Question about Whirlpool LTE5243DQ Combination Washer/Electric Dryer
Whirlpool thin twin washer lint trap?
Washing macine: where is the lint trap? how to clean?
  • 116 Answers
SOURCE: lint trap
There should be a rectangular flap on the top panel at the rear right of your dryer. the lint filter is in a chute if there is just a hole here then the filter is missing.
Posted on Mar 15, 2007
  • 262 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
MAKE SURE YOUR VENT ISNT CLOGGED AND YOU HAVE 220 VOLTS AT THE DRYER IF ALL THIS CHECKS OUT GO TO ELEMENT WHICH IS BEHIND THE LOWER PANEL IN THE FRONT.REMOVE THE PANEL WITH THREE SCREWS ON THE BOTTOM AND TAP DOWN AND OUT AT THE SAME TIME. USE A VOLT OHM METER AND CHECK OHMS ACROSS THE TERMINALS OF THE HEATER IT SHOULD HAVE A OHM READING IF NOT CHANGE HEATER AND OPERATING THERMOSTAT GOOD LUCK
Posted on Dec 16, 2007
  • 15 Answers
SOURCE: whirlpool thin twin dryer starts and stops after 5 seconds
In the back of your thin twin dryer is a small white flat fuse attached with a screw, a clip, and two spade clips and wires. This is a thermal fuse and if tripped will cause your dryer to do nothing. Check with multimeter for continuity and replace if necessary. Also inside machine is a black tubular capacitor that will cause dryer to not run. Again, remove after properly discharging capacitor. Using multimeter check capacitor for continuity and potential. Obviously disconnect all power to machine before even thinking about repair. 240 volts will kill you dead.
Posted on Mar 19, 2008
SOURCE: Whirlpool Gold Dryer GEQ9800PW1
take a screwdriver and push it in below the door at the top of the bottom panel, near each end of the panel, there is a springclip to pry on that that releases the panel and it will fold out and then lift off. then you can get access by removing a few screws.
BE SURE TO UNPLUG BEFORE WORKING ON IT.
Posted on May 18, 2008
IFIXALL
  • 868 Answers
SOURCE: Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
Posted on May 26, 2008
Where is the lint trap and how do i clean it?
If the model number is true in the blue this a top load washer there is no lint trap lint collects on the protrusions on the outer side of the basket and is washed away during the rinse drain spin cycle
Aug 28, 2014 | Whirlpool WTW8600YW 4.6 cu. ft. Cabrio...
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
My calypso machine leave alot of lint on clothing
you have to clean the lint trap before every use. I assume that you know that. also , you need to clean the area where the lint trap is really good, so you dont have a dryer fire.
Aug 25, 2009 | Whirlpool Calypso GVM9959K Top Load Washer
Why does my washing machine leave lint on my clothes? does this type of washer have a lint catcher?
Most washers don't have lint traps, the dryers are expected to. In your type of top loader some simple traps would be located in the top cap of the agitator. They should be cleaned each load, but they only stop the bigger pieces.
Jul 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
HOW DO I CLEAN OUT THE LINT TRAP ? THE MACHINE IS @ 6 YEARS OLD AND NOW I AM HAVING SEWER PROBLEMNS CAUSED BY LINT FROM THE WASHER.
I did not fix the problem, I called a plumber and fixed the sewer. So I will still have a problem with the lint trap on the washer. It is supposed to be self cleaning, but I have my doubts.
Mar 22, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool deut washer - is the a lint screen on washer like the top loading washing? If yes how do you clean and service the lint screen? Thanks.
there s a"button trap" located on the side of your pump assy, behind the lower acess panel ( youll need to remove 3 torx 20 screws from the from bottom of machine ) after emoving the panel oull see the clean out directly in forn t of you. BE WARNED THERE WILL BE WATER behind that acess point grab a towle!!!!
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LTE5243DQ Combination Washer/Electric Dryer Logo
44 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
