Question about EliteGroup ECS P4M900T-M2 Socket 775 Motherboard
My internal ac port does not work can i change it out
Do u know if i can change it out
  • 37 Answers
Yes, buy a new Power Supply.
Posted on Aug 06, 2009
Charging ic
1. Make sure the AC outlet is working. Try connecting to a known working AC outlet.
2. Can you try a different charger to charge your tablet?
3. Can you try a different tablet to charge from your charger?
4. Can you bring the tablet to a mobile store for them to test the above?
Jan 06, 2014 | Samsung Cell Phones
Rgb connection
did you re install the drivers for your port/card , update BIOS? is this port present under device manager? is it a pci slot card? if so make sure that in bios that pci slot is enable as well .. let me know how it goes.
Jun 03, 2013 | Dell LATITUDE Computers & Internet
Lights come on but no AC output
Yes,internally there is two fuses. always arround 30 Amps. change it. there are like automotive fuses, plug in type.
Apr 19, 2013 | Belkin AC Anywhere (F5C412UK140W) Battery
Microsoft Cpa09-010a Ac Adapter Xbox360 Slim 135w stopped working
if your volt is 220v. so you can use fuse on AC line 600mA to under 1Amp.
DC line fuse is under 12Amp. clean any power cable port & use perfect gas.
May 28, 2012 | Microsoft Cpa09-010a Ac Adapter Xbox360...
I have 2420n that has stopped taking data from my PC. I know its not the PC as it works with another HP printer. I know the 2420 is internally ok as it prints a self test from its own control panel menu! I...
change usb port., restart printer,, / remove power cable from printer, after 2-3 minut put. after it if will not be resault, scan with strong antivirus your pc, there can be working script /on that printer driver/, what blocking usb port,
May 31, 2011 | HP LaserJet 2420 Printer
My external Harddrive just up and stopped showing up on the computer. I mean the lights (red and blue) are on, it just doesnt show up. i even plugged both cables into my comp, and still nothing. I noticed...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then power adapter of harddisk or your harddrive has internal issue.
Let me know if you need further assistance. Thanks for using FixYa
Oct 15, 2010 | SimpleTech SimpleDrive 160 GB External USB...
My i b m will not turn on with ac but will work with battery
possible problems: charge port has been damaged or it simply wont work (common ibm problems)...
Solution: go to the local repair shop to repair or change the ac port.
good luck!
Mar 23, 2010 | IBM ThinkPad T41 Notebook
Netopia NAT
I know that most Netopia's I've worked with have been able to port forward single or ranges of ports to numerous internals from numerous externals.
Address Translation needs to be on.
IP Passthrough has to be off.
Then in NAT Easy Servers, setup port forwards and specify the external IP, internal IP, and ports (can forward all).
Dec 21, 2009 | Netopia ADSL2+ 11G WIIRELESS ROUTER 400MW...
Milwaukee Job site radio
Questions:
1. Does the AC cord look ok? Not damaged?
2. Have you tried another AC outlet?
3. Does the AC cord unplug from the radio?
When you operate the radio from the AC power cord, the radio uses an internal power supply consisting of a step-down transformer, rectifier, and filter that converts the AC to DC to operate the radio.
When you run the radio off of batteries, it powers the radio directly. In some radios, when you plug the AC cord into the radio, it activates a switch that disconnects the battery voltage to the radio so that the batteries wont be damaged from the voltage created by the internal supply.
The radio can be powered by either the batteries or the internal supply. You don't want either supply affecting the other, so that is why a switch is sometimes used.
Since the radio works fine off of batteries, that would indicate that there is a problem with the internal power supply. This could be a blown fuse, bad transformer or bad rectifier diode.
Good Luck,
- Jim
Jan 24, 2008 | GE Superadio III AM/FM
EliteGroup ECS P4M900T-M2 Socket 775 Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
