Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Western Digital My Book Essential Edition 500 GB
My new (1 month) My Book does not "light up" when I plug it in. It obviously isn't getting any power. It doesn't seem to be the power cord itself, at it works fine with another drive of the same model, etc. Is it possible that this problem can be repaired, or more importantly can my files still be accessed? Help, I'm a teacher, and I need those files.
  • rai_vuong Sep 09, 2008
    My My Book only flashes when i plug the power cord in and it's not connecting to my computer, plz help i hav important files on it.
  • joylene6 May 11, 2010
    how do you plug the SATA directly in to your computer? My case broke and I want to get the files off the hard drive.
I don't want to seem too simplistic, but before taking any drastic measure, try the following: with the firewire cable disconnected, plug the DC in and then connect the drive with the computer (should be on) using the firewire. I hope it helps.
Posted on Feb 05, 2008
    Scholar:
  • 59 Answers
The 500gb is RAID, at least the one i bought yesterday is, the drive or drives out and install them in the other enclosure and try using that, you must move any and all drives in the my book at the same time, if there are more than one then it is RAID and the data is spread across both drives(files can be half on one drive and half on the other or and other combination of fractions) if you don't think your up to the task of cracking these open and possibly voiding any warranty you may have then by all means do not, have someone with experience with this do it for you if possible or else at the very least egister the product on western digital's website and see if it has a warranty and get it replaced or upgraded, the latter will probably cost some cash but you will get a discount for upgrading old hardware.this may not be much help but its about the best i could offer over the internet, hopefully this helps you or someone at least a little
Posted on May 21, 2007
    Problem Solver:
  • 6 Answers
Hi Bawhee, Following is the link which will help you dismantle the case and will enable you to pull the hard drive out of it, you can either then submit the case to Western digital for repair or check for yourself, hopefully the data shud be safe, cause the hard drive case by WD uses a power unit of its own independent of the drive. http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1464&p_created=1158253904&p_sid=B*O5p2Ci&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzgmcF9wcm9kcz0yMDksMCZwX2NhdHM9MTIzJnBfcHY9MS4yMDkmcF9jdj0xLjEyMyZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX2ZubCZwX3BhZ2U9NA**&p_li=&p_topview=1 You can, after dismantling pull out the SATA hard drive and either plug it in directly into your computer or the other wd unit you have by replacing the hard drive inside it. There are more instructions on the WD site if this MYBOOK was part of a RAID. Hope it helps Mutahir
Posted on May 20, 2007
SOURCE:
WHAT IS THE INPUT OF 500 GB MY BOOK ESSENTIAL EDITION?
AC INPUT VOLTAGE - 100-240VAC
AC INPUT FREQUENCY - 47-63 Hz
Jun 08, 2010 | Western Digital My Book Essential 1TB...
We purchase western digital 500 gb hdd when pc is
The blinking of the lights is just the indication that data is being accessed.
Mar 19, 2010 | Western Digital My Book Essential Edition...
I haveProblems with Western Digital My Book Essential Edition 500.They show the USB failed. How can i repair it help me
You would more than likely have to send it in and get it serviced. Or if you can find out if it is just the USB 2.0 cable, then just replace the cable.
Jan 25, 2010 | Western Digital My Book Essential Edition...
My Western Digital My Book Essential Edition 500 GB hard drive was working fine, until the power cord was removed accidentally. Now I can't get any computer to recognize the drive when I plug it in the USB...
Is the power light on, if not replace the power supply.
I f you have light then your hard drive is shot or the circuit inside the box is fried.
If it is out of warranty and you have another Western Digital Sata drive handy you can swap it with the one inside to see if the drive is bad.
Good luck.
Dec 21, 2009 | Western Digital My Book Essential Edition...
Power cord replacement needed
Is the product still under warranty? You can try http://support.wdc.com/warranty/index_end.asp?lang=en which is the Western Digital Warranty Support pages.
Mar 18, 2009 | Western Digital My Book Home Edition 500...
No Power to new 640 My Book Drive
John, Ejected or unmounted may be the difference.  Have you added the drive?  If you only power it up occasionally for back-ups you would leave it off, but for everyday use once it is added you can just leave it on and after you power down then turn it off.  randy320sgi
Jan 16, 2009 | Western Digital My Book Essential Edition...
Connection problems with my Western Digital MyBook EE 2.0 320 GB.
Go to Programs and Devices and see if your Western Digital MyBook is even listed on your computer.
Jun 28, 2017 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition 320 gb
sure..is it under warranty...the power supply would be best replaced by a trained person
Oct 09, 2008 | Western Digital My Book Essential Edition...
How do I know that the My Book Essential Edition is working?
You should be able to here the disk spinning when it is plugged into a computer and power supply.
Apr 23, 2008 | Western Digital My Book Essential Edition...
Compuer doesnot see the my book
Only the Proedition2 and the studio edition are formatted for a mac
Feb 13, 2008 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
1,953 people viewed this question
Top Western Digital Computers & Internet Experts
Alun Cox
Marvin
Marvin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
