Question about HP Photosmart C6180 All-In-One InkJet Printer
Poner la tinta al printer
Como puedo poner la tinta hacia el printer
5 Suggested Answers
SOURCE: Error al instalar driver de scanner HP Deskjet F380
hi dear
i need ho deskjet f380 All in one
thanks
Posted on Sep 23, 2008
pineworks
  • 4041 Answers
SOURCE: error 0xc18a0206 de hp d7100
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Posted on Jan 25, 2010
pineworks
  • 4041 Answers
SOURCE: PRINTER ERROR 0XC8A0001
Hi
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Please come back and just gave a vote
Posted on Feb 13, 2010
puertobori
  • 7725 Answers
SOURCE: En el display me muestra el error "Atasco
Trata este link en ingles pero facil de entender.
Posted on Oct 22, 2010
puertobori
  • 7725 Answers
SOURCE: como puedo conectar la printer si mi disco
Ve a este enlace y consigue el modelo y tu sistema operativo,baja el driver y luego de bajarlo habre la aplicacion y sigue las instrucciones.
Si necesitas mas informacion escribe o postea luego.
Posted on Nov 27, 2010
ES IMPRESORA Y SCANNER. NO PUEDO USARLA SOLO COMO SCANNER AUNQUE NO TENGA TINTA????
Muchos de los lectores tienen una funci?n de copia que utiliza la impresora . Usted puede ser capaz de comprar cartuchos de tinta para que o tal vez rellenado de los cartuchos de tinta si el coste es un problema. Creo que ser?a necesario de tinta para poder utilizar el esc?ner debido a la funci?n de copia.
Dec 31, 2014 | Office Equipment & Supplies
Como aser para recetar chip de la T430
1. entra el menu de CONFIG de la impresora. Para hacer esto:
1. enchufa de la impresora.
2. con la impresora enchufada lejos, aprieta y sujeta tanto el boton Selecto como el Regreso abotonan.
3. al mantener ambos estos botones presionaron, enchufan la impresora atras en.
4. cuando la pantalla de impresora dice que MENU de CONFIG o Principal Valor de Cnt, suelte los botones.
2. aprieta el bot?n de Menu de flecha hacia la derecha hasta que vea Repone Maint Cnt (o Repuso Maint a Conde) como una elecci?n.
3. aprieta el boton Selecto una vez. Debe ver Repone Maint Cnt en la l?nea primera y = Repuso en la segunda l?nea de la pantalla de impresora.
4. prensa Selecciona otra vez. Esto repondra al conde de mantenimiento para poner a cero.
5. salir el men? de CONFIG, aprieta el Regreso hasta que regrese en el principal menu.
6. aprieta la izquierda o boton de Menu de flecha de derecha hasta que vea la Salida Config Menu como una eleccion.
7. prensa Selecciona. Esto debe guardar que poniendo y vuelve la impresora al modo Listo. La NOTA: Si usted se pierde durante cualquiera de estos pasos, apriete el boton del Regreso para volver al principal menu. Hacer esto no cambiara ningun ajustes. Alternativamente, puede enchufar lejos la impresora por unos pocos segundos y comenzar otra vez.
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
Feb 18, 2011 | Lexmark T430 Laser Printer
Se desplaza la cinta de de tinta al imprimir
frubioa: En el soporte de la cinta hay dos peque?as laminitas que mantienen fija la cinta, si estan muy dobladas hacia adentro, no sujetaran el rollo de cinta. Puedes levantar esas laminitas para ajustar el rollo.
Roberto Martinez
padrino99@prodigy.net.mx
Jan 13, 2011 | Zebra Z4Mplus Label Printer
MARCA ERROR 0xc18a0506 TRAE TINTAS NUEVAS :s
: Realice por favor el debajo de pasos: : 2. Apriete y suelte el bot?n de flecha hacia la derecha hasta que la presentaci?n diga "Men? de Configuraci?n de Sistema". 3. Apriete y suelte el bot?n "bueno". 4. La presentaci?n debe decir "estatus de fracaso de Hardware". Si no all? ya, Llave de Flecha sobre a "estatus de fracaso de Hardware
: 5. Apriete y suelte el bot?n "bueno" : 6. La presentaci?n debe decir "estatus de fracaso de Hardware: Vac?e. Apriete bueno vaciar". 7. Apriete y suelte el Bot?n "bueno". El mensaje cambia a "estatus de fracaso de Hardware Vaci?. Prensa Cancela para continuar". 8. Apriete y suelte el "CANCELA" bot?n como muchos veces como sea necesario, para que, o el "bienvenido a Photosmart Exprese" pantalla parece, o, el "Fracaso de Sistema de Tinta" pantalla parece. POR FAVOR no TRATE de IMPRIMIR EN ESTA ETAPA. 9. Utilizar el Bot?n del Poder, apaga la unidad y desenchufa el cable de energ?a el?ctrica de la espalda de la salida de impresora y pared.
HPRepDude: As?gurese de que realiza pasos de 2-9 y permiti? que sepa el resultado. El cliente: Visto bueno. Todo fue como si los pasos dijeron y ahora son apagado y es desenchufado. HPRepDude: 10. Espere 30 segundos para el poder de ser descargados y entonces tapan el cable de energ?a el?ctrica en la salida de pared primero y entonces en la espalda de la impresora 11. Encienda la unidad. La impresora puede demostrar mensaje "BOTON de PODER de USO Al CIERRE LA IMPRESORA" seguido por "visto bueno de PRENSA para CONTINUAR". Apriete bueno. 12. Si la impresora ya ha inicializado, entonces va al pr?ximo paso. Si no, la impresora comenzar? el "UN PROCESO de INICIALIZACION de TINTA de TIEMPO". Permita este proceso para completar y no interrumpir. Una vez que el proceso de inicializaci?n es completo, la impresora imprimir?
una P?gina Diagn?stica. 13. Para verificar impresora funcionalidad imprime una AUTO PAGINA de PRUEBA. : Realice por favor todos los pasos antes mencionados de 10 a 13.
Nov 24, 2010 | HP Photosmart C6280 Printer
TENGO UNA COPIADORA XEROX 1012, CUANDO TRATO DE SACAR UNA COPIA TARDA EN CALENTARSE Y NO HACE LA IMPRESION Y ASI UNA SEGUNDA OCACION, HASTA LA TERCERA VEZ QUE TRATO DE SACAR LA COPIA SALE, CUANDO INTENTO...
Esta maquina es viejo, pero si la quiere usar, buenos.
Hay algunos alambres en centro de abajo, limpa los. Tiene cuidado porque los alambres se cebran faci.
Otra cosa es la tinta. La tinta tiene una cosa que media la tinta en el roldono palo. Si esta cabado, no va poner tinta muy bien. Se puede acer copias malas.
Otra cosa tambien es si el papel se tora.
Las jantas pueden ser mal. O otra cosa es si la maquina esta cebrara. Cuando abre la machina, mira adetro donde los dos partes se pegan. Si estran cebranan, el cloche en la atras puede pegra la ariba del metale de ariba de la machina. Usa unas pinsa a planar el metala de el clotche.
Buen suerte! Ojala que entiende esta mensaje.
Aug 12, 2010 | Xerox FaxCentre 1012 Plain Paper Laser
Como puedo cambiarle la carcaza ami motorokr z6 yo misma? es q se le rompieron unas partes xq se m callo al piso, y ay q compre una carcaza nueva me gustaria saber si m pueden explicar como la puedo...
loba , tenes que conseguirte un destornillador especial, lo desatornillas de atras de la pantalla( la q sube). UNa vez que sacaste los tornillos, levantas la carcaza y la deslizas un poquito hacia abajo PERO NO LA RETIRES DEL TODO!!! porque la botonera esta unida al telefono. Con un destornillador plano desenchufa la botonera del telefono ( con cuidado) una vez que esta desenchufada ahi la podes retirar. Yo estoy haciendo lo mismo pero tuve q comprar la carcaza, los botones y el lente todo por separado , si la tenes completa solo tenes que enchufar la botonera al telefono , si no asegurate de tener todas las partes (el lente si lo sacas no se puede volver a poner) Espero que te sea de ayuda, a mi me resulto facil pero el problema es que ahora se me rompio la pantalla=( pero ya me fije como cambarla. Saludos.
Jun 12, 2010 | Motorola Mobility MOTOROKR Z6 Cell Phone
Nesecito saber como abrir la tv sony para cambiar
QUITALE DOS TORNILLOS GRANDES QUE TIENE ATRAS PEGADOS A LA ORILLA, UNO AL LADO DERECHO Y OTRO AL LADO IZQUIERDO, LUEGO ALAS HACIA EL FRENTE LA TAPA FRONTAL Y VERAS UN COMPARTIMIENTO DONDE VA LA LAMPARA, LE AFLOJAS ESOS DOS TORNILLOS Y LA SACAS.RECUERDA PONER LA TAPA DE ESE COMPARTIMIENTO LUEGO DE PONER LA NUEVA LAMPARA, SI NO NO FUNCIONARA.Y BUSCA EN EL MANUAL COMO RESETEAR EL TIEMPO DE LA LAMPARA.ESPERO ESTO TE AYUDE.
Jan 29, 2010 | Sony KDF-42WE655 Television
No se como meterle musica a mi psp, o diganme como puedo meterle musica a la memory stick y luego ponerla al psp en espanol please
Bien, yo soy americano, así que tuve que recurrir a un traductor ... si usted va a su XMB, a continuación, la configuración Sytems, desplácese hacia abajo hasta que veas algo que dice que el idioma del sistema, haga clic en él y lo puso a su idioma. Para poner música en tu PSP, conecte el PSP en el equipo luego abrirlo y crear un derecho de nueva carpeta en el comienzo la llamada 'MUSIC', dentro de esa carpeta, puedes poner toda tu música y luego desconectar tu PSP y ir a escuchar a él
Dec 22, 2009 | Sony PlayStation Portable (PSP) Console
Al poner el dvd me marca como no disco
necesito el codigo para configurar el dvd favor si tiene el codigo nviemelo a adiesri_4@hotmail.com
Dec 08, 2008 | Daewoo DVG-8500N DVD Player
HP Photosmart C6180 All-In-One InkJet Printer Logo
107 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
