Question about Air Hogs Havoc Heli Helicopters
Nephew lost directions for charging
Need to know to charge in A-B-C port can you help? If you know the difference between them would be a great help!!
  • the_green_ca May 11, 2010
    What do you mean by ABC? To charge you heli all you do is pull out the connector charger from the remote and plug it into the heli. The charger is right by the on and off switch on the helicopter. MAKE sure the helicopter is turned off and the actual remote control turned on or else it won't charge.
  • 30 Answers
Make sure both heli and controller are off and batteries are new and then plug wire into heli and then turn controller on it doesnt matter abc, abc is just the frequency to controll heli just match with the letter under the heli
Posted on Jan 05, 2009
My kindle won't charge. I have tried 3 different chargers.
Lillian, May have to try hard reset or possibly repair charge port to get battery to start charging. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Kindle won charge
Kindle Wont Start or Charge How to Reset Kindle
Troubleshooting Kindle Fire That Won Charge
Kindle Fire Won Charge Fix
May 22, 2016 | Tablets & eReaders
Tablet wont charge
you most likely need a new charging port,,,, they are available on amazon, just search for #### charging port , , #### being your model number,,,, or remove the back number and read the number on the harness for the charging port and amazon search that number,
you tube videos will show you how to replace that, if you watch the vid for replacing the screen, you will see the charging port being removed and you'll then know how to do it
Mar 31, 2015 | Tablets & eReaders
I need help please!!!!!
The charging port could be clogged with dust, or the battery is shot. You can bring it to a cell repair place and they will probably do a free charging port clean out if it is dirty.
Aug 05, 2017 | HTC One VX
I have a 2005 chevy malibu and need to know which port to recharge the system through. The lower port (located near the firewall) or the upper port (located near the upper left side of the radiator)?
You didn't mention your engine size but if you have the correct tool to charge the A/C system there are 2 different sizes and the connector that you use to charge it with will only fit on the correct one as they are 2 different sizes. The 2 different connectors of valves like I said are different sizes. The one you use will be the smaller of the 2 valves. The hose itself is larger but the port you fill up is the smalled one out of the 2. The hose will only fit on the 1 that fills it.
Apr 22, 2013 | Cars & Trucks
I want to know where is the location of an ac low service port?
HI!!
Find the compressor and follow the thicker line/hose coming from it. On an A/C System, the Fat Line is the Suction or Low Pressure Line and the Skinny Line is the Hi Pressure Line. The Low Pressure Service port is usually located by the passenger side fender well next or on top of the filter/receiver/dryer (a metal cylinder device). The Low and Hi pressure service ports are different so there is no way you can hook up wrong the charging hose.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Apr 15, 2011 | Ford Thunderbird Cars & Trucks
Is their a different way to charge a dsi
Unfortunately the only way to charge the DSi is with the charging port. You can get different chargers if you lost yours, but if there is another problem, like the port broken, there really isnt a way. Hope I could help ;) thanks
Mar 04, 2011 | Nintendo DSi Black Console
I eed to know which port to connect to to use usb
I had this problem as well. I loaded the drivers for the USB to Serial Adapter and the drivers for the SiPix printer, left the adapter cable plugged in and rebooted my pc. After powering my PC back up I went back into the SiPix printer properties and another com port (5) showed up in the list of com ports. This was the port I needed and the printer woks great!! now your comport may be different depending on which USB port you have your SiPix connected to. This worked for me. Hope it helps you out!!
Nov 18, 2009 | SiPix Pocket Printer A6 Mobile Thermal
Psp won't charge when plugged into computer
u cant charge on a computer unless you have a charger that hooks up to it...are you sure your using a charger or are you using the cord that transfers data to ur psp! the data cord will not charge ur psp its not a charger all it does is transfer data sorry you need a charger for the psp not a data cable
Jun 18, 2009 | Sony PlayStation Portable (PSP) Console
Charging camera
Are you using the front usb ports on your computer? My computer's front usb ports were not able to charge my camera, but the rear usb ports were able to (the charging light should stay on if it's charging correctly). I'm not an expert on this stuff, so maybe there's a power output difference between your frontal and rear usb ports.
Also, on the CD there was a camera connection driver. You might try installing that and see if that makes a difference?
Sep 28, 2008 | Kodak Easyshare M753 Digital Camera
USB Cord (Or something)
First, make sure the hold/lock is not engaged, and that there is no lock on your USB port (usually not). Try hooking it to a different PC, and see if it will charge. If it charges on a different PC or a different usb port, then your USB port is bad/wrong kind.
Sep 06, 2008 | SanDisk Sansa Clip MP3 Player
Air Hogs Havoc Heli Helicopters Logo
421 people viewed this question
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
magna buff
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
