Question about Refrigerators
GE Refridgerator howling noise from evaporator fan- older model #TBX 18 SG
  • 183 Answers
SOURCE: Howling - Which is the correct fix
Suggest a defrost with doors open over night, what often happens with this model is that you get an ice build up near the fan which causes an extremly loud noise, very common problem.
Posted on Sep 01, 2007
Master_Tech
  • 770 Answers
SOURCE: noise
this fan is a variable speed and is controlled by a board in the rear of the unit. your bearings maybe going out. The fan will ramp up to speed depending on the call for cooling the Thermistors is asking for
Posted on May 20, 2008
Big Poppa Ma
  • 302 Answers
SOURCE: Fan noise in freezer of my GE side-by-side refridgerator
You don't have to worry about the ice and frost, Your heater does that for you Your heater comes on and defrost every day. You just need to tighten the screws and clean up the vent where the noise is coming from but I wouldn't worry about it. The temperature on your fridge and freezer is running optimal, You know the saying, if it ain't broke, don't try to fix it....just tap the vent covers every few days.
Posted on Dec 06, 2008
SOURCE: My GE side by side refridgerator makes a "howling" sound. Any ideas?
the problem you are having is in the main control board. ge has had a problem with this part causing the fan motor to go into high and low speed which causes the howling noise. unfortunately it is a costly fix, around $125 for the part. if you are savy to changing this part it is a matter of unplgging about 5 connections and replugging them. the new board has an extra set of pin that nothing connects to. READ the instuctions and it is a simple fix, saving about $50-60 in labor costs.
Posted on Dec 09, 2008
  • 29 Answers
SOURCE: evaporator freezing up on my ge gss25tsrd refridgerator
YOU CAN SEE HEAVY FROST ON THE REAR OF FREEZER WALL?
Posted on Jan 29, 2009
GE model GSS22JERF BB keep hearing loud howling noise coming from the freezer size. Don't know the cause
Uh-huh... Ivy Joseph,
Well ...
unless your cat is missing that characterization is going to need some EXPANSION... clarification... definition.
The door is open/closed has no impact on "howling"...??
The unit is OTHERWISE WORKING... (????)
or some issues have accumulated to attract your attention.
Your diagram shows a pretty standard side x side configuration...
a "WORKING" refrigerator won't be howling. An iced up refrigerator can encase the EVAPORATOR FAN... and the howling will be that fan shaft spinning in a FROZEN FAN.
The noise should stop on OPENING the door...
Iced up... can come from several sources
- huge air intrusion
- Defrost circuit failure
Go to the location below to get an idea of how our machine fits together...
The part depicted is the second LEAST LIKELY
failure point (defrost thermostat)... First least likely
is the defrost heater element...
Most likely... DEFROST TIMER (or PCB)
Hope this helps... comment me back with progress questions (I'm usually here daily)
appliance parts
Search Over 2 1 Million Appliance Parts
defrost-limiter-thermostat (and video)
http://www.appliancepartspros.com/ge-defrost-limiter-thermostat-wr50x10068-ap3884317.html
Partsselect
PartSelect Appliance Parts and Repair Help
Jan 05, 2017 | GE Refrigerators
Howling noise from freezer fan, GE side-by-side
Replace the fan, Remove the evaporator cover in the back of freezer, and probably another cover for the fan. Unplug your refer first. Usually their are two screws holding the fan bracket to the wall or mount. disconnect the wires, and replace. Their is a newer model evap fan motor that does not have wiring terminals to disconnect, it is hard wired together and you have to practically remove everything in the freezer compartment to get at it. You have to cut wiring and splice the new fan motor in. Fairly tough job. Usually an evaporator fan motor bearing fails from the refer being moved or in storage for a few days at least with the doors closed and the unit unplugged. This allows all that moisture that was in the freezer to get into the metal parts of the fan motor and cause this problem. To prevent this always block the doors open if your refer is going to be off for a few days. This will allow the unit to dry out without damage. Sometimes it was just a bad motor from the factory. Good Luck, Appliance Specialists
Dec 17, 2009 | GE GSF25XGR Side by Side Refrigerator
My fridge is howling pretty loudly when ever it runs , the howling is coming from behind the ice maker turned the ic e maker off but unit st ill howls what s wrong
Hi, It sounds like the evaporator fan motor is going bad or there is frost building up and hitting the fan blade.
Unplug the refrigerator and remove the rear panel inside the freezer and locate the fan.
You can plug the refrigerator in and see if the fan is making the noise.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whining/howling on freezer side
Need to unplug the refrigerator and remove the cover inside freezer compartment. Sounds like the evaporator fan is hitting something and we need to resolve this as soon as possible. Thanks Sea Breeze
Mar 26, 2009 | GE Refrigerators
GE GSL25JFR Freezer fan noise.
Replace the fan motor is my guess to cure the noise.
Mar 01, 2017 | GE Profile¿ 42" Built-In Side-by-Side...
Howling noise in the evaporator fan motor
Bad computer board in back of fridge, unable to control motor speed causing motor to hunt
Nov 02, 2008 | GE GSS25JEMWW Side by Side
Sep 08, 2008 | GE GSH22SGRSS Side by Side Refrigerator
Noise
May 20, 2008 | GE GSS22JFMWW Side by Side Refrigerator
Noise
I believe you will trace this noise back to the evaporator fan motor inside the freezer making the noise. If you agree that the noise is coming from the evaporator fan motor inside the freezer it is not the motor that is responsible. Your model has a Main Mother Board on the outside rear wall of the freezer down low (about 10 screws hold square cover on over board). The Main Board is causing your noisy evaporator fan motor. Use caution when handling any electronic circuit board. Follow antistatic cautions. Static electricity in your body can damage these valuable circuit boards.
Nov 10, 2007 | Hotpoint HSS25GFP Side by Side...
I think I have the same problem. The unit is also about 2 years old (GSH25KGRBB). I have an extended warranty. They already replaced the controller card. I see it is the exact part number you have mentioned. It seemed to help for awhile but I think it has gotten worse again. The noise is more consistent after they changed the board. Less revving up to "turbo" mode. Howling is a good description. I can hear it now, on the other side of the house. I would change the fan out. I think they did the board first because it probably is easier even if the part cost is higher. I will probably call them back again. This will be the third time. The first time they just changed the little flapper on the ice dispenser. Otherwise the unit cools and runs flawlessly.
Aug 11, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
