Question about Maytag Neptune MAH6700A Front Load Washer
Maytag Frontloader (Perf series) brand new Agitator off axis
I have a brand new Maytag frontloading Performance Series Washing machine. The agitator basket seems to be off its axis and tilting to one side. It still rotates but the rubber seal seems to be "twisted" as well. Maytag is coming in about one week (bummer) but is there anything I can do in the meantime to correct the problem?
Okay! We just fixed this problem on our washer. First, be safe and be sure that the electrical cord is unplugged. Then you want to take the lid panel off of your washer. Then you'll feel around under the base of the agitator/washer basket. You should notice that its feet sit inside huge springs which are fixed to the base of the machine unit. Determine whether any of your basket feet are disloged from their spring and re-insert. Make sure the fit is good or else you might have the same problem again. After you reassemble, plug in the machine and try a test spin without any clothes. Then try with a smallish load.
Hopefully this helps.
Posted on Feb 02, 2009
A407 maytag washer getting grease on clothes occassionaly what would the replacement part
Maytag washing machine gets grease on clothes ... - Fixya
Oct 8, 2012 - Maytag washing machine gets grease on clothes occasionally. ... some of their clothes ruined by grease stains from their front loader Kenmore. .... remove the agitator from a Maytag washing machine Model A407 series 02?
Aug 24, 2015 | Maytag Washing Machines
How do I take the black plastic agitator off so I can get the drum out of my Maytag LA212 Series number 423621
Never seen a black agitator how a photo of what you are trying to remove if it is black sounds like the tub ring
Jan 19, 2015 | Maytag Washing Machines
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
My one year old son dropped a refrigerator magnet in our clothes and now the magnet is under the agitator. How can I remove this to retrieve the magnet and not stop up the drain?
Pull up on the fabric softener dispenser in the top of the agitator.
Set it aside.
Remove the agitator mounting screw from inside the agitator.
Pull up on the agitator base to remove the agitator.
Remove the magnet.
Reverse the above order to re-install the agitator.
Aug 09, 2010 | Maytag Legacy Series Top Load Washer
How do you remove the agitator from a Maytag washing machine Model A407 series 02?
Loosen the 1/4 inch hex nut on the side of the agitator about 6 inches up from the bottom.
Then pull up on the agitator.
Nov 11, 2009 | Maytag Washing Machines
Could you please tell me how to remove the agitator for cleaning on a Maytag top loading performa machine heavy duty.super size 3 speeds quiet series 100 13 cycles Thank you Bob Clark
The agitator on a Maytag Performa comes off by removing the center post cap and dispenser by pulling on it. Locate the agitator bolt and loosen (you may need to hold the agitator in place while loosening). With the bolt removed, the agitator will lift off.
If you still have questions, please let me know. I hope this helps you.
Sep 16, 2009 | Washing Machines
Seal leaking from tub. How do I remove agitator?
If this is a Maytag Performa or Atlantis model all you have to do is remove the center cap on the agitator by pulling on it and locate the agitator bolt underneath. Loosen the bolt, and the agitator should pull straight up.
If this is a Maytag Dependable Care series there will be 1/4 inch screw along the side of the agitator towards the bottom. Remove this screw and the agitator will pull straight up.
Aug 11, 2008 | Maytag Washing Machines
I have a Bosch frontloader. I have had it almost 4 yrs. About 6 months ago or a little longer the tub has started to bouce terribly when washing heavy clothes such as jeans, towels, bedding. I have to...
The inside of the agitator where the transmission shaft attaches can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Aug 07, 2008 | Bosch Washing Machines
I have a Maytag performer series machine,the main agitator is screwed down properly but the corkscrew agitatorthat is attachedto the main agitator completely cuts loose and floats to the top , i don"t...
With the Maytag Performa series, the auger is held by a pressure fit only - no screws. Mine failed after about 6 years. There is no (easy) way to repair this problem. The top auger does not stay attached to the post, and it floats off the post while washing... I ended up ordering a new one from the Sears 1-800 number. Easy to replace, and it comes with both the post and auger. Costs about $110, but certainly a lot cheaper than buying a new machine. The part does not come with the top cap for fabric softener, so be sure to save the old one. You do need a fairly long extension for your ratchet wrench to unscrew the attached bolt, but it is fairly easy to do.
May 30, 2008 | Maytag Washing Machines
Maytag Neptune MAH6700A Front Load Washer Logo
244 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
