Question about Maytag Atlantis MAV6451 Top Load Washer
Matsui dishwasher wont fill up with water
I put pots in from dinner,water came out with alot of fat,now it wont fill with water or drain
  • misscutie59 Jan 04, 2009
    didt work
  • uvbi Apr 04, 2009
    I have a Matsui Dishwasher Model MF145, It works well but at the end of the wash cycle it always leaves water in the bottom
    Problem Solver:
  • 4 Answers
Check your inlet filter at the tap source and behind the machine where the filler pipe enters. They changed some pipes in our street and fine sand filled our micro filters to the dishwasher.
Posted on Jan 04, 2009
Why does our dishwasher drain when large items are put through?
if your question is why does the washer drain first when pots and pans mode is selected? the answer is mfg. have realized that most everyone prerinses there pots and pans first , this makes a lot of water drips in bottom of washer this affects the volume of new water it can allow to enter , so they have made it pump out first for a \few minutes when first turned on in that mode ,it should fill after that and wash normally , also this is why its important to use soap dispensers and not just toss the soap in as it may get rinsed away in first few minutes and not get to wash cycle
Feb 16, 2016 | Dishwashers
My dishwasher(samsung DW7933LRABB) wont fill, it will drain if i put water in the tub. supply is on.
You either have a bad water valve, or a bad case-brake assembly (in which case you should have an error code or blinking light on your console).
Mar 06, 2015 | Samsung Appliance DW7933LRABB 24" Tall Tub...
My dishwsaher wont drain water
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 10, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher fills up with water put wont go into wash cycle and wont drain
your drain hose is probably plugged to the drain especially if it goes through the garbage disposal first,remove drain hose from dishwasher at the disposer and see if its plugged,if so unplug obstruction,then start it and put hose in sink and press drain/cancel and see if it drains now
May 12, 2012 | Hotpoint Dishwashers
Bosch classixx dishwasher wont drain
Ive had this happen on mine too. remove the filters in the bottom. squirt washing up liquid into the space-- liberally dont be shy!
Boil pans of water, boil the kettle. pour water into the space where the filters normally are. Fill the base of the dishwasher completely. Next close the door and repeatedly use the Reset feature. Eventually the pump will clear and kick back into life. Its a build up of fats, and sludge that causes the pump to appear to seize--the washing up liquid and boiling water see to that.
Feb 05, 2012 | Bosch 24 in. SGS43C12 Classixx...
I have a Matsui MS160SLI dishwasher it keeps on draining and will not fill with water. I have tried everything in the manual but nothing works. Help.
If the cycle does not stop draining that is usually because of a faulty water level switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Check if the floating sensor is stuck or faulty.
Some machine may use a membrane switch instead of a floater.
Apr 13, 2009 | Neff 24 in. S5543X2 Built-in Dishwasher
Put wrong soap in the SmatDispense container...
If you run it as is you will have a kitchen full of soapy water.
Take a pot or pan. Fill it with COLD water. Our it into the DW. Fillit to the regular water level, about 1 inch below the bottom rim.
Set the DW to a pump out setting and drain it.
You will have to repeat this several times to clear the soap out.
COLD water pump out. Cold water pump out etc.
Do not use HOT water. You will get instant suds and lots of them.
Mar 27, 2009 | GE 24 in. Profile PDW7800 Built-in...
Matsui MF145 beeping continuously
You might want to check the salt and rinse levels on your dishwasher.
Ours was doing the exact same thing and we refilled the dishwasher salt and it worked again. Unscrew the plastic thing on the bottom of the dishwasher and fill it up with about 1 kilo of dishwasher salt, water will flow out when you do this and you can put at least 2 kilos in.
Hope that helps xxx
Apr 02, 2008 | Dishwashers
Dishwasher won't empty?
try cleaning the drain hose to see if there are any obstructions, cold fat is a favorite!
Nov 25, 2006 | Candy 24 in. CD622 Free-standing...
Maytag Atlantis MAV6451 Top Load Washer Logo
280 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
