Question about Coleman Powermate Powermate 5000W Generator
Motor Blew Up
WHile using my generator the other day, the side of the motor blew out. I had been having trouble keeping it running as the pull cord seized, I fixed that and ensured that it had fresh gas and oil. Any suggestions and any idea what kind of warranty these generators have?
  • 5 more comments
  • jmaceachen Jan 05, 2009
    Thanks for the info. I will give it to my Dad to call. I see ont he website that the engine warranty is only 3 years. i am not sure how old our machine is. A hole blew out the side of the generator and pieces went everywhere. It was like shrapnel. Very Dangerous.
    Even though the warranty may be expired he will still call the company and tell them what happended. You never know there may be a recall.
    Thanks again
  • Anonymous Jan 06, 2009
    about 2 am in the morning it blew out. It was full of oil about 10 pm that night so i dont know why it done it.
  • miller_n Jan 09, 2009
    I have a new one with the subaru robin 10 hp engine and its making a faint knocking noise and smoke pretty bad on startup only. used a screwdriver as a stethoscope and hear no noise in block nor the ohv assembly or alternator but sounds like its coming from flywheel area. also its new and i have changed the oil at least 5 times with 10w-30 premium oil according to the manual specs, and it has fine powdery metal in the oil each time i have changed it and an occasional slither of metal. other than that it runs fine. Im afraid engine will BLOW A HOLE IN THE BLOCK also. tried 30w oil still smoke like hell on start up, thinking valve guides are bad or rings maybe. wife threw away receipt cant bring it back for another I think I got a piece O ****!
  • valvestem May 11, 2010
    Now I look like a madman after all these replies. Coleman is still in business, they still do the camping stuff, but sold the Coleman Powermate section to the Italian company. Sorry.
    Correction to above:
    Coleman Powermate was sold to an Italian company, not Chinese.
    Here's a link to the Powermate page, they no longer use the word "Coleman".
    Info To Your Issue:
    My brother in law has a Coleman gen w/a Honda motor. He told me Coleman went out of business in Feb 08. Their stock, parts etc., was bought up by a Chinese company that he says will honor warrantees if they still carry/manufacture the particular model giving trouble. I believe also they are keeping the business in the US,at least for now. MY BIL also said that they are only going to keep up manufacture/support of the higher end models. I can ask him if he has any numbers/email to contact them if you want.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 25 Answers
Connecting rod bearing failure ...metal shavings in oil....
top compression ring worn allowing combustion carbons to mix in oil increasing wear & heat to break con rod which broke & went thru engine block
Posted on May 05, 2014
  • 120 Answers
Normally they only have a 90 day warranty. But if the generator is under a year old I would contact the manufactor and see what they say.
Posted on Jun 04, 2009
How do i fix dyson DC41 Animal vacuum upright cleaner it has burning smell coming from motor and it blew the fuse box when i WENT TO VACUUM. the wire flex is a bit over twisted
You most certainly shorted this out and will need a new cord. Easy fix but you will have to take it apart and find where it failed. I doubt the motor fried but it is possible. When you take it apart look for the burn mark left by the electrical arc. That is the point you fix.
Dec 26, 2015 | Dyson DC41 Animal Bagless Upright Vacuum...
My 4H.P. 25 gal. air compressor doesn't work, when i plugged it in it blew the beaker and the outlet. Now it's dead?
Check motor reset on end of motor. Check cord for damage, insure insulation isn't cut. If you've reset your breaker for receptacle , make sure switch for compressor is off, plug in , then flip switch. See if motor attempts to run. If the problem repeats, motor could be shorted if cord is ok.
Sep 29, 2015 | Air Tools & Compressors
2277HB washing machine blew switch for second time have replaced the hall sensor and the motherboard. motor smells hot
The motors might be freezing they do get jammed with **** after time pull the motor to see if it's spinning if not look at the shaft clean it to wear it will spin still nothing the motor has froze time to rebuild it or get a new one
Sep 11, 2012 | LG WM-2277HW Front Load Washer
My York Pacer 3500 Treadmill switched on then every time I used it the fuse blew. Its happened almost 5 times.
see the block diagram attached.
1) you must test the power cord for short wires.
2) test the power switch for short.
3) test coil for shot
4) test capacito for short.
5) the main motor board can be faulty
In short you must disconnecat every wires , and isolated the short for to avoid the fuse blown.
Otherwise you must call some service tech, from your supplier company.
God bless you
Jun 29, 2012 | York Exercise & Fitness
I have a model #919.167200 5hp, 20gal. air compressor. It has been working great for years, but when I went to turn it on today it blew the breaker. I pulled cover and cleaned contacts on pressure switch,...
Hi dtsorrell...
If your somewhat of a mechanic/electrician then you can by-pass the pressure switch by hooking the color coded motor wires together with the incoming color coded wires from your power cord in the proper order.
Plug it in and then check to see if it blows the breaker again, if it does then it is your motor that is faulty.
Please take time to rate me.
Jul 28, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
The pull cord is locked, can only pull out 5 inches....why?
Could be motor locked up or cord caught in the rewinding mechanism. Remove top engine cover and see if cord pulls now. If not then in winder. If it does see if you can turn the motor over by hand with cover off. If not maybe engine locked up. Did the engine run low on oil? if so when motor cooled, things may have locked up. Try removing spark plug, and light oil to cylinder and let soak.Turn engine with wrench.
Jun 30, 2010 | Briggs & Stratton Power Products 5,550...
Washing Machine won't turn on
the rating, is that the same with the original one.?
try running with no load, maybe the motor got problem. if okay no load. try run with a little load. if still blow the fuse even no load test. Your problem is in the motor. Or monitor carefully when the fuse blew, is it when the motor run ccw or cw?
Jun 10, 2009 | Fisher and Paykel (IWL12)
Cord won't pull out
Hi Shaun77b,
Regretfully if you didn't use a gas/oil mix the motor is probably seized. The internal parts on a 2 cycle motor are lubricated by the oil in the gas. It may keep running without oil but once it shuts off- its done.
Sorry, Phil
Dec 27, 2008 | Husqvarna Forest & Garden 125bt Backpack...
Fan cooling
Doesnt sound like anything out of the ordinary.  The only things you can do to help remedy that more is run synthetic oil get a right hand side air scoop or cut vents into your undertail panel.,,
Nov 10, 2008 | 2007 Buell XB12X Ulysses
Vacuum cleaner blew the fuse in my house!!
Are you sure that the vacuum motor went bad? If it did, then if would just have to be replace again. Doubt that you would find a different motor other then what belongs in there. If you did it would have to the right size to mount right. Some motors will last a long time while others just don't and you never know how long a one will last. Maybe the power head is what caused your present problem.
Jan 12, 2008 | Vacuums
Coleman Powermate Powermate 5000W Generator Logo
181 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
