Question about Frigidaire Kitchen Ranges
OVEN WILL NOT HEAT UP
I can turn oven to 350 and the green light comes on for "oven"and "preheat", but the oven will not heat up. The broiler will come on and the stove top works
  • 530 Answers
You probably have a bad bake ignitor
Posted on Jan 04, 2009
Turn my oven to preheat, broiler comes on and not the bottom element. Checked the ohms on element and it did move the meter.
Check the broiler element, and see if get the same reading.
Does the oven heat on normal "bake" settings? If so, the bottom element is fine, and it's the "brain" not telling the bake element to get hot.
Jun 08, 2015 | Ovens
Why doesn't my oven heat
If neither your bake or broil is not working. The first thing taht you should check is your safety Hi Limit. Part# 318003614. You will have to remove your oven to gain access to this. it is located behind the oven cavity. Typically blows after a self clean. Careful to switch off your circuit breaker.
http://www.on-timeapplianceplano.com/ovenrepair.html
Jul 23, 2012 | Dryers
I have a Whirlpool Self Clean oven Model number:RBS305PDS17. I used the self clean feature and now my oven will not heat up. All the digital controls work such as preheat and temperature, however there is...
Error code E2F3 indicates oven overheating, i.e. sensor is not cutting off heat. Replace the sensor, about $75 online. If you have done this more than twice, or if oven is acting strangely (for instance, broiler comes on during "bake" preheat), replace control board OEM part #8302994, about $170.
Aug 16, 2010 | Whirlpool Ovens
Frigidaire oven will not light
The control panel behind the knobs is the most likely problem.
The heating element rarely fails.
Apr 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
SLOW HEATING OVEN
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
anyway
14-20 mins is the industry standard for a 350 preheat...
Oct 25, 2009 | GE 30" Built-In Single Electric Wall Oven...
Oven not heating
On the bottom is a link of what your oven is. I'm pretty sure it's the ingnightor #16. You should see a glow red hot when you turn on the oven or broil. Very common problem and pretty reasonable price to repair. Unless that glows and get's red hot, it will not turn on the gas. I think that should do it. Let me know if you need anything else. Scott
http://www.searspartsdirect.com/partsdirect/getModel!retrieveModelDetails.pd?modelNumber=SF325PEEQ0&productCategoryId=0124002&brandId=1198&modelName=Free-Standing,-Gas
Apr 19, 2009 | Kitchen Ranges
Oven will not light
there is a eletric thermocouple at the bottem back of oven unplug the stove remove broiler draw to get access to this part remove small screw disconnect wire replace with new one to order part you will make modle s/n off data plate good iuck later
Apr 01, 2009 | Ovens
Oven elements just stopped working
If I understand your use correctly, you were using the oven to heat the space? Or for baking?
Regardless, it sounds as though the elements have failed. If you used the oven for heating the space (with the door open) the broiler element comes on during preheat of the oven to get the oven to temperature more quickly. The elements are NOT designed to heat a space, and will quickly burn out if used in this manner.
Jan 23, 2009 | Ovens
Oven will not heat - Thermador SMW272 Electric Oven
since you said the broiler does work , take the wires off the broiler element and put on the bake . then when you put on the broiler the bake should work . the light bulb principle, just remember to wrap all loose wire with electrical tape and disconnect from wall while working.
Dec 12, 2008 | Thermador SMW272 Electric Double Oven
Kitchen Ranges Logo
368 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
