Question about Kenmore 15208 Mechanical Sewing Machine
Kenmore sewing machine model #1813 the thread on the bottom keeps getting all tangled
SOURCE: Kenmore Sewing Machine model # c877.15
I have an old Kenmore and here are the directions from my manual: 1. Draw thread from spool through bobbin winder tension discs. 2. Wind thread around an empty bobbin several times. 3. Place bobbin onto bobbin winder shaft with thread coming from rear of bobbin. Push bobbin winder latch against bobbin until it clicks. 4. Release clutch by turning clutch knob toward you. Start machine.
Posted on Aug 09, 2007
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: Kenmore 10 Sewing Machine
kenmore sewing machines relics
Posted on Jul 13, 2008
Michaelle
  • 65 Answers
SOURCE: need help to thread our sewing machine.
you really must get a manual for this machine.
You can find manuals online for a small price.
At one time some sites had them for free, but I haven't been able to find many recently. sewusa.com has some older ones for free. but not many. you could try the kenmore site as well, if not I'd try to search on dogpile.com (sewing machine manuals)
Just so you know, your manual is the MOST important tool for any sewing machine, and its worth a couple of bucks to get it.
Posted on Jan 24, 2009
WonderTech
  • 268 Answers
SOURCE: my kenmore sewing machine model 385.18221 is not
Here are several solutions to try.
- Re-thread your machine. It may be threaded incorrectly (backwards).
- Raise your feed dogs if your machine has this feature.
- When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
- Reinsert your needle and make sure it goes all the way into the holder and that it’s positioned correctly – usually with the flat side away from the bobbin, but consult your machine’s manual to be sure.
- Change your needle, it may be blunt, bent, or otherwise damaged.
- Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). Make sure your needle is appropriate for the type of thread you’re using.
- Adjust the pressure of your pressure foot. It may be too light for your fabric.
- Change your thread. If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
- Adjust your thread tension, It may be too tight or too loose.
- Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: After changing your needle plate, check to make sure your needle aligns perfectly with the smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope these solutions help you.
Posted on Sep 24, 2009
I have a JC penny sewing machine model # 6912 and my bobbin thread keeps tangling up can you help me
check the upper thread tension as it is not pulling the bottom thread through
May 07, 2015 | Sewing Machines
Kenmore 12493 top thread getting tangled in the shuttle
Adjust top thread tension to match bottom tension.
www.kenmore.com/kenmore-sewing-machines
Jul 13, 2014 | Sewing Machines
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
The bottom thread gets loose and tangles, just the bottom stitsch is not proper
This can happen when the machine is threaded with the presser foot down.
What looks like a problem with the bobbin thread is actually the top thead not seating into the tension control during threading.
When the foot is up, the tension opens and accepts the thead. When the foot is down, the tension is closed and then when you sew, the loose top thead cannot form a tight stitch with the bobbin thread and it is pulled to the bottom.
May 01, 2010 | Kenmore 15358
My Brother XL5130 tangled thread on bottom
Check to ensure that you have routed your bobbin thread properly in the bobbin case.
Mar 27, 2010 | Brother Sewing Machines
Top stitch looks good but bottom is all tangled up.
9 times out of 10 this problem leads to that the person threading it is not threading the the machine correctly. If you know you are then tightned the bottom very small screw on the bobbin case ONR QUARTER turn clockwise. Then make sure that you are putting the bottom thread through the small **** on the bobbin case. Ths should fix your problem
Nov 09, 2009 | Kenmore 19233 Computerized Sewing Machine
Material not moving through sewing machine.
Yours is an oldie (but goodie) mechanical machine. If it has not been given a thorough oiling with fresh, good quality sewing machine oil, then she probably needs some TLC. If the feed dogs are up and the stitch length is set to at least the midway point but the fabric is still not moving through the machine, it could be the feed dogs are seized because the old oil has dried and they are not moving like they should. Following the method below, your machine will be humming along in a day or so. Periodic attention will keep her humming.
Wheel on right side that controls the needle up and down is very tight...
Also, something to remember. When threading the top thread, ALWAYS RAISE the presser foot!
Jul 15, 2017 | Kenmore Sewing Machines
Bobbin tangle
can not thread bobbin...bobbin on top
Jan 16, 2008 | Kenmore 19233 Computerized Sewing Machine
Kenmore model 385. 12912890
Make sure your machine is set to feed material. There may be a switch or knob somewhere on your machine to lower the "feed dogs" (the little metal teeth that pull the material through the machine). If they are down, the material won't feed so the machine will sew in place. More likely, since its knotting on the bottom, your machine is probably not threaded correctly. Rethread the machine, and try again.
Yes, the thread on the bottom IS the needle thread.
Nov 25, 2007 | Sewing Machines
Kenmore 15208 Mechanical Sewing Machine Logo
56 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
