Unable to get 1440 x 900 resolution with onboard graphics.
ECS 661FX-M motherboard. Bios Phoenix 6.00PG Ver. 1.01 is latest available for this model so I can't get onboard graphics upgrade to 1440 x 900. Only VGA available in BIOS setup.
Intel Celeron D
AGP3 slot 8x/4x support.
Would a Graphics Card with DVI be a solution?
Is an ASUS A9250/TD/128M AGP Graphics Card with DVI ouput compatible and would it solve my problem?
  • brianarbon Jan 04, 2009
    Thanks for advice Morriss, however I can't upgrade current graphics driver unless I update my BIOS. My BIOS is original and the latest 2005 version and there is no later version available, so I am stuck with 1280 x 1024 max res and a distorted image.
    Will I get wide screen resolution from a Graphics card even though my BIOS may not support it? Most AGP graphics cards don't even list 1440 x 900.
    Scholar:
  • 40 Answers
Yes, through bios you can only select VGA but it wont have any effect on what you see on windows, so let bios aside. Is through Windows Display properties that you select all the different resolutions... (RIGHT CLIC YOUR MOUSE OVER THE DESKTOP, SELECT PROPERTIES AND LOOK FOR THE SETTINGS TAB ON TOP, MOVE THE SLIDER AT THE MIDDLE TO SELECT RESOLUTIONS) in windows is where you should have the latest drivers from ECS (now PCCHIPS) for your motherboard's onboard graphics. 1440x900 is widescreen type resolution, only available rather recently by new monitors that support it and so I guess it wasn't included in your original motherboard driver CD. Then it's a must to have the new drivers installed and the monitor's plug and play recognized by windows in order to attain the desired resolution from the card.
Any new AGP video card will be far better than the onboard type. DVI is just a digital type of conector and doesn't have to do with the resolution selection, but it will make the images in the monitor show a little better since there is no signal degradation in digital transfer through the monitor cable.
Posted on Jan 04, 2009
  • Mauricio Garcia
    Mauricio Garcia Jan 05, 2009
    There's no need to update your bios in order to install and use a new video card, video cards are almost stand alone from your motherboard bios. They have their own little bios inside (that you don't need to modify) that sometimes you'll able to see while booting just before the motherboard bios loads!
    Yes, you will get your widescreen resolutions from any respectable new video card, once you install the card and windows detect your monitor, the widescreen resolutions should appear for you to select.
    A personal recommendation if you like ati processor video cards are the X1300 series AGP cards.
    Finally it took me soome time but you might want to take a look at Display Changer, a program you run the old fashioned way (DOS style) but works on windows its a freeware. You may be able to force the 1440x900 resolution to your actual card with no problem.
    look for it at 12noon.com which has other simple safe programs
    But the best of all (I used to use a lot this program like 5 years ago and I can't believe it's still available and up to date!) its called PowerStrip, from EnTech Taiwan. Try this one first! its free too!
    Look for it at www.entechtaiwan.com
ATI Radeon HD 3600 Series video card this card displays this resolution.
Posted on Sep 18, 2009
What kind is a video card?
Here are the specs. It has on-board graphics chip. http://www.motherboard.cz/mb/ecs/661FX-M.htm
If you want to find a compatible video card, you could ask here. http://www.ecs.com.tw/ECSWebSite/Support/Technical_Support_List.aspx?MenuID=50&LanID=0
Jun 29, 2014 | EliteGroup ECS 661FX-M P4 FSB800 DDR400...
Does a core 2 duo processor work on an ecs 661FX-M7 motherboard?
Your motherboard was set up for a pentium 4 or celeron d only and neither are dual cores, So the short answer is no,'
But there are many 3+ ghz celeron d's that are less then 50 online
Oct 06, 2010 | EliteGroup ECS 661FX-M7 SiS 661FX Chipset...
Im looking for all drivers for mercury kobian 740 ecs?
here it is...
http://www.ecs.com.tw/ECSWebSite/Downloads/Category_Download.aspx?MenuID=6&LanID=0
select motherboard in the 1st drop down
select lga 775 in the next drop down
select 661fx-m7
select ver number in the next drop down
click submit
and there we go
please rate the service you have recieved
Apr 24, 2009 | EliteGroup ECS 661FX-M7 SiS 661FX Chipset...
Installed a new Saphirre Radeon x1650 512mb, 128bit, AGP 8x card. But I am not seeing a significant increase over the onboard graphics. The card install sheet says to Disable the onboard video, but I don't...
In your BIOS on the main screen choose INTEGRATED PERIPHERIALS (get a copy of your manual here if you don't have one), then go to INIT DISPLAY FIRST, and choose AGP. It's not clear from the manual if AGP is an available option, choose PCI slot if it is not. ECS is notoriously sloppy with their BIOS programming.
While you are in the BIOS, under ADVANCED CHIPSET FEATURES choose AGP &P2P BRIDGE CONTROL then make sure your AGP DATA RATE is set to auto.
Apr 16, 2009 | EliteGroup 661FX-M7 (661FXM7V11)...
Ecs p4vmm2 v1.0 motherboard windows xp sp2 can`t get sound to work onboardsound
1st: try enabling the onboard audio devices from the bios setup menu. it should be somewhere in the on board menus.
2nd: try installing the latest drivers from ECS
i did not manage to find the motherboard model you specified. i did manage to come up with these:
p4vmm2[v1.1] drivers http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=46&DetailName=Driver&DetailDesc=P4VMM2%20%20(V1.1A)&CategoryID=1&MenuID=82&LanID=0
and also p4vmm[v1.0] drivers
please re-check the specific model you have and download the driver that suits you
Mar 02, 2009 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
POST-Beep-Code List availible for Phoenix-BIOS? ECS 755-A2
The problem is with your RAM. Try installing the RAM in another slot. Install your AGP card slowly. I can assure about your motherboard yet you have no problem without assembling. Keep informing.
Feb 22, 2009 | EliteGroup SiS755 (755-A2 V1.0)...
Is visiontek a radeon hd 2400 pro agp 8 compatible w/ p4s800- mx?
ATI has recently written some better drivers for the 2400 Pro AGP cards,... Make sure the setting in the BIOS for the motherboard is set to the AGP or PCI for primary video. For AGP, make sure that you have the power from the power supply connected to the video card. Make sure that your motherboard does support 8X AGP video cards. If you are not sure, please check with motherboard manufacturer for compatibility.
Dec 13, 2008 | VisionTek ATI RADEON HD2400 Pro Edition...
No picture at all
Hi geminip3, you need to make a couple bios changes when using a PCI-E graphics card. Still have your manual? Go to page 36. Advanced Chipset Features. Onboard GPU (Enable If No Ext GPU). By adding a PCI-E card this should be set to Disable. Than go to page 44. Init Display First (PCI Slot), set this to [PCI-E]. Read each page.
Than save your bios & exit. The system will auto restart. If you do not see display, wait about a minute & remove the monitor cable to the second out put slot. Some PCI-E cards need more power than the PCI-E motherboard slot can provide. You may find a power port on the PCI-E card. Some look just like the power cord for a floppy, others look like the power cord for an IDE hard disk drive. The latest ones are black in color & one end connects to an opened 4-pin molex (IDE power cord). Let’s address the onboard video card. (No PCI-E card attached). Back to page 36. Onboard GPU should be set to [Enable]. Page 44. Set Init Display First to [VGA/PCI]. Page 45. PCI/VGA Palette Snoop, set to [Disable]. I was unable to find where in the bios one can set the amount of system memory to run the onboard VGA. ECS manual is not the easiest to work with. Note: Ihave worked on other ECS MB's & though the above information has worked out ok for some, its not worked out for others. If the above suggestions do not work out, suggest you call ECS tech. I have emailed ECS stating their manual is confusing & asked for them to explain bios settings for VGA & PCI-E. Correct bios settings for your MB & user jrl1261's MB GeForce6199PM-M2. If the above settings do not work out. Don't fret. ECS wil get back to me & I'll post their email here.
Mike
Aug 10, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
Where could i find BIOS Jumper for mother elitegroup 661fx-m7?
Hi MATTOTECH, when you receive a reply from a tech or wish to continue the post with the same tech do this. When you log into Fixya go to you're profile, listed there will be you're question. Open that question & continue / post more question (s). When you create another question like above, you will not get the same tech.
MATTOTECH if you do not have you're user manual for the ECS 661FX-M7 (V1.1) motherboard. You can download it from this link. http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=476&DetailName=Manual&MenuID=44&LanID=0
Create a folder on you're desktop & give it a name. Download the manual, file name 661FX-M7.zip into the folder. Uncompress the file within the same folder. You will need Adobe PDF reader to view the pdf manual. If you do not have Adobe reader you can download it for free here. http://www.download.com/Adobe-Reader/3000-2378_4-10000062.html?hhTest=1
Go to page 4 which will show you a picture of the board. Each item is numbered. Page 5 will describe each number.
Number 6 is the bios jumper. Than go to page 9. This will show you how to set the jumper to clear the bios/cmos. (Leave it in the clear position for 15 seconds), than move the jumper back to pins 2 & 3, its normal position.
EliteGroup 661FX-M7 (V1.1) main web site
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?DetailID=476&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
Mike
Jul 25, 2008 | EliteGroup 661FX-M7 (661FXM7V11)...
Computers & Internet Logo
2,504 people viewed this question
David Payne
David Payne
