Question about Sportline Exercise & Fitness
How do I open my sportline model 4409 to change my battery
Need help so I don't break the pedometer
4 Suggested Answers
  • 5473 Answers
SOURCE: How do you change the
The battery hatch is at the bottom of the pedometer. Just slide the hatch open with your fingers and then pry battery out. Put in the new battery in the same orientation (positive up on most). I find shaking the pedometer works to get the battery to fall out. If my fingers don't move the hatch, I use a small flat blade screwdrivers.
I hope this helps.
(on my pedometer (a similar model) the hatch is on the back with a slot to slide in a finger nail and wraps partway around the hinge)
Posted on Aug 08, 2010
  • 3 Answers
SOURCE: Sportline 347 pedometer- need instructions.
http://web.archive.org/web/*hh_/www.sportline.com/manuals/347.pdf is where I found the manual. Good luck!
Posted on Jan 01, 2011
6ylucy
  • 742 Answers
SOURCE: Missing a battery for a Sportline Model 342 Pedometer.
You should be able to get every Sportline Pedometer manual here
Posted on Aug 27, 2012
Beeping won't stop in Sportline 370 pedometer
Use MODE button to scroll to ALM (alarm) then press INFO button to change from ON to OFF. If that doesn't work use MODE button to scroll to PACE, then press INFO button to toggle from ON to OFF.
Feb 27, 2012 | Sportline 370 Traq Motion Sensor Pedometer...
Need to "unlock" my Sportline
all you have to do is hold down the start/stop button for like 3 seconds and at should unlock it so you can use the heart rate monitor...
Sep 20, 2011 | Heart Interface Sportline S12 Ecg Heart...
I have a new sportline belt clip pedometer. It has 3 buttons: mode,set and r/s. How can the length of stride be entered into it so an accurate mileage reading is possible?
I have an older Sportline pedometer with the same three button arrangement.
My pedometer is set as follows:
First press Mode to get the unit in the Distance mode. Note if the unit is in Kilometers or Miles. (Press and hold Reset for 5 seconds to switch the setting. This will reset the entire pedometer.) Press and hold Set for 2 seconds. The current (or default) step length will appear and flash. Press Set repeatedly until your step length is displayed. It changes by 1" or 1 cm at a time. Then release the Set button. (The pedometer will return to the normal operating mode if you do not press a button for 5 seconds.) When you reach the maximum step length, the unit will advance to the lowest step lenght when you press Set again. Since my step length is actually not a whole number, I rounded down.
A different Sportline step and distance pedometer (the 340) is set slightly differently. To switch from Miles to Kilometers, press and hold Mode when in the Step mode. Then switch to the distance mode and press and hold Set until the step length flashes. Press Reset to advance the current step length by 1" or 2 cm. Then release the button when you have the correct step length displayed. The pedometer will return to the normal mode after 5 seconds with no button presses.
Many Sportline pedometer manuals are available from the company's web site on the product site: http://www.sportline.com . You can look up the model number.
If you add your Sportline pedometer model, I'll be glad to give the specific setting procedure for you.
I hope this helps.
(on her third Sportline pedometer, two had the plastic spring clip fail. They all had similar programming details.)
Aug 18, 2011 | Sportline step and distance Pedometer New...
My Sportline pedometer is showing KM... how do I get it to miles?
If you post the model number someone might be able to help you. Sportline makes a lot of models.
You can start here: http://www.sportline.com/ . They have online manuals for most models.
Dec 22, 2010 | Sportline step and distance Pedometer New...
How do you change the battery on the Sportline, fitness pedometer 360?
I hope this helps.
Aug 08, 2010 | Sportline 15 Function Total Fitness...
Same problem here. If your pedometer is rectangular, with slanted window, LR 44 battery should work.
Oct 23, 2009 | Sportline Exercise & Fitness
I have a sportline 345 pedometer. I replaced the
I was looking for instructions for a different model when I found the instructions for the 347 here: http://www.sportline.com/manuals/345.pdf
Aug 07, 2009 | Sportline 345 Electronic Pedometer
How do I change the battery in my 345 Sportline pedometer
the battery is under the front cover. Pop it open with your fingernail or a coin. It uses a CR2032 button cell battery.
Jun 19, 2009 | Sportline 345 Electronic Pedometer
Exercise & Fitness Logo
32 people viewed this question
Top Sportline Exercise & Fitness Experts
Ansel Alberto
Ansel Alberto
Are you a Sportline Exercise and Fitnes Expert? Answer questions, earn points and help others
