Question about Baumatic Ovens
Fixing glass protectors to oven glass door
Sentparts in post with no instructions metal clips to replace plastic ones
SOURCE: AEG COMPETENCE DOUBLE OVEN - 13 year old model
You can look on eBay to buy a used cooker and use it or spare parts
or if its better replace your own.
Posted on Sep 15, 2008
SOURCE: top oven front glass broken want replacement
WHERE CAN WE BUY REPLACEMENT GLASS FOR AN OVEN
Posted on Oct 08, 2008
ginko
  • 19396 Answers
SOURCE: how do i replace the inner glass on the oven door?
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Part here: _.gif PS2087058
Posted on Apr 08, 2009
ginko
  • 19396 Answers
SOURCE: replace inner oven door glass on kitchenaid wall oven
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
Part here: Inner Door Glass
  • 4 Answers
SOURCE: Remove Outer Glass Of Oven Door
On my Zanussi ZDF 866 it goes like this:-
Rest the door with its top edge on your work surface. Once the bottom two screws are removed, pull the outer glass away from the bottom edge of the door just enough so that the brackets fixed to the outer glass (into which those two screws went) clear the bottom edge of the door. Then pull the outer glass up towards you parallel to the door (there are now screws hoplding the top edge on this model).
It may need one side to be pulled and then the other to release it from the metal slot at the bottom.
I would recommend great care with this given that a) your door may be different, b) it could be held more tightly and c) you are dealing with glass. Recommend taking all precautions including eye protection and suitable gloves. Proceed slowly and carefully (this did not need much force on my door). If you're not sure at any stage, choose discretion and either give up or pay someone to do the job to avoid paying for a new glass or hurting yourself.
Hope this may help someone.
Posted on Jan 16, 2010
How to remove glass from oven door
didnt specify unit -generic answer --remove door and place on flat surface or floor --un screw the inner panel --remove glass retaining clips [if present ] -replace glass --replace panel and then door done one of the videos in link an assist you
replace oven door glass Yahoo Video Search Results
Oct 17, 2016 | Ovens
How do i remove the glass from the door
The oven door glass panel is a sealed unit that is not intended to be removed for "cleaning". The unsightly residue between panes accumulates because the metal seal expands while the oven is heating.
Jul 30, 2016 | Ovens
Taking apart a NEFF oven door
The inner door glass is held on by two clips at the bottom (hinge side) and two slides near the handle side. Remove the door from the oven and lie it the worktop flat with the hinges uppermost. Near the hinges you will see the glass is angles leaving a triangle of metal frame either side near the hinges.Rest the outside of your hand on the metal for purchase and then pull on the glass along the bottom edge (reasonable tug required) this will disengage the bottom clips and then slide the glass down about an inch to remove completely.
Mar 21, 2013 | Neff U1661 Double circotherm super...
Inner glass has fallen out
Have an appliance repairman check if the oven is still under warranty and if any recalls on the door are in force.
Dec 17, 2017 | Baumatic B180SS And B60SS (Bundle)...
The inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Jan 31, 2010 | Zanussi ZBF360X Electric Single Oven
How do you remove the door on a 4080 bm?
There are two metal clips at the bottom of the glass that hold the bottom of the glass in place- you can see these from the inside when the door is open and from the outside at the bottom of the door when the door is closed. There are two metal clips at the inside top of the door. You can see these when the door is open slightly inward from the "switch pins on each side.
Open the door. You will see 2 small (about 1/16") metal pieces about 1/2 " in from the 2 switch pins. CAUTION: WITH SOMEONE ELSE HOLDING THEIR HAND UNDER THE GLASS PANEL. Press the 2 metal pins in. Then slowly pull down on handle until the metal parts move down past the tiny opening on the black inner door. This glass is tempered and I can tell you from experience it will break in a million pieces if you are not careful tohold the glass.
It's delicate but very easy. Just be careful
Nov 23, 2009 | Miele DG 4080 Stainless Steel Electric...
Smeg F170-5 door joint broken
The door is removed by rotating, on both sides of the door, a clip on the lower of the two struts that connect the door. The clip rotates up and then engages a hook on the upper clip so that the two are held together by the spring mechanism to allow the struts to be lifted out when the door is in a 45° angled position. With the door off there are three screws on the bottom of the inside that allow the inside window assembly to slide off, allowing the parts to be replaced.
Sep 14, 2009 | Smeg S351X/5 Electric Single Oven
Kitchenaid Conv OvenHeating to toast grilled cheese
At higher temperatures, glass expands differently to metal. if glass was installed tightly by what ever means (some use silicon sealer or metal clips etc.) the different expansion rate could have been the problem. Not to mention a possible weakness in that piece of glass.
Sep 14, 2009 | KitchenAid Architect Series KEMC308KSS...
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Smeg se336ss 5 some so and so has broken the outer glass door!
We removed the front glass of our oven door after a big spill between the two glass sections (by blunt force!). Since it took us 4 hours to put back together, we wanted to spread the info in case any others have the misfortune to make this mistake! Note, I wouldn't do this unless you have to, just incase you can't get your door back together again.
Assuming the back sheet of oven glass is still in position, but the front sheet is not attached -
1. Follow the manual instructions to remove the door, ensuring that both hinges are locked fully (otherwise you won't be able to get the door back on easily)
2. Once the door is removed, ensure that the plastic spacers that hold the two sheets of glass apart are in original position, resting on the inner door, at the bottom corners of the tempered glass
3. Remove the narrow metal strip at the bottom of the inner door by unscrewing the 3 screws that hold it in place. This is the metal groove that the outer pane of glass needs to rest in
4. Lay the outer sheet of glass in position in this metal strip
5. Lay the outer sheet of glass over the inner door. Slot the outer sheet into position at the top of the inner door first, ensuring it is layed flush at the top.
6. A second person needs to ease the metal strip back into place at the bottom of the inner door, so that the two sheets of glass are now held together at both top and bottom.
7. Screw the metal strip back into position with the 3 screws
8. Follow the manual instructions to replace the door. Ensure that the small grooves at the bottom of both hinges are resting in position correctly, otherwise the door will not close flushly.
Jan 17, 2009 | Smeg DO81CSS Electric Double Oven
Ovens Logo
29 people viewed this question
Top Baumatic Ovens Experts
Starnley Johnwells
Starnley Johnwells
Craig Butler
Craig Butler
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
