Question about Whirlpool GT2SHKXLS Top Freezer Refrigerator
We bought a GT2SHMXMSO4 fridge about a year and a half ago. I noticed several months ago that the plastic edging in front og the glass shelves and the shelves in the door are all cracking in the middle.
  • FrancesWD Apr 18, 2009
    Our Whirlpool refrigerator, GT2SHMXMS04, has a cracked shelf and is only 18 months old. And our household has two adults so the cracking is not from overuse or kids. .... Very dissapointed. ....
    Fran
    Lexington, Ky
Amigaman
  • 248 Answers
SOURCE: Whirlpool refrigerator w/ top freeezer
It has a plugged defrost drain. You may need to defrost for 24 hours with unit unplugged and doors open. UNPLUG FIRST!! f still leaks, you need to remove floor of freezer, then the back wall of freezer. Remove ice. At center rear under coils is the drain hole that is plugged up. Use hair dryer to melt ice. Pour hot water in this area to uncover drain. With hot water in area, you can put a 1/4 diam. hose or copper pipe in drain and blow into it while pressing down. It will slowly go through ice, clearing drain.
Posted on Nov 18, 2007
  • 518 Answers
SOURCE: fridge parts broken
Try checking HERE.
Hope that gets ya fixed up...
Geno
Posted on Mar 24, 2008
mikedurland
  • 481 Answers
SOURCE: front metal piece that the seal goes against - between freezer and fridge
clean the coils under the machine and make sure the airflow under the machine is not obstructed at all.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 23, 2008
SOURCE: I have an american fridge model FRS-T20DA. Out of
A computer expert friend suggested I turned the fridge off and on again. Like you do sometimes with computers where nothing else works. Well couldn't reach the plug, but this morning the electricity went off. Whenit came back on again this aft, all the buttons were working again! Magic.
However, still do not know where I can order new shelves. Can you help with that?
Posted on Feb 15, 2010
Sebin
  • 712 Answers
SOURCE: wHIRLPOOL SIDE BY SIDE fridge GD25DFXFW 10 YRS
Get your refrigerator repainted before it is too late. It isn't that costly. Cracks may be due to rusting. Ask those mechanics about it when you give it for painting.
Posted on Apr 21, 2010
RF197ACRS Samsung fridge How to remove glass from the shelves to clean
Well, I don't know about the individual shelves, but for the long glass shelf above the crisper drawers, there are two white clips located at the back edges of the glass that need to be pried out with a knife blade, or something similar. Place your blade in between one of the grooves of where the clip meets the plastic frame (and, NOT between the clip and glass! ) and pry the clip with a bit of a sideways motion. It's a little stubborn, but if you break a clip, don't worry, you really don't need it for the shelf to function.
Anyway, after you pry up the two corner clips, lift and slide the glass toward the back to get it out of the front groove, and voila!, the glass comes right out.
Aug 14, 2015 | Samsung / RF197ACRS
How to remove the glass shelf for better cleaning PSC25MSSC
if the glass has plastict trim like pieces across the front and rear edges try pushing up on the glass close to the plastic trimat th rear end, the trim should swivel up and the glass pop out of the groove
May 03, 2015 | GE Refrigerators
Mp450 docking station no sound not charging
It's very likely the wires that go inside were worn out or cut by the internal plastic edges. It happened to mine. I removed the soft plastic at where it rotates and noticed that the wires were cut but the internal plastic edges. If you bought it less than one year ago, Altec is replacing them. If not, check if you got an extended warranty through the store or your credit card company.
Aug 31, 2011 | Altec Lansing Audio Players & Recorders
I have a whirlpool refrigerator, model GR9FHMXPQ. I got it about 4 years ago. When it was delivered, it had several pieces of styrofoam lodged in the inside ceiling of the fridge section (below the freezer...
You need to remove all of the styrofoam packing material.
Any insulation material would be installed inside the body of the fridge/freezer. The packing material is there so anything inside the compartment (like metal shelves, plastic holders, etc. don't bounce around during shipping and either scratch up the interior, or break. That is all that it is there for.
Apr 25, 2017 | Whirlpool GR9FHMXPS Stainless Steel Top...
8 year old Whirlpool Gold refrigerator: Freezer icing up. Found ice on shelves and on the bottom under the vegetable hydrators. The shelves and drawers constantly have a humid film on them. Last week,...
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
Oct 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Bought in Nov 2007 online from circuit City. Has
Change printheads,Issue will not get fixed then its a hardware failure.
Jul 11, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Samsung Cooltech spare shelves available in b'lore??
it is possibly cheaper to go to a glass firm and get glass cut and edges polished to fit than it would be to buy replacement shelves.the mark up is horrendous on any spare parts......
Apr 20, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Feb 14, 2010 | Daewoo Refrigerators
Water on btm of glass shelves and water in bottom of frig
sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
Jan 07, 2009 | Kenmore 72073 Top Freezer Refrigerator
Smelly water from door dispensor
I had the same problem. Drove me crazy and cost me about 5 filters at $50 a pop until I found the solultion. Water in the Sears/LG refrigerator that I have (french door trio) goes through the filter then into a container on the left front door of the refrigerator. That container stores the water so it can get cold and it also equalizes the flows in the system so that when you put your glass under the spigot the flow is steady and the water is cold. Problem is .... this tank can build up with algae/slime/foul tasting stuff. Since it is after the filter, no matter how many times you change the filter it will have no impact on the water in this container. That is why if you use the water spigot a lot, the water seems to get a little better (as the tank water gets diluted) but as soon as you don't use it for several hours or more, back comes the smelly water again. Solution for me was to remove the plastic panel on the inside of the left front door and clean the plastic bottle. It is pretty easy to remove with 2 screws and easy to pull off the hoses. I filled is with a little clorox and water and swished it around for several minutes then drained and rinsed it. Then I filled it again with a little clorox (like an ounce or two max) and put the container back into the fridge. Once in the fridge, I ran fridge water through the front water dispenser for about a gallon or so. This flushed out the chlorine in the plastic container as well as the lines between the container and the spigot. After about a half hour of work, my great tasting water in the fridge is back again. I've checked the taste on this water for several weeks now and no plastic/odor/bad tasting water any more. Hope this helps.
Oct 16, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirlpool GT2SHKXLS Top Freezer Refrigerator Logo
109 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
