Question about Hotpoint Dishwashers
Hotpoint dishwasher df61 how to fix soap despenser door and spring
Soap dispenser door has come off how do i put it back on, spring is catching me out
5 Suggested Answers
  • 114 Answers
SOURCE: Hotpoint DWF61 Soap tray
What usually happens with this machine is the peg that the spring attaches to breaks. You will need to drill a small hole into a nearby plastic tab and attach one end of the spring into this hole. Job done.
Posted on Oct 01, 2007
catriver
  • 878 Answers
SOURCE: soap dispenser door doesn't open during cycle of my Maytag dishwasher
Kqon, looks like your dispenser has a wax motor. I think the first thing you have to do is remove the inner door and inspect the soap dispensor assy. See if any of the moving parts are broken. This wax motor is 120V so you can run a cheater cord to it to see if it works, but be very careful when doing this. It will expand the plunger and open the flap. If the wax motor operates with 120V applied to it then you want to see if you have power coming from the timer. It will be the tan wire # 27 on the timer harness. You also want to make sure the spring and pin are in place on the dispenser flap. Your part number for the wax motor is 902899. Catriver.
Posted on Jan 16, 2008
  • 1003 Answers
SOURCE: Soap dispenser door not catching properly
THE INNER DOOR PANEL HAS TO BE DISASSEMBLED TO ACESS THE SOAP MECHANISM NO IT DOESNT JUST PULL OUT
Posted on Jan 18, 2008
SOURCE: Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Posted on Jan 09, 2009
Soap dispenser not working
The soap dispenser door has a spring inside under the pastic that opens it when the timer says it's time for soap.
Sometimes the spring can become disconnected.
Sometimes the plastic part the spring connects to gets broken.
Sometimes the door's pivot point becomes gummed up so bad the spring is no longer strong enough to open the door.
Sometimes solenoid (which works like the electric door unlocker in a car) doesn't work.
Sometimes the timer gets broken and doesn't tell the solenoid when to open the door.
If you start taking out screws around the door to see what is going on inside, unplug the dishwasher first.
Feb 26, 2015 | Dishwashers
The soap despenser is broken. looks like the spring is inside the holder and it will not close....stays open at all times. model number for our dish washer is 665.13842k601.Kenmore ultra wash. is this an...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101 '';
Aug 01, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
Detergent door wont close
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 09, 2011 | Hotpoint 18 in. DC26P Free-standing...
Tablet compartment catch has come loose
i would first call the company and get the price of a new dispenser then see if they have a kit to fix the dispenser.
then call a service tech and see what he would charge you to only put in a dispenser or to fix one with the kit. that will be the best advice because unless you can take down a door and release the dispenser it might not be worth the aggrevasion to try to do something that you might still have to get someonr else to do. unless you are pateint and mechanically inclened. if this helps let me know with a 4 thumbs up post
Feb 27, 2010 | Dishwashers
Kenmore Elite Dishwasher 630 1630 9400 Soap Dispenser Problem
From your description even when the soap dispenser opens it is opening late which is why all the soap does not dissolve.
Try adding only half as much soap and see if it opens then - even a little spilled soap catching on that little latch mechanism can cause it to be difficult to close and stick opening.
Also make sure that the spring that controls the door is not broken.
May 19, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher problem
Symptoms:
Dispenser lid is open. Caked powder at (what would be during normal operation) bottom edge of soap dispenser or caked powder fallen onto dishes or dishwasher bottom. There may be loose powder in rest of dispenser or spilled down inside door or onto dishes underneath dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many dishwashers the top tray has an indentation as wide as the lid of the dispenser. This allows the top tray to be as large deep as possible while still allowing space for the dispenser lid to open. People often pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery or crockery prevents the lid from opening all but a few degrees. Some water will splash in but not enough to wash out the soap powder. The soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly open, will of course swing fully open and you'll be convinced that the lid opened normally during operation. If this is the problem then if you're very careful and open the door very slowly you can actually hear the lid flip open. Also, depending on when the lid opens, how far it opened during operation and how fast you open the door you may find soap powder spilled down to cover the dishes at the front or down the inside of the door. This happens when you first open the door and obviously there couldn't be loose powder there if the powder had emerged while there was water washing around. Seeing the lid open as you open the door is a lot harder but can be done on some machines.
Oct 24, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Jan 16, 2008 | Hotpoint 24 in. DWF61 Built-in Dishwasher
Hotpoint DWF61 Soap Tray Spring
Best way for checking it will be on your next machine's operation. Good luck!
Aug 31, 2007 | Hotpoint 24 in. DWF61 Built-in Dishwasher
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Maytage dishwasher soap dispenser not operating properly
I have an older (1990) Maytag dishwasher that had the same problem. In my case liquid dish soap had penetrated the seal and dried out causing the rotating cover shaft to freeze up.
Remove the door panel and then disconnect and remove the soap dispenser from the door. Make a diagram of the soap dispenser as you carefully disassemble it; there is a coil spring around the soap door axis. If you find a buildup on the door shaft or in the hole it rotates in or in the groove the door rides in, try removing the residue with a plastic scuffy pad after letting it soak in a lime scale remover (Lime Away) or some other cleaner. I think Jet Dry makes a dishwasher cleaner. Before you reassemble the dispenser, wipe a thin film of plumbers grease (available at Home Depot or Lowes) on the shaft.
If the door is free turning and doesn't appear to be bound up, then the problem may be with a heating element that expands when energized, allowing the door to open to the second soap compartment. An ohmmeter will be needed to test the thermal lock.
These jobs are fairly simple and should need only a Phillips screwdriver and a volt ohmmeter.
Happy Motoring!
Mar 06, 2007 | Maytag 24 in. PDB1420 Built-in Dishwasher
Dishwashers Logo
121 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
