Ef5 code what does it mean on a lavamat l12843 vit washer
3 Suggested Answers
  • 44 Answers
SOURCE: AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Posted on Mar 21, 2009
  • 4088 Answers
SOURCE: my aeg lavamat L14710 VIT only spins at a very low
Does the machine seem to be draining (pump running) fairly quickly as the spin cycle begins? If not, the machine will sense the high water level and prevent the motor from turning rapidly. Check the drain hoses and pump for clogs, pinched hoses, plugged filter, etc.. Hope this helps!
Posted on Mar 31, 2010
My Lavamat Turbo 11842 VIT door will not open
This usually means that it has not finished draining all the way. IF the unit has a panel under the door that comes off, you can access the drain plug, it will make a mess though. Also there may be a latch release there depending on the model.
Jan 29, 2016 | Washing Machines
How do you take out the filter on a AEG LAVAMAT, 12843 VIT.
HI,SOME TIMES A COIN OR HAIR GRIP CAN JAM UP THE MAIN PART OF THE FILTER,IF YOU CAN IS TO REMOVE THE WHOLE PUMP TO CLEAN IT OUT,POWER OFF BEFORE YOU DO IT ,THANKS.
Jul 04, 2014 | Hotpoint WMA54 Front Load Washer
What means error code "C9" ? AEG Lavamat 74652
C9Motor tacho fault •Check main drive motor •Check tacho magnet •Check tacho coil •Check module
May 27, 2014 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 72 620 What does error code C9?
c9 means the electronics is not detecting any drum movement. check the carbon brushes in the motor this is usual culprit.
Aug 29, 2010 | AEG Lavamat 72640 Front Load Washer
What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Jul 14, 2010 | AEG Lavamat 72640 Front Load Washer
My aeg lavamat L14710 VIT only spins at a very low speed ! does this mean that the motor needs replacing ? how can I verify ?
Mar 31, 2010 | Washing Machines
Hi
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
