Question about Canon P170-DH Calculator
Canon P27-DH setting date and time - Canon P170-DH Calculator
SOURCE: Cannot set the date on my Canon P23-DH V calcualtor
ok, have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved. do the same for time.
Posted on Feb 05, 2008
SOURCE: Canon P170-DH
I played around with mine and found the keys that you change the time and date with by looking over the top of the keyboard. On my model there is a time and date key that has a little calendar and clock actually on the key. That key allows you to switch between date and calendar. After you click on that button you will either see a date or time. To change those numbers use the following keys: The equal (=) key will change date and time by holding the key down till the numbers on the display start to flash. Once they start to flash use the number keys to make your changes. The multiplication (X) key you can use to change am and pm. If you want military time use the division key. If you are changing the date there is an additional key that lets you change the format. What this means is the sequence on the display by the way you view the month, date and year. You can change it so year shows first then month and date or interchange day and month. Once I found those keys it was easy.
Posted on Mar 11, 2007
old marine
  • 2122 Answers
SOURCE: Setting tax rate on a canon P170-DH
To set the tax rate, slide the "GT" switch to RATE. Enter the tax rate (i.e., 4.5 for 4 1/2 %). The display should show 4.5 %. Slide the "GT" switch to OFF.
Posted on Jul 30, 2008
old marine
  • 2122 Answers
SOURCE: Canon P23-DH
I don't think the P23-DH has a calendar/clock mode. I have found the instructions for setting date and time for the P23-DH V. If your calculator does not have [Calendar/Clock], [Time Set], and [AM/PM] keys, you cannot set the date and time.
To set date:
1. Press the [Calendar/Clock] key once
2. Press and hold the [Time Set] key for three seconds
3. Enter the date in MMDDYYYY format
4. Press the [Time Set] key
5. Press the [C/CE] key
To set time:
1. Press the [Calendar/Clock] key twice
3. Enter the date in HHMM format, press [AM/PM] key if necessary
Posted on Aug 28, 2008
SOURCE: Settting up tax rate on Canon P1-DH III
push CA
hold TAX+ button until tax% starts flashing on the display
put in the required rate
push CA
should now be set
Posted on Mar 04, 2009
How do I change the ink cartridge?
go to your browser search box type Instruction manual for Canon P27 -DH 12digit mini desk top printing calculator . on the page that appears you will see a PDF OF THE INSTRUCTION MANUAL. on the machine lift lid and the ink cartridge can be seen , you can lift the ink cartridge out and replace . Suggest download PDF just in chase .
Dec 24, 2015 | Canon P27-DH 12 Digit Mini Desktop...
How do I set the time and date on a canon p170-dh
Press the Date and Time button on the calculator. It is to the right of the Feed button and has a small calendar and clock on it. To set the date, press the button once to display the factory supplied date and hold down the Equal ( = ) button that is two buttons below Date and Time until the screen flashes. Input the correct date. Ex: August 20, 2010 would be entered on the numerical keyboard of the calculator at 08202010. When finished, hold the Equal button again. Do the same for the time.
To sum it up:
Press Date and Time button
Hold = button until blinks
Enter date or time
Hold = button again until blinking stops
Aug 03, 2010 | Canon P170-DH Calculator
Where is the time set key on canon p170-dh
Press the button to the right of the FEED button twice. The first time you press it will be for the Date, the second will bring up the time.
May 13, 2010 | Canon P170-DH Calculator
How to reset the clock?
Push the button with the clock and calendar, this is directly over the 'cost' button, to display the date or time. Then use the 'Time set' button (this is the one for Memory - Plus - Equal). Hold the 'Time set' button down until the first figure blinks then release it. Use the number buttons to change the setting. When you have gotten the correct date or time entered oress the 'Time Set' button again.
Although it is only printed with 'Time Set' the button works for the date just as well.
Mar 30, 2010 | Canon P23-DH Calculator
How do you set the date & time on a canon P23-dh?
Press and hold the ClockDate Set button for three seconds until the display shows the date with the first digit blinking. Enter a two-digit month, a two-digit date, and a four-digit year, followed by the ClockDate Set button.
Press and release the ClockDate Set button. Press and hold it for three seconds until the display shows the time with the first digit blinking. Enter a four-digit time, press AM/PM as appropriate, then press the ClockDate Set button. Press CE/C to finish and return to calculation mode.
You can download a manual from http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=346&modelid=15431
Oct 03, 2009 | Canon P23-DH Calculator
Can't set the time on my Canon P170-DH adding machine
1. Press the calendar/clock button twice
2. Press and hold the Clock/Date Set (or Time Set) button for three seconds.
3. Use the numeric keys to enter the time -- four digits (i.e., 0730)
4. Press the AM/PM button to select
5. Press the Clock/Date Set (or Time Set) button
6. Press the C/CE button to return to calculation mode
Aug 27, 2009 | Canon P170-DH Calculator
Canon P23-DH
To set date:
To set time:
Aug 27, 2008 | Canon P23-DH Calculator
Canon P100-DH Calculator manual
How to change the roller ribbon on my Canon P100-dh calculator?
Jan 10, 2008 | Canon P100-DHII Calculator
Canon P170-DH Calculator Logo
404 people viewed this question
old marine
old marine
