ryobi Drills
Charger doesn't charge anymore
If you are comfortable with removing the upper half of the housing, unplug charger and remove the screws, take a look at the circiut board for a "cold" solder joint or broken component, usually the round ceramic looking piece with the copper wire around it. but look at the whole board.
Jun 30, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Charger broke
common problem, go here
http://mrclm.blogspot.com/2009/09/black-decker-18v-firestorm-drill.html
May 14, 2010 | Black & Decker 18V Cordless Drill/Driver
Batterys dont keep there charge i think the batterys need to be replaced
before you dump those batteries, check the charger. If the battery when charged runs the tool but dies out quickly then you are probably right. If the battery never seems to be charged at all, then it may be the charger.
Dec 10, 2009 | Hitachi DS14DVF3 14.4 Volt Ni Cad 3/8 Inch...
Case Needed for Power Glide 60101325 Cordless
A roll of duck tape wrap around the case will work quite nicely.
Jul 21, 2009 | Ryobi Multi-Volt Battery Charger
Powerglide Power Glide Cordless Drill Logo
Top Powerglide Drills Experts
Are you a Powerglide Drill Expert? Answer questions, earn points and help others
