Question about Epson Stylus C86 InkJet Printer
My Epson DX7400 won't turn on
My printer is just out of guarantee and won't turn on. I've tried another power lead but it makes no difference.
    Problem Solver:
  • 9 Answers
Funnily enough Ive had a similar problem with another Epson printer recently. I removed the power input unit - involves a bit of dismantling and replaced the on-board fuse. This was a quick blow 2.2 Amp one if I remember correctly. However, the fuse is capped at both ends and rests on the circuit board wire soldered to it. Not a task for the feint hearted! The replacement worked for about a week and then blew the fuse again. Obviously other components on the board were duff - printer scrapped.
Then the customer mentioned it had got damp through an open window and that he'd only had the printer three years ... tum te tum!
Posted on Jan 24, 2009
  • Simon Wheeler Nov 16, 2012
    Hi. I know it is now three years since your post but if you are still around could you tell me what model of Epson printer had the fuse that was replaceable. I've trying to find out if the Epson D120 has such na fuse as two of my printers have died due, I suspect, moisture in the printheads. Maybe I can ressurect them by replacing the fuses. Thanks (simonwheeler_uk@yahoo.co.uk).
My Dell 3115cn printer will not connect to the network (it still works on USB cable), hard to believe it's broken, so can the printer system be reset?
Try turning off the printer and disconnecting power plug from wall. Hold power on button for about a minute. Then replug unit and turn power on - it should then attempt to hook up to your existing network.
If no go, try reinstalling the software that initially came with printer and was used to set up the network
Jan 10, 2017 | Dell Office Equipment & Supplies
Is my new Epson printer compatible with Linux
http://www.openprinting.org/printers
http://www.openprinting.org/printers/manufacturer/Epson
Don't really know you failed to provide the exact model number ????????????????????????????????????????????
see if model number is listed in the above link
Jan 09, 2017 | Epson Office Equipment & Supplies
B&w/gray Scanning Is Okay But Color Scanning Problem
Run ink head cleaner routine. If you cannot the list make and model of printer. Thanks.
Dec 25, 2014 | Office Equipment & Supplies
My Epson WF-3640 is printing with gaps in the text. How do I fix this issue?
Make sure you should remove shipping tape from the ink cartridge. These taps are used to protect printer during shipping but you have to remove it before starting printing. Beacuse these taps prevent the ink to entering in print head. If you will not found shipping tape in your printer then there is terr off strip, remove it. The tear off strip seals the the vent holes on the top of the cartridge to prevent it from drying out on the shelf or during shipping.
After ensuring that the shipping tape has been removed, run the printer's "Head Cleaning" utility to prime the cartridge, then print a test page.
See full detail at- http://guideusermanual.com/product-name-workforce-wf-3640-manual&po=152836&lang=English
Sep 18, 2014 | Epson WorkForce WF-3640 Wireless Color...
Hp laserjet m1522f error 5 turn off and on
Hi, Error 5 is a Scanner error. When turning the printer on, have the lid up so you can watch the scanner movement. Does it move smoothly? It should go through a warm up and you should be able to watch the scanner movement. If there is a problem with the scanner, there isn't a lot you could do except. The service manual says the scanner assembly should be replaced. If it was my printer, I would try to take a closer look at the scanner assembly and check to see if the scanner unit is bound up somewhere, or maybe a drop of 3 in 1 oil on the scanner rails. Let us know what happens.
thanks
Oct 02, 2013 | Office Equipment & Supplies
"Error sent to printer" problem with ZDesigner TLP 2844
have you gone to printers in control panel and made this printer with a tick in it so its the one the computer recognises
Dec 24, 2011 | Office Equipment & Supplies
Why does canon MP258 printer with scanner can't scan japanese yen paper bill amount 10,000. I tried it over 10 times but it stops,. And when i tried US paper bill, it works well. I need some explanation...
When you scan with any scanner it utilised the software with "Optical Character Recognition functions, usually abbreviated to OCR -> OCR is a field of research in pattern recognition, artificial intelligence and computer vision." to scan and record the scanned object, sometimes it does not or cannot recognise certain symbols or characters because of man made software & hardware have its limitations too.
Hope it helps.
Nov 12, 2010 | Office Equipment & Supplies
HP printer psc 2210 all in one
Chances are that you didn't lock down the scanner when you moved the unit. You can attempt to open the unit and move the scanner bar manually to reset it. HPs are very difficult beasts when it comes to their power up check out. It must be fully functional...including all cartridges...to work in most cases. Good luck.
Dec 20, 2007 | Office Equipment & Supplies
Printer won't recognize cartridge
I had the same problem. I'm not sure but I think I replaced the cartridges when the printer was on because I turned the printer off and removed one of the cartridges. When I turned the printer back on it recognized that cartridge but not the others. I turned the printer off again, rmoved all cartiridges and put them back in when the printer was still off. When I turned the printer on again I had no problems. So...try turning off the printer, rmove all cartridges, then put them back in and restart printer. Hope this works for you .
Nov 28, 2007 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus C86 InkJet Printer Logo
652 people viewed this question
Top Epson Office Equipment & Supplies Experts
Michel Smith
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
