My Medion E1210 notebook won't start up
I was using my net book when the power went so i pluged it into the mains but now it won't power up, i have the green light on showing that it is conected to the mains but the green power button does not work which means computer does't work can anybody help me with this problem thanks
  • 406 Answers
SOURCE: Acer notebook not working
Remove battery connect power(A/C) then system should work. If not change RAM display should come.
Regards
rafique
Posted on Feb 14, 2008
SOURCE: eMachine Model T3828 No power
Greetings! As the first answer suggests, you must be comfortable taking things apart. I've actually just finished diagnosing the same problem on a customer's computer, and Here's what I did.
First, I remove the power plug, open up the computer, and inspect the caps (capacitors). If any of them are 'leaking' or 'bulging' or becoming 'pointy', then you are done, your motherboard is at fault for certain. If not, then I continue ...
Second, I have a power supply tester, something you can get at most small mom's-n-pop's computer stores, or online at newegg.com or tigerdirect.com for as little as $25 to $50. I unplug the power supply from the motherboard, both the 20-24 pin connector and the 4-8 pin connector (the 12 volt supply on newer systems 4-5 years old or newer). I plug these into the tester, and test the power supply by plugging the power back into the power supply. If all of the lights on this tester come on, then the power supply works. If they don't, or if they do, but you can smell a rancid burn't smell coming from the power supply when you put your nose next to it, then the power supply is shot. This would be a good time to have another power supply to use to test with the current setup, simply setting atop the current power supply, and replacing the plugs so that the working test power supply is plugged into everything instead, and if that powers the system and it turns on, then you know the power supply is the faulty part.
Next, if the power supply is good, or the test power supply doesn't turn the system on, then I continue to testing the motherboard. I have a POST tester to use for this, but you may not want to spend the $50 on this, and it's rather complicated, so now remove everything from the motherboard except the CPU, RAM, and HDD. this means remove any NIC's, Modems, CD drives, anything and everything. Now try with the test power supply connected to power the machine. If it starts, then it's one of the other parts. if it doesn't, then remove the HDD. Try again. If nothing, then remove the RAM and try again.
If nothing, then the last resort is to remove the CPU heatsink/fan, inspect the CPU, and remove and re-seat the CPU. This step in my opinion should require at least some prior experience with CPU's, and I would suggest having a can of CPU cleaner and a tube of CPU thermal grease to replace the now exposed thermal grease. The reason I would suggest prior CPU experience, is that the thermal grease is 110% necesary for the heat to transfer to the heatsink, and while others may disagree, there is a too much, and it's not a good thing. You need only a very small thin layer of thermal grease, only around 100th of an inch thick, even thinner.
So once re-seating the CPU, re-connect the heatsink and cpu, and try again. Then begin connecting parts one at a time, starting with the RAM, then the HDD, then the optical drive, etc, until either it starts, or everything's plugged in and it doesn't. Sometimes in odd situations, the system will not start with just the CPU, RAM, and HDD, while it will if you add the NIC or the Optical drive. In these strange cases, there's usually something wrong with the motherboard, cpu, or ram, and you'll want to find out from a profesional, or simply replace the motherboard.
In this most recent case I diagnosed with my customer's computer, the motherboard was faulty, with no visible evidence of damage. E-Machine computers most common problem are the motherboard and the power supply. In my experience with my own company, and with the last two computer shops I worked with, E-Machine's have these problems usually at least once within the first year, covered under the Manufacturer Warranty, and then once again after about 5-6 months past the first year. This is due to the cheaper quality parts, cheaper quality soldering, and cheaper construction in general of E-Machines. E-Machine can produce a much less expensive product, though this becomes evident in the quality and expected lifetime of the product.
Sorry to write a novel, but I hope this helps give some perspective on what is done by a technician. Realize, As I work on diagnosing a problem, I'm thinking of a lot more things than just what I've written here, this is just a general synopsis of what I'm doing when I diagnose a system, and should just be used for general diagnostics in the home, or as a begginers basis for working out problems.
Posted on May 12, 2009
  • 29 Answers
SOURCE: Help! Western Digital My Book Does Not Work
possibly the firmware is corrupted,u need some tools to repair it.or go 2 the professional dr company
Posted on May 19, 2009
Jack_Dawson
  • 287 Answers
SOURCE: Notebook stuck before POST
problem in BIOS (POST), update it!
Posted on Dec 30, 2009
  • 3940 Answers
SOURCE: medion akoya e1210 notebook. failure to boot pxe
Failure to boot PXE 061 is a BIOS message that indicates 2 things:
  1. System failed to boot to the hard drive
  2. System failed to boot to a network connection
The apparent problem is failure to boot to the hard disk. If the system was running yesterday and there have been no hardware changes to the system, then most likely failures are:
  1. HDD failure (Replace the HDD, reinstall OS and applications) I hope you have information backed up.
  2. HDD not being detected by the motherboard due to connection issue (Remove HDD and reseat it, then see if seen in BIOS) If no change replace hard drive, if new drive not seen, replace motherboard
Posted on Jan 11, 2010
Testimonial: " many thanks will get it looked at"
Medion e1210 factory setting
Usually, if the recovery partition is still intact, pressing F8 just before it boots and selecting restore does the job. All data will be erased permanently!
Jan 24, 2015 | Medion Computers & Internet
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
Neato vacumm won't turn on
Here is a video showing a quick temporary fix and the full fix showing the change of all the electrolytic capacitors.
Apr 17, 2013 | Neato Vacuums
Aspire ahows green light but won't start up, have turned off main but still just green shows
Pull the plug from the AC outlet, wait a 30 seconds, plug in, try to reboot. Does it try to start and in a few seconds shut down? Give as much detail as you can.
Dec 19, 2012 | Acer Aspireā„¢ T135 PC Desktop
My net book won't boot but the power lights are on. I waited almost a day for it to boot but nothing happens It doesn't dispaly anything.What happen.
Try turning off the laptop, unplugging it, pulling out the battery and holding power down for 30-60 seconds. After that's done, put the battery back in, plug it back in, and turn it on.
Oct 19, 2012 | ASUS Eee PC 1000H Laptop
Battery completed drained, now won't start up even with A/C power
If it is not opening with AC power that is the not fault of battery instead of main chip on the motherboard, so you need to check it and take it a very good laptop technician.
Good Luck
Aug 21, 2012 | Medion MD 96340 PC Notebook
Pioneer Rear Projection TV problems
a 240 ac voltage appliance will run happily on 220 volts but ther is obviously a fault as the green spark was possibly a fuse blowing
ie main fuse as power is not reaching the tv
Aug 14, 2012 | Pioneer SD-533HD5 53" Rear Projection HDTV
My electric windows won't work on 2002 VW Pointer no fuse schematic available
look in your owners manual,it will tell you the location of the fuse box and main block. if it doesn't show the what each fuse controls in the book,they should be listed on the covers of the boxes
Jan 28, 2012 | Cars & Trucks
My del star ds 700 net book won't turn on
i guess it has virus or its battery aint working go get it checked
Jan 27, 2012 | Cars & Trucks
Computers & Internet Logo
David Payne
David Payne
