Question about Texas Instruments TI-83 Plus Calculator
WHen I replace the batteries, all I get is a solid black screen.
A week ago, I opened the case, and it said the ram was cleared, and now the only screen I can get is a solid black one, which I can sometimes get to go blank, and then when I turn it on, it shows the black screen and then immediately turns off.
Have you tried adjusting the contrast using second and the up and down arrows?
Posted on May 23, 2007
I found the solution on mathforum.com as well. What worked for me was doing a memory dump. Following are the instructions that I found: On 2006012917:15:08, silverHalo wrote: > > >One solution is doing a Memory Dump. These are the instructions for >reseting the memory if you can't see the screen. Turn calculator on. >Press the "2nd" (yellow button) and "+" (MEM) function (this takes us >to the "Memory" screen. Then press the down arrow key 4 times (which >is the #5 choice - Reset), then press "enter" (this selects the - >Reset function). Then press "enter" again (this selects the - "All >Memory" funtion). Then the down arrow key once, then "enter"( this >selects the #2 choice - Reset). IF you did it right then you should >see the normal screen again with the word "Memory cleared" or >something like that. If you hold your screen at an angle in a good >light source (sunlight) you can still see what you are doing on the >screen, as it is not totally black. Hope this helps!!
Posted on Sep 06, 2007
Hey, I had the same problem just now and found the solution on a math forum, the link is below. You probably already tried to adjust the contrast by holding down [2nd] and holding down [v] (=down arrow key). Instead try the following: Hold down [2nd] Hold down [v] Release [2nd] but not [v] and it will take the contrast back down to zero. What a relief, right? http://mathforum.org/t2t/discuss/message.taco?thread=1651&n=24
Posted on Jun 16, 2007
Emachine laptop E527 won't switch on power button solid blue with black screen stone dead no sounds beeps nothing
Dear
In this case the RAM may have the problem. Pl. do detach the RAM from the mother board and clean the golden contact points with a dust free eraser and re-attach the same to the mother board. (found under the back cover).
If problem persists replace the RAM with new.
Thanks.
Jan 31, 2015 | Computers & Internet
Why is that after the battery gets down to about 15% or after I've used it for a while, it decides to shut off and it won't let me charge it back up. I plug in the charger and the screen stays black but I...
The battery or the charger may be defective. Because it is so new I would advise you to either return it to the place of purchase or contact the manufacturer. If a defect surfaces within the first 30 days the manufacturer may require you to contact the seller first for any issues.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Jan 09, 2015 | Chromo Inc Chromo AAAAAAAA Pink 4gb 7"...
Black screen with blinking cursor in left corner.
Please power off, remove the RAM and then reinsert the RAM. Power on the pc.
Aug 01, 2010 | Intel D945GCCR Motherboard
P1493 code
If you are running any extra systems, ie amps, subs, high watt speakers, etc. etc. you may need to get a better batter, like the blue. or yellow top one. check with auto zone.
Mar 11, 2010 | 2001 Dodge Ram 2500 Truck
The cursor blinks as a checkered black square and keys don't work
The memory of the calculator is ful,l that is why you cannot enter anything anymore. You must clear the RAM of the calculator.
Press [2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER]. Press CLEAR to clear the Ram Cleared Message.
If that does not work, pull the main batteries out of calculator and leave them out for a while (a few hours). Then reinsert them.
Hope it helps.
Thank you for using FixYa and rating the solution.
Dec 01, 2009 | Texas Instruments TI-83 Plus Calculator
1998 Dodge 1500 Extended cab 4wd 5.9 Magnum motor Approx 115k miles. Mostly highway driving Check engine light, was coming on and then clearing by itself after a week or so. Started a few months ago. Was...
there may be a software update for the powertrain control module for mis-fire monitor. check with your local dealer. but if thats not the case,these engines are known at least in my experience of having the heads crack between the valves and cause mild mis-fires. try compression testing all the cylinders and performing a leakdown test on them as well.
May 12, 2009 | 1998 Dodge Ram 1500 4WD
Apple ibook crashed when on MS Word. Black screen fan running???
Sounds like you have a problem with the logic board. This appears to be a common problem with iBook G4 related to the fit of the logic board (ie motherboard) within the case.If you were to take it to apple store the likely fix would be to replace the entire logic board which is very expensive and probably not fiscally sound on a 5 year old machine. Another option would be to try to fix it yourself. If you are feeling brave you can dissemble the laptop and attempt to shimmy the logic board back into position.
Here's a link that detail the approach. http://www.coreyarnold.org/ibook/. This guy had success on two ibooks that had the same problem and they have been working for 2 years since he did his repair
Also, here is a link to a forum that may offer you a few more approaches to solving your problem. iBook G4 won't boot up - fan running & black screen - AppleNova Forums
Hope this helps, good luck!
Mar 30, 2009 | Apple iBook G4 14-INCH Series M7701LL/A...
Ti 83 black screen problem
i had the same problem. If you hit 2nd down 2nd down 2nd down and keep repeating untill the screen clears it should solve the problem. i tried the other solutions that tried clearing the memory and they didnt do anything but erase the equations i had previously put in it (great). But this should work.
Feb 22, 2008 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus Problem
Batteries:
Make sure to replace the "battery backup" too the little lithium ion battery
Try Adjusting contrast:
Hold down "[2nd]" key press up or down arrow repeatedly to lighten or darken contrast.
First attempt reseting:
Step 1: Remove all the batteries
Step 2: Hold "Clear" key down
Step 3: Still holding "Clear" key reinstall batteries
Step 4: Still holding "Clear" key press "On" key until home screen is displayed.
Second shot reseting:
remove all batteries including lithium ion (backup battery), wait 3 hours and reinstall batteries.
Third Shot reseting:
Step 1: Remove a battery
Step 2: Hold down "DEL" key reinstall battery
Step 3: Possible msg pops up saying "Waiting ... Please install software" IGNORE msg and take out battery again
Step 4: Reinstall battery do not hold down "DEL" key
reseting will cause the handheld to loose all of its stored memory.
Hope that helps!
Jan 29, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
460 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Steve Allison
Steve Allison
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
