Question about Garden
What kind of spark plug for husqvarna 235 - Garden
2 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: Husqvarna 235 not an e model, Will not start, no spark to plug.
Hello David; We are prohibited from contacting you directly. It sounds as though the ignition module is defective but it could also be a defective switch or interconnecting wire, try this please, it tests the entire system.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
In the USA a duplicate receipt can usually be obtained from the merchant, there too? If not what about your credit card receipt?
I would try my local Husky dealer once the problem is isolated.
Dealer Locater.
http://www.husqvarna.com/uk/homeowner/dealers/dealer-locator/
An IPL (Illustrated parts listing) can be found here:
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 25, 2010
Testimonial: "Thank you for your help."
Husqvarna 235 chainsaw wont run
Check fuel supply, proper plug (resistor) compression 120 to 145 lbs. If saw will not run have the ignition tested with a 3-point spark tester.
Apr 30, 2014 | Husqvarna 232 235 240 Cylinder Pn...
How to replace carburetor in 235 husqvarna.
before replacing the carb remove the muffler and run it the muffler has a screen inside that gets plugged up with carbon then replace the fuel line from the filter to the carb they crack and **** air instead of fuel
Sep 19, 2012 | Husqvarna 232 235 240 Cylinder Pn...
Brand new husqvarna 235 chainsaw will not start
is the kill switch on?check the spark plug it could have had the wire fall off in shipping
May 24, 2012 | Husqvarna Forest & Garden #952802239 235E...
3 month old Husqvarna 235. Refuled. Won't start. Plug is firing. Primer bulb gets full. Still won't start.
These machines have had issues with main bearing cages breaking up, this it turn scores the piston and snags the ring in, if there is a good spark and the plug is getting wet i woud whip the muffler off and take a look at the piston through the exhaust port.
Jun 14, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Not getting spark to the plug.On my Husqvarna 18 in. chain saw 235, e series.
Try a new condenser. They are very cheap and can freeze which shorts it out inside so the magneto energy is not absorbed and ready for when the points fire. It only has one wire and looks like a metal cylinder about 1/2" diameter.
Mar 29, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Wont start got spark and fuel husqvarna 235 model #9528021-55 serial # 2010 0700375
Is the saw mechanically sound? remove the muffler and check the condition of the piston through the exhaust port, any sign of damage or scuffinf and it will need to come apart for further investigation, they are very prone to the drive side main bearing breaking up and damaging the piston.
Mar 01, 2011 | Husqvarna Garden
I am unable to pull cord to start, on my Cainsaw model 235.
Remove the spark plug and try to pull the starter--if ok, open the throttle and pull through several times to expel excess fuel from the cylinder. Check for blue snappy spark at the plug after this--if weak or nothing, try a fresh plug gapped at 0.020". If the engine still doesn't turn after removing the spark plug, it may have been run without oil in the fuel which will cause serious damage to the piston/ring(s) and cylinder. Remove the muffler and inspect these parts through the port behind the muffler--if badly scored, they will need to be replaced--an expensive process even if you do the work yourself. You might consider a new replacement saw if an estimate is very high. Hope this helps!
Dec 10, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I HAVE A 235 16"
A Husky 445 has a compression release (about the same bar length) which gets around this difficulty. We have a 435 Husky that has the same problem--your arm needs to be in pretty good shape to pull them through. We have found that the saw needs only one pull with the choke full on to be able to start on the second or third pull. Back the choke off about half to make the following pulls. Other than replace the saw, not much help I'm afraid.
Nov 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Ignition module gap
Dealer Locater.
06 1500198
Lou
Apr 25, 2010 | Husqvarna Forest & Garden #952802239 235E...
Won't start
only thing left would be the timing of the spark. inspect rotor, key may have broke and spun on shaft.
Sep 08, 2009 | Husqvarna Forest & Garden #952802239 235E...
Garden Logo
107 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
