Question about Acer Aspire 3680 Laptop
Difficulty with new hard drive on acer 3680
I just installed a new hard drive on my acer. System comes up and says media test failure. Check Cable? Initially it was saying operating system not found. Tried recovery disks as well as back up disks. Absolutely nothing happens. Any ideas? What am I missing? Also downloaded a boot up disk. That did not work either. Thanks for any guidance.
  • sonnyrey Jan 04, 2009
    try reinstalling the os again
    Sergeant:
  • 366 Answers
Check if new drive is installed as Slave.
Only one master drive can be on same cable
setting can be selected with contact on device back if you use a flat cable..
Posted on Jan 04, 2009
Acer Aspire 7741Z 4433 does not see the operating system, new hard drive.
with a new hard drive , ti will not have an operating system installed
turn thr computer on and hold down the delete button until the bios screen comes up
click on the boot tab and set boot priority to first device c
put the cd in the cd drive
switch off the computer and then restart
the boot will now read the cd and reinstall the operating system
when installed go back into the bios and change back to first device --hard drive
May 09, 2017 | Acer Aspire Computers & Internet
Tip
PXE-E61: Media Test Failure
Issue:
My computer gets this message when I try to boot it:
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting Intel PXE ROM.
Solution:
Your computer is set to boot from the network (PXE = Netboot).
Go to your BIOS and make sure you boot from your hard drive.
Remarks:
Shouldn't be enabled by default
[more...]
on Jan 04, 2009 | Acer Aspire 3680 Laptop
STILL SAME PROBLEM
Sounds like your hard drive is either dead or the cable or interface is not making a good connection. The computer cannot read the main hard drive that contains the master boot record and the computer is searching for a boot device. The pxe-e61 is the computer searching for a network drive to boot from. It then goes to the next device in it's menu. Need to check the hard drive and all cables and / or interface connections. Go through the BIOS settings and make sure the computer default settings are reset.
Jun 18, 2010 | Acer Aspire 3680 Laptop
"NO OPRETING SYSTEM IS FOUND""MEDIA TEST FAILURE"
check the HDD or remove the Hard Drive and Make a Replace..Good Luck and Have a nice DAY
Jul 04, 2009 | Acer Aspire 3680 Laptop
Operating system not found media test failure will not reboot aspire 3680
Installing an operating system from one computer and inserting it into another computer will not work specially when they are from different manufacturers because the components in them are different.
The Windows install has to be done on the intended computer.
The media test failure error message refers to a faulty disk controller or a faulty hard disk.
Apr 13, 2009 | Compaq Armada 6500 PC Notebook
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Aug 31, 2008 | Acer Aspire 3680 Laptop
I probably meant to say "reseat" the memory. Just remove the memory module(s) and reinsert them in their slots. This problem can also sometimes be resolved by reseating the hard drive. I had this happen to me just the other night. The laptop slid off of my lap and fell to the floor. Just fell about a foot and a half, and didn't hit all that hard. Kinda partially caught it as it went. But the laptop didn't like it and I had a message of "Operating system not found". Reseating the hard drive had me up and running in about 30 seconds.
Ron-
Jun 22, 2008 | Acer Aspire 3680 Laptop
hi..try to remove unplug or plug in the Hard Drive,, if cant work you or nothing happens you need to re-place the hard drive.about files theirs nothing ways to recover the files if the Hard Drive is totally defective..Thanks..and GOOD LUCK...^_^
Jun 15, 2008 | Acer Aspire 3690-2196 Notebook
CAN NOT GET INTO WINDOWS
Try reseating the memory modules and hard drive and see if this helps. If not, get back to me.
Thanks!
Ron-
Nov 25, 2007 | Acer Aspire 3680 Laptop
Media Test Failure, Check Cable.....
This is an Invalid / Non System Disk error.In your Bios settings change the "First boot device" option to your hard disk.If you have only one hard disk set it to "HDD 0"
Other causes of the problem are:
  1. Floppy or CD that is not bootable is currently in the computer.
  2. Hard disk's power or data cable is not connected properly(loose contact)
Oct 12, 2007 | Acer Aspire L310 (ASL310UD631A) PC...
Acer Aspire 3680 Laptop Logo
75 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
