Question about Norelco 8160XLCC Electric Shaver
Jet clean system will not clean.
I have purchased the Norelco 8160XLCC with the Jet clean system. It had been working fine until today. After shaving I went to clean it and the system would only move up and down into the solution without turning the shaver on as usual to geget the full cleaning. The Cleaning ligh and the charging light on the Jet Clean System continuously flash. The Cleaning light flashes 3 times and pauses then 3 mre times and pauses, which keeps repeating. The Chargng light flashes, which is supposed to turn off when charging then turn on again when cleaning is finished. Is there anything that would cause this?
  • Anonymous Nov 04, 2007
I had the exact same problem. Then I put more solution in so that it was just above the MAX line and it worked fine. So make sure you have enough cleaning solution in the system and it should work great.
Posted on Jan 30, 2008
Replacement heads for a Norelco 8160XL
Replacement heads for electric shaver 8160xl is philips norelco HQ9 speedxL replacement heads.
http://www.menelectricrazor.com/norelco-8160xl-replacement-heads/
Nov 30, 2012 | Norelco 8160XLCC Electric Shaver
The norelco shaver i have does not shave
If the shaver is running ok but does not shave well, the blades either need cleaned or replaced.
You will find replacements for 8175XL model at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq9-replacement-heads-p-252.html
Scroll down the page for tutorial video showing how to remove blades for cleaning or installation
Oct 07, 2011 | Philips Norelco 8175XL Electric Shaver
How much volts and ampere battery it needs to replace
Model 8160XL (8160XLCC) uses a lithium ion battery. You will find the correct replacement battery at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-8100-series-liion-battery-cell-p-578.html
Aug 23, 2011 | Norelco 8160XLCC Electric Shaver
Norelco 8160xl jet cleaner. The top of the jet clean assembly came apart, is there any kind of manual, or parts catalouge that indicates reassembly?
Go to:
http://download.p4c.philips.com/files/8/8160xlcc_40/8160xlcc_40_dfu_aen.pdf
This is the only manual I have been able to find. Hope this helps.
Jul 09, 2011 | Norelco 8160XLCC Electric Shaver
I've purchased new blades for my Arctic. they did fine until they got clogged. what can i do to clean my blades? this IS a problem. if i can't find a solution i can't purchase norelco again. please...
It's a hack, but you can use needle nose plyers to let you pry open those razor blade heads to clean the blades inside the heads. My Arcitec shaver stopped working after being clogged, rather than pay $50 for new blades, I just opened it up, took out the blades and cleaned it with an old toothbrush and soap.
803a8aba-577b-4dd5-b52e-ae7a2458bab2.jpg 5ad496c8-7607-44bc-a579-a1f98a4246fb.jpg c362edfb-fb3e-4c00-8221-99b8a095d1d7.jpg
Nov 06, 2010 | Norelco Arcitec Electric Shaver with Jet...
Red light came on in the form of the heads. Is it time to replace
This means that it is time to change the shaving heads. You will find Arcitec replacements at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Jun 11, 2010 | Norelco Arcitec Electric Shaver -...
How much Jet clean solution do i use in the Norelco Jet clean system? Is it straight solution to the line or a mix of solution and water?
The solution should not be deluted. You should fill the basin to the 'fill line' with the Jet Clean solution.
Jet Clean solution can be purchased at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-hq200-smart-touch-jet-clean-solution-p-258.html
If you do not know where th fill line is on your cleaning station, refer to your user manual. I would offer a link to the user manual but you did not state the specific model number of your shaver/
Apr 08, 2010 | Norelco Health & Beauty
Norelco 8160XLCC Electric Shaver Logo
1,338 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Andrew Taylor
Andrew Taylor
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
