Question about Clarke Air Tools & Compressors
Clarke ranger air 25
Pressure regulating valve
gaeb7
  • 25 Answers
SOURCE: 25 gallon air compressor wont shut off,changed air regulator
You have a valve plate problem . It could be a slipped "o" ring to a bad reed valve. There are rebuild kits for that purpose. The kits include a valve plate assembly. It covers all the bases. When you look at this area pay attention to the partitions of the head gasket/"o"ring. You may avoid the cost of the kit.
Posted on Feb 25, 2009
  • 89 Answers
SOURCE: tank will not build pressure beyond 25 lbs. Just runs
IS YOUR AIR FILTER CLOGGED. SOUNDS LIKE THE VALVES IN YOUR HEAD ARE NOT CLOSING ALL THE WAY. THEY ARE MOST LIKELY REED VALVES, THIN STRIPS OF METAL THAT OPEN AND CLOSE WHEN THE PISTON MOVES. MAKE SURE THEY ARE CLOSING ALL THE WAY (NOT CARBONED UP). DID YOU REMOVE THE HEAD AND DID YOU PUT BACK LIKE YOU FOUND IT - NOT TURNED OR FLIPPED OVER. SEE IF YOUR FINGER WILL GET SUCKED UP TO THE INTAKE HOLE.
Posted on Apr 12, 2009
dmftrucker
  • 1922 Answers
SOURCE: my regulator control valve assembly has started to
it'll cost you about $40 dollars w/shipping look around for a used 1
Posted on Oct 06, 2009
SOURCE: Was working normal suddenly will not build pressure
Maurader1 an apprentice has this problem solved and is spot on. All these gurus and wiz need to stick to the basic and common sense. The first place your pump will give out after use or abuse is the gasket. All this garbage about defective reeds and defective pressure switch is a lot of nonesense if you first don't rule out the most common problem the head gasket. I'm cheap and this thing has paid for itself 10 time over. You can get a gasket kit for $7, but I fabricated a gasket out of the back of my notebook and sprayed some gasket spray and been working like a charm ever since.
Posted on Jan 04, 2010
wiringlunati
  • 576 Answers
SOURCE: Air pressure does not go over 25 psi I have taken
Does it shut off at 25 psi or just keep running and never build more pressure than that? Also, did this come on gradually or suddenly? Also, was it being used regularly when it happened or had it been sitting for a while?
Posted on Mar 07, 2010
Where can I find a AC2003B-0045 check valve for a Clarke air compressor
it's most likely a pressure safety valve and it's EFFIN important !!!
Aug 20, 2014 | Clarke Air Tools & Compressors
What air pressure do i use for a clarke sb 9006 sand blaster
There will be a regulator valve on the unit and you can adjust it to do the job in hand ie light ruat/paint --just enough pressure to to the job --- heavy rust --more pressure material--- plastic light pressure--- aluminium more pressure --- steel will handle even more pressure.
Jan 14, 2013 | Clarke Power Products Clarke 10 Gal....
Compressor runs, builds up pressure, but wont come out of hose/???
When the pressure regulator fails, no pressure will be available at hose. Replace the regulator with generic available at Lowes or bypass. To bypass the regulator (this method will give you full tank pressure to hose) remove the safety valve (or gauge if it threads directly into tank) and install a tee fitting. On one side of tee fitting reinstall the safety and the other port is for quick connector. You can also install a regulator here if you would like to save time and the old regulator is difficult to remove. Good luck
Feb 12, 2011 | Clarke Power Products Inc AC2001 2HP 4...
No gas comming out
Try these possible problems and solutions.
1) Ran out of gas pressure from cylinder. Replace cylinder.
2) Solenoid valve not opening or clogged. Replace solenoid valve.
3) regulator closed or faulty. Open regulator to adjust flow. or replace it.
4) Gun connector not pushed all way in. Release butterfly nut on gun and push the connector all way in.
5) Gun liner's gasket (o'ring) at end of gun missing or broken. replace liner.
Feb 06, 2011 | Clarke Power Products Clarke 130EN...
Where can I purchase a new pressure regulator for a Clarke ac2001a pancake air compressor?
Harbor Freight should have this or be able to order it for you and usually take them bout three days to get items in.
Oct 28, 2010 | Clarke Power Products Inc AC2001 2HP 4...
I have a Clarke SHHH air 2/9 compressor
Hi
Can you hear any leakage, if not then I would suspect a valve is jammed open.
Gently tap valve housing with a soft hammer, may dislodge the valve.
Aug 11, 2009 | Clarke Air Tools & Compressors
I have a clarke hunter 2.5 50 ltr pump. when the pump reachs full pressure,instead of switching onto standye until more air is needed it dumps the air out from the under the on off switch housing.
well their is safety air pressure valve make sure it good which 99% they are good is pressure too high check the regulator is it set to high. that is. extra air and lots of regulators do dump air any ways so that's no big deal, it is normal
Jul 04, 2009 | Air Tools & Compressors
Clarke AC 2005A air compressor will not start under pressure.
It sounds like you have a bad check valve. Remove the main discharge line to the tank and listen for air. If you have any coming out your check valve is bad.
Apr 04, 2009 | Clarke Air Tools & Compressors
Clarke hunter 60 2.5 hp compressor , trip switch keeps tripping
if you are talking about the brass valve with a small pin in the middle.it leaks untill the pressure get to 15-25 lbs then the pin pops out and stops leaking and the compressor pumps to pressure. this is normal that valve it a cold start valve that allows the compressor to start with out binding
Dec 09, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
22 people viewed this question
Top Clarke Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Clarke Air Tool and Compressor Expert? Answer questions, earn points and help others
