What does f1 code on the Honeywell smart fit central heating controls mean ?
  • 16 Answers
SOURCE: my daughters honeywell ch/hw digital control resets to zero
have the batteries died have you got the programmer set back to timer control or is it still in the set mode
Posted on Aug 17, 2009
  • 252 Answers
SOURCE: we have a Honeywell smartfit central heating
go to
http://www51.honeywell.com/honeywell/
and enter your model number on the right side near the top.
Hank
Posted on Oct 17, 2009
heatman101
  • 43501 Answers
SOURCE: st6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Posted on Nov 12, 2009
james3751
  • 614 Answers
SOURCE: Honeywell Central Heating temperature control
R comonY cool W heat G fan C other side of 24 unless you are battery operated. On the back of the Tstat tou should have switch that says gas or electric this controls how the fan operates. If not go into programing and program 1 stage heat one stage cool.Let me know I will walk you thru this.
Posted on Nov 18, 2009
  • 36 Answers
SOURCE: boiler is a baxi control for heating is honeywell.
this will be your diaphram inside your divertor valve.
the one that looks like a spaceship.
it will e split.
Posted on Jan 31, 2010
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
He3 dryer no heat electric F01 code in diagnostics also f 28
The F1 error code means that the control board has detected a error within the control itself
the F28 means that the moisture sensor is defective,now the moisture sensor is justa metal bar that fits into the front of the drum and hardly ever bad so sad to say both error codes point to a bad control board that would need to be replaced.
GENE
Oct 12, 2011 | Kenmore Dryers
Stove error f1 kenmore elite model 790.75902990
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Aug 12, 2011 | Kitchen Ranges
F1 popping up
try unplugging it,this code means power failure,sometimes unplugging it will clear this code,if not you need to replace the central control unit and possibly the motor control unit along with the Hall-Effect Sensor on the motor stator that tells the central control unit that the motors turning and not locked up
Jan 26, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Programmable Thermostat Heater: no power to honeywell central heating control...
Multiple possibilities:
Damage to cable (doing any DIY?)
Failure of thermo
Board gone in heat unit
Possibly simple as loose or disengaged connection, check at thermo & heat unit, if nothing obvious, call serviceperson.
May 18, 2010 | Honeywell Programmable Thermostat Heater
St6400c thermostat wont run the central heating independantly
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
109 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
