I am trying to print out 12 year calender with pcitures and i keep on getting a link that says a printer supporting te selected paper size is not selected
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
When I copy to photo paper it reduces automatically, why
Print on special and custom-sized media
To print on special or custom-sized media (Windows)
1. Load the appropriate media. For more information, see Load media.
2. With a document open, click Print on the File menu, and then click Setup,
Properties, or Preferences.
3. Click the Paper/Features tab.
4. Select the media size from the Size is drop-down list.
To set a custom media size:
a. Click the Custom button.
b. Type a name for the new custom size.
c. In the Width and Height boxes, type the dimensions, and then click Save.
d. Click OK twice to close the properties or preferences dialog box. Open the
dialog box again.
e. Select the new custom size.
5. To select the media type:
a. Click More in the Type is drop-down list.
b. Click the desired media type, and then click OK.
6. Select the media source from the Source is drop-down list.
7. Change any other settings, and then click OK.
8. Print your document.
To print on special or custom-sized media (Mac OS)
2. On the File menu, click Page Setup.
Chapter 2
28 Use the device
3. Verify that the correct printer is selected.
4. Select the media size.
5. To set a custom media size:
a. Click Manage Custom Sizes in the Paper Size pull-down menu.
b. Click New and type a name for the size in the Paper Size Name box.
c. In the Width and Height boxes, type the dimensions and set the margins, if
desired.
d. Click Done or OK, and then click Save.
6. On the File menu, click Page Setup, and then select the new custom size.
7. Click OK.
8. On the File menu, click Print.
9. Open the Paper Handling panel.
10. Under Destination Paper Size, click the Scale to fit paper size button, and then
select the customized paper size.
11. Change any other desired settings, and then click OK or Print.
Print borderless
Borderless printing lets you print to the edges of certain media types and a range of
standard media sizes.
NOTE: Open the file in a software application and assign the image size. Make
sure the size corresponds to the media size on which you are printing the image.
You can also gain access to this feature from the Printing Shortcuts tab. Open
the printer driver, select the Printing Shortcuts tab, and select the printing
shortcut for this print job drop-down list.
NOTE: Borderless printing is not supported on plain media.
To print a borderless document (Windows)
2. Open the file that you want to print.
3. From the application, open the print driver:
a. Click File, and then click Print.
b. Click Properties or Setup.
4. Click the Paper/Quality tab.
5. Select the media size from the Size is drop-down list.
6. Select the Borderless Printing check box.
7. Select the media source from the Source is drop-down list.
8. Select the media type from the Type is drop-down list.
Print borderless 29
9. If you are printing photos, select Best from the Print Quality drop-down list.
Alternatively, select Maximum dpi, which provides up to 4800 x 1200 optimized
dpi* for optimum print quality.
*Up to 4800 x 1200 optimized dpi for color printing and 1200 input dpi. This setting
might temporarily use a large amount of hard disk space (400 MB or more) and will
print more slowly.
10. Change any other print settings, and then click OK.
11. Print the document.
12. If you printed on photo media with a tear-off tab, remove the tab to make the
document completely borderless.
Change settings from an application for current jobs (Windows)
To change the settings
1. Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
(Specific options may vary depending on the application that you are using.)
3. Change the settings that you want, and then click OK, Print, or a similar command.
Change default settings for all future jobs (Windows)
1. Click Start, point to Settings, and then click Printers or Printers and Faxes.
- Or -
Click Start, click Control Panel, and then double-click Printers.
2. Right-click the printer icon, and then click Properties, Document Defaults, or
Printing Preferences.
3. Change the settings that you want, and then click OK.
9. If you are printing photos, select Best from the Quality drop-down list.
dpi*.
print more slowly.
10. Select the media source. If you are printing on thick or photo media, select the
manual feed option.
11. Change any other print settings, and then click Print.
Nov 04, 2011 | HP J4680 Office Jet All-In-One Printer
When I want to make a copy it tells me "Paper size
Good day, Regarding the error message that your getting, that means the paper where you want to print that document is not supported by the printer. Usually you'll the see supported paper size if you click the print option or print setup for your printer. The only way to resolve this is to use the appropriate size of paper like.
You can also try this steps to change size for the documents you want to print
>Open the File menu and click Print.
>Click the Settings tab
>Click on Paper Size. A list of paper sizes will appear
>Select the size you want.
>If none of the selections are suitable, select Custom. A box will appear inviting you to set your
own measurements. Enter the width and length that you want.
>Click OK.
These are the usual paper size use. It's 8 1/2 by 11 inches and the other one that you could use in most printers is 8 1/2 by 14. The first one is known as Letter size, the other one is known as Legal size. Hope this information help in resolving your issue. Have a great day.
May 23, 2011 | HP Photosmart 3310 Printer
Paper Jam keeps appearing
At the print driver there is a paper size selection before you print.Select the proper size and weight and it will work fine for you.
Jul 27, 2009 | HP PSC 2355 All-In-One InkJet Printer
How 2print 8 x 8 inch paper, HP Photosmart C5180 All-in-1 printer
From the User guide:
Select the appropriate options for your print job by using the features available in
the Advanced, Printing Shortcuts, Features, and Color tabs.
Tip You can easily select the appropriate options for your print job by
choosing one of the predefined print tasks on the Printing Shortcuts tab.
Click a type of print task in the Printing Shortcuts list. The default settings
for that type of print task are set and summarized on the Printing
Shortcuts tab. If necessary, you can adjust the settings here and save your
custom settings as a new printing shortcut. To save a custom printing
shortcut, select the shortcut and click Save. To delete a shortcut, select the
shortcut and click Delete.
6. Click OK to close the Properties dialog box.
7. Click Print or OK to begin printing. The user guide link: http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf Click on this link or copy and paste the complete link into your browser. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | HP Photosmart C5180 All-In-One InkJet...
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Hp 2610 all in one
Check if the right type of paper is selected to print,
Try the steps in the link bellow:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00654323&dlc=en&product=421139
Good Luck
Jan 10, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printing size and shifting to the right
Hi there check the print margins within MS Word goto
  1. File
  2. Page Setup
  3. Margins
And check that they are OK. if not check that you haven't got the wrong size paper set in word. Same as above but select Paper size then check in the printer driver that you have the correct paper size selected and that you haven't selected a strange margin.
Hope this works
Thanks J
Nov 28, 2007 | HP DeskJet 5650 InkJet Printer
Keep getting "11 load letter in tray 1" message
Are the print jobs being sent to printer all the same page size?
Are they all print jobs sent letter page size and your printers cassettes are set for A4 or something?
Your printer is asking for letter size paper, because any paper it has is not set to letter  and document that it is trying to print has been sent as that size.
Check what options you have on print driver on pc as far as Tray defaults, paper type and size settings
Check printer settings via its keypad as to tray defaults, paper size set for each tray and paper type, some printers have paper size switchs on their trays too.
Oct 26, 2007 | IBM Network Printer 12 Laser
Custoem paper sizes
Sounds like it's more of  an A4 type,
go to the settings on your pc and try to switch it to A4 size instead of letter
Sep 11, 2007 | Dell P1500 Laser Printer
24 people viewed this question
k24674
