Question about RCA F27668 TV
RCA F27668 clicks but wont turn on
Serial - 023421213
chassis - CTC203AA
TV will turn on for 1sec with click but then just turns off...is it the relay switch and if so which part do I need...
only other suggestion would be resoldering??
any help would be great, thanks
    Sergeant:
    Champion:
  • 346 Answers
Check cr4108
Posted on Jan 04, 2009
I have serial #107611268,model # f27668,classic #ctc203aas..i need to change from cable to antennae and can nit get any channels to list
This is an analog tuner tv,there are no OTA analog tv transmissions you need a digital converter box btween your antenna & tv
Aug 02, 2013 | RCA Televison & Video
RCA 36695BC wont turn on
Can you please provide the chassis number of this TV?
Jul 24, 2008 | RCA F36695BC 36" TV
My rca F27668 tv fell down and the color is off its purple and blue yellow and green in diffrent areas. how do i fix this?
You need to degauss the TV,
This can be accomplished 2 easy ways i knwo of.
1.> If you have or know someone who has an old style soldering gun, the kind that has a pull lever and looks like a gun and buzzes when pushed, this will act like a degauss wand, simply plug it in pull the trigger and wave an inch or so around the affected areas untill the problem goes away.
2.> call a tv repair shop and ask them how much to "degauss" your tv.
Sep 25, 2009 | RCA F27668 TV
When I turn my TV on, it clicks on and off 5 times then stays off
first check a switch contacts, that switch has two make contacts in side it. if the switch is okay, then check a power supply dry joints on it.
or a dry joint on the line out put transistor, or a line transformer legs.
Apr 30, 2009 | RCA F27450 27" TV
I'm afraid this failure is not just a fuse failure in your TV since you still can hear the relay clicking. This fix might not be a DIY.
Where can I send you additional info on what could be wrong with your TV?
RCA Model 32V434T chassis ATC010A
for shure your fly back transformer is bad is a commom problem in this chassis
Mar 29, 2008 | Televison & Video
60in. rca rear projection tv
1) Reset will not help
2) Older RCA projection tv's usually produce a good pix,
so you could fix it....
3) light box chassis pulls out to go to shop for repair...
4) For more info = provide service # and chassis # off back..
Please rate this solution...............
Nov 13, 2007 | RCA P46924 46" Rear Projection Television
RCA 32V524T won't power up. Chassis # ATC010T
I've had this TV for just over a year. Went to turn it on one day and it would not power up. I here a relay clicking. i suspect the horziontal drive transistor. Does any one have a service manual or know where I can gat one? first check power supply output if it ok than forget relay if not check power supply by dis connnecting horl. output. if it is ok check h/driver collector voltage if it is less than supply voltage than h/osc & driver ckt.is ok check h/output & its print for loose. regards thanks
Sep 10, 2007 | RCA 32V524T TV
RCA F27668 TV Logo
167 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
