Question about Canon EOS 30D Digital Camera with 18-55mm Lens
Built in flash
The built in flash is not working. It will not pop up in low light conditions. Pressing the flash button will not make it pop up either.
  • 3 Answers
Try this:
Basically the there is a little pin in the hotshoe that gets stuck that can be replaced by a 4-5mm piece of paper clip.
It worked for me.
Posted on Sep 26, 2009
  • 2,985 Answers
Have you given it a gentle press down with the button depressed? This will release it sometimes, Other than that it is a repair shop job or send it back if you are able.
Posted on May 25, 2007
My flash stopped working on my nikon coolpix L110..
The Nikon Coolpix is a compact digital camera that is well-suited for amateur to semi-professional photographers. Occasionally, some issues with the built-in flash can occur. If the hardware is damaged, the camera must be taken in for repairs. More often, problems occur because of obstructions or issues with the camera's settings and are easily repairable. Follow the troubleshooting guide to fix the built-in flash.
1.Ensure the Nikon Coolpix digital camera battery is fully charged.
2.Wait several seconds before pressing the shutter-release button if the "Flash Ready" indicator light is flashing red. Press the "Flash Mode" button once or twice to change the flash settings from "Off" to "On" or "Auto" if the "Flash Ready" indicator light is off.
3.Ensure there are no obstructions, like your finger or the camera strap, that are preventing the flash from firing if an error message appears on the display screen and the flash is not firing when the flash mode is set to automatic.
4.Press the flash back into the camera after every photo to ensure the flash always fires in "Auto" mode instead of just in low illumination settings. Press the flash back into the camera to turn off the flash in "Manual" mode; otherwise the flash will continually fire.
5.Change the auto focus setting from "Infinity" to "Auto," "Macro Closeup" or "Self-Timer" by pressing the "Focus Mode" button once, twice or three times to automatically turn the flash back on.
6.Use only Nikon external flash accessories to avoid damage to the built-in flash and camera circuits.
I hope you find it very helpful. Thanks.
Aug 25, 2011 | Nikon COOLPIX L4 Digital Camera
Each time I press the shutter button to take a picture the flash keeps flashing fast on and off 3 bursts of about 10 flashed then it takes a pic ??? help
The built-in flash can function as an autofocus illuminator. This helps with focusing in low-light conditions in the AF mode.
To disable this function, press the menu button, then select service1 menuitem, then AF illuminat., and finally, select OFF.
Aug 20, 2010 | Olympus EVOLT E-410 Digital Camera
How do i switch off flash in canon eos 400d? I do not want to use the flash but it pops up automatically in every mode.
Your camera has a built-in flash and it will pop up automatically in low light or backlit conditions if you are in Basic Zone.
All you have to do is push it back down.
If you set your camera option to P, only the shutter speed and aperture are set. You can then change settings for your flash and other functions.
Oct 25, 2009 | Canon EOS 40D Digital Camera
Why won't the flash on my e500 pop up when the correct button is pressed or when I try to take a picture that requires a flash?
When you take pictures in AUTO, Portrait, Macro or Night scene mode, the built-in flash will automatically pop up in low-light or backlit conditions. If you want to control the flash pop-up, set this function to OFF.
1 Menu [AUTO POP UP]
2 Use control dial to select [ON] or [OFF].
3 Press the Ok
If you are in any other mode the flash will not auto pop up.
Apr 16, 2009 | Olympus EVOLT E-500 Digital Camera
Nikon D40X built in flash doesn't pop up automatically
This is a common fault with the D40x. You will need to contact Nikon for repair details.
Mar 31, 2009 | Nikon D40x Digital Camera
Nikon D100 SLR Built in Flash Repair
That's hard to answer until it is seen by the repair person, a reputable repair shop might be able to cannibalize another camera for the pop up flash parts pretty cheap and you just have to pay his hourly rate (the big variable). If the camera still functions otherwise and even the pop-up flash still works, you may want to go low-tech and hold it down with black electricians tape. You can turn off the flash so it won't want to pop up even in low light situations. If you use a flash attachment it will produce better results anyway. The D100 is a tough camera, lots of photojournalists were the first to embrace it for its durability out in the field. (metal body as opposed to plastic parts)
Jan 07, 2009 | Nikon D100 Digital Camera
Nikon D40 - The built in flash will not ppo-up in auto mode. The only time it works is the manual modes. Are there any settings I don't know about. I'm calling it defective and will return it the store.
With the command dial set to "auto", try to take a shot in low light. The flash should pop up automatically. You can't manually pop it up with the flash button in the auto mode. If it won't pop automatically in low light, then it certainly sounds defective.
Apr 16, 2008 | Cameras
Canon XTi Built in Flash
I found the answer and fixed my flash. Look on
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Feb 09, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon EOS 1000F in-built flash unit
Set camera body for Internal Flash for Pop-Up Flash.
Set camera body for External Flash for parked flash on Hot Shoe.
Nov 08, 2007 | Canon EOS-3 35mm SLR Camera
Built in flash not popping up
Error 05 means - Something is obstructing the built-in flash.... Try to reclean it. Good luck!
May 07, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon EOS 30D Digital Camera with 18-55mm Lens Logo
87 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
